TPMS light should be OFF
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Frontporch, Dec 16, 2025 at 4:01 PM.
  1. Frontporch
    Frontporch Active Member
    527
    118
    Nj
    I replaced my TPMS sensors in each tire this summer.... Worked without issue for months.
    The light is now on and I immediately assumed that a cheap sensor was bad. Connected techstream and saw several pressure values. All seemed reasonable. It looks like the Low threshold (sorry I dont remember the name) was around 26 PSI. I think all of my tires were around 31-34 PSI and some other indicator pressure (there were four values) were all slightly different but very high... 28-30.
    I would like to do a sensible reset of this system. If I verify all cold pressures are around 35PSI should I be able to use the TPMS reset to get that light off? Not really sure how it works. I didn't find it in the owner's manual at first glance. I also saw temp readings that were similar to the outside temp 30 degrees. I hope cold is good for a reset.
    Thanks!
    51,950
    idk, but definitely put a gauge on the tyres, cold makes the pressure drop
  3. Brian1954
    Brian1954 Senior Member
    2,211
    869
    South Central PA, USA
    Post a picture taken of the Techstream data for the tire sensors.
  4. Tombukt2
    12,993
    2,329
    Thot in very 28 the tire info.is on main screen .the screen that shows health at top . Tells me what ea sensor is reading by number 1234
