Water leaking into the footwell
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by veggiecar, Dec 5, 2025.
  1. veggiecar
    veggiecar Junior Member
    I had a broken window and had a Safelite replacement installed. My window did not leak before the installation but is leaking after the job was complete. I watched the installer throughout the process. There was no rust around the window frame and the installer put a continuous healthy bead of sealant where the window would rest. My point is that I don’t think it is the window that is leaking. The wiper assembly was removed before installation and replaced after the window installation was complete. When it rains, water seems to be collecting somewhere and when the car is moved, water runs in from behind the dash either to the far right or far left of the foot well depending on the direction the car is turned. My question is: Do you know of anything with the windshield wiper assembly that might not have been reinsstalled correctly that might cause this leaking problem? Is there another problem that I should be looking for? I texted the installer but have not heard back from him as of yet.
    Thanks for the help … Michael
  2. douglasjre
    douglasjre Senior Member
    2,236
    747
    Null, NL
    Drains on the wiper tray are clogged on both sides. Then overflows into the air intake of your air handler in the passenger compartment. 14 mm socket pulls off the three nuts and then you pull off the wiper arms and then the plastic cover comes up off the wiper tray. Check the left and right sides of it because it's probably clogged at both ends. Use a vacuum. Report back so we can learn from your experience
    CR94 and ETC(SS) like this.
  3. veggiecar
    Thank you for the guidance. The passenger side drain actually had a bit of water pooling and the drivers side drain had debris that might have impeded water flow. I vacuumed and blew out both drains. I will report back as to if this solved the problem. Thanks so much…
    douglasjre likes this.
  4. veggiecar
    It seems that the problem is not a clogged drain. I have included a picture of the drivers side drain. When the window is installed, a tall bead of sealant was laid down but there is also also a rubber seal applied to the edge of the window. I have included a picture of the seal on the passengers side towards the bottom of the window. I am thinking that the seal around the window was not installed properly.
  5. veggiecar
    Safelite is coming back out to reinstall the windshield. Does anyone have the Service Manual description of how the windshield should be installed? In particular, I am interested in the seal that goes around the edge of the windshield and how it should look after it is installed. If you have a good picture, that would be appreciated. Thanks for the help … Michael
