Inserting new spark plug tube seals into the valve cover ... anything better than beat them in?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by pingd, Oct 12, 2019.
  1. pingd
    pingd Member
    97
    61
    Twin Cities, MN
    Thank you Georgina! Sorry to not understand, but I do not have the proper foundations to know how to proceed.
    Could someone please help translate? For example:
    - what type of machine/industrial shop could do this? (ex one that specializes in POM? ... for what type of application ... automotive?)
    - what artifacts would I need to bring with me so that they could understand? (rough drawing, drawing with dimensions, valve cover with example seal, just example seal, etc)
    - would this be considered a "routine" or "exotic" request?
    - guestimate of cost?
    Basically, for the right person (Georgina) easy to do, but would others typically have the equipment and would they be inclined to undertake such a request? (Really wish I lived in SC but I'm in MN!)
  2. Mendel Leisk
    41,442
    Especially onsidering the original seals were maybe ok:
    There's got to be a simple, low budget way to press those seals in, with what you have on hand. Don't overthink it?
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,465
    2,429
    Taylors, SC
    You can actually make the driver out of wood on a wood turning lathe. That's how manufacturers like Ford did it for the Model T.
    Also, POM Delrin can easily be turned on a woodworking lathe.
    Simply put, all I would need to know is how deep the seals are inserted. Most often, they are flush, but I would have to be sure. Just have to look at them before removal to know. The only other thing I would need is one of the seals. That's all.
  4. Mendel Leisk
    41,442
    Looking through post #14 attachment, the Repair Manual instruction is to use an old gasket with the seal portion cut off, to help install the new gasket
    Last illustration, enlarged:
    The Critic likes this.
  5. pingd
    pingd Member
    97
    61
    Twin Cities, MN
    Many thanks to you again Master Po as well as Georgina.
    What worked for me in the end was trial and error: ordered a different brand of valve cover gasket + tube seals:
    Beck Arnley 036-1887 Valve Cover Gasket Set
    The tube seals were probably 0.4-0.75mm less in diameter and they popped in quite readily
    Son swears that these aftermarket seals are the same as the original Toyota ones (pattern of ridges/markings).
    Tried the above method with the new (superseded) Toyota part and Fel-Pro but had limited success.
    The nigh impossible part for me was always getting the entire seal initially seated into the hole (i.e. seal is too big for the hole unless you deform it).
    A heat gun worked to some extent - but because the rubber coating on the seal is basically "paint thick" it exposed the metal bands inside and this made it unviable.
  6. Mendel Leisk
    41,442
    pingd and Raytheeagle like this.
  7. RavenPri
    RavenPri New Member
    22
    North West California
    So yeah, I know this is an old post but I am having the exact same difficulty with replacing my spark plug tube seals.
    Firstly, they original seals were brittle stretchy soft. It took a couple hours of scraping with a pick to get off. Completely adhered to the metal. I suspect based on the car fax report it sat in a storage unit in Indiana for 1-2 years and never was started causing the gaskets to dry out. Otherwise they were a bad factory batch or got way over heated. IDK. But they were a great pain to remove.
    Now I went through a couple of the new ones but they just wouldn't go in and just damaged them. I thoroughly read the install instructions posted about cutting the inner circle on the old one and since no old one existed I now had a half set could cut. Thankfully the local parts department had what I needed. The OEM from the parts department were a few hairs smaller than the fel-pro kit but still having difficulty. It gets in just a bit but then no movement. Have another OEM set in the mail and just after reading through this thread just ordered the Beck Arnley set.
    Watched a few videos and all though there's probably time cutout you don't really know how long they are tapping for, but it seems it does go in smoothly more than forcibly.
    Going to try and make a press out of a bolt, washer and socket. Hopefully that works, but doubts are deep.
  8. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,698
    1,743
    Bay Area
    Have you watched this video on how I installed it?
    if its dry, use some silicone paste to lube the rubber so it'll go into the hole easily.
    RavenPri likes this.
  9. RavenPri
    RavenPri New Member
    22
    I have, thoroughly a few times. As well as a couple others just doing the valve cover. Everybody's just pops out, pops in. Granted there is some time cut but it fits without force, just plain tapping. The outer part should just be a tad recessed in and the upity part just level. It goes in a bit but not like it should. The gasket has no play in the hole when you place it in flat. I would think there should be a bit , just enough to get past the lip. Otherwise its like pounding a square peg into a round hole. I used some Vaseline jelly, a dab of oil, thought about the liquid wrench but unsure reactivity with gasket. The silicone spray is worth a try, that stuff is slick.
    I like the idea of making a press so that to keep as a tool for future use.
    NutzAboutBolts likes this.
  10. NutzAboutBolts
    1,698
    1,743
    Bay Area
    You have to force it in by hammering the over sized socket or else it won’t go in by pushing it with your hand. I used a 30mm socket and a hammer to hammer it into the hole. A press would be an over kill and doing the socket and a hammer is the basic tool we use when putting in the spark plug tube seals. Hope that helps. I’m curious of your press that you’re thinking of making though.
