Must I take my Prius to a Toyota dealer for routine maintenance?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by priusunum, Dec 6, 2006.
  1. Lucymama
    Lucymama Junior Member
    Southern California
    I have a 2010 Prius III. Dealer is telling me work needs to be done by a mechanic that is Toyota hybrid-certified, or else my warranty will be invalid. I am not a d0-it-yourself owner, and have carefully had all scheduled maintenance done at Toyota. Mileage now 29,000. They tell me next service is $500. Any advice aappreciated.
  2. jdenenberg
    jdenenberg EE Professor
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Your dealer is at least misinformed, if not just lying. I would never let that dealer do any work on my Prius. You can either DIY or find a good local shop do standard maintenance items. Hybrid related items need to be done by a mechanic that understands the Hybrid components. There are several qualified independent Hybrid shops in California.
    The 30,000 mile work that they are quoting is full of unnecessary items. Use the list in your owners manual to limit the cost, but consider adding a drain and refill of the Transmission fluid at this time (Use Toyota Type WS ATF if you DIY - instructions can be found by searching this discussion group, dealer cost should be about $100).
    JeffD
  3. bogeybob513
    bogeybob513 rtc513
    147
    Myrtle Beach, SC
    I must have the dealer from hell-always overfills even when it is noted on the order, once left the oil cap OFF after oil change, then when they did the recall on the inverter water pump, they didn't secure it and left me stranded on a trip!
  4. richard schumacher
    7,664
    1,046
    United States
    Why continue using that one?
    usnavystgc likes this.
  5. pardreamer
    pardreamer Member
    114
    San Diego
    I did not take my 2008 Prius to the dealer once. I have mechanic friend and he charges about half of what a dealer typically charges.
  6. Lucymama
    Southern California
    Thank you ! I really appreciate your feedback. Lucymama
  7. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    If you don't want to do it your self, we'd love to do it for you. And, for much less than $500.
    Avi
  8. Robert21PrimeLTD
    82
    Nashville
    An example of what to expect from a Toyota Dealer. I received a coupon for a free oil change from my local dealer. I took advantage of the coupon and also asked them to rotate the tires since it had been 10k miles. The service tech suggested performing a complete fuel system cleaning for $364.92, brake fluid exchange for $247.70, and PVC valve replacement for $631.64 Total cost $1,356,33 but not anything that Toyota specifically recommends at 60k. I declined.
    When finished my bill was $0. They rotated the tires for free even though they could have charged me for it. I’ll look for another free coupon next year when they say that they “miss me” again.
  9. BiomedO1
    3,627
    1,872
    SacTown, Ca
    Zombie thread......
  10. Mendel Leisk
    41,463
