TPMS light should be OFF
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Frontporch, Dec 16, 2025 at 4:01 PM.
  1. Frontporch
    Frontporch Active Member
    528
    120
    Nj
    I replaced my TPMS sensors in each tire this summer.... Worked without issue for months.
    The light is now on and I immediately assumed that a cheap sensor was bad. Connected techstream and saw several pressure values. All seemed reasonable. It looks like the Low threshold (sorry I dont remember the name) was around 26 PSI. I think all of my tires were around 31-34 PSI and some other indicator pressure (there were four values) were all slightly different but very high... 28-30.
    I would like to do a sensible reset of this system. If I verify all cold pressures are around 35PSI should I be able to use the TPMS reset to get that light off? Not really sure how it works. I didn't find it in the owner's manual at first glance. I also saw temp readings that were similar to the outside temp 30 degrees. I hope cold is good for a reset.
    Thanks!
    51,965
    idk, but definitely put a gauge on the tyres, cold makes the pressure drop
  3. Brian1954
    Brian1954 Senior Member
    2,219
    874
    South Central PA, USA
    Post a picture taken of the Techstream data for the tire sensors.
  4. Tombukt2
    13,000
    2,330
    Thot in very 28 the tire info.is on main screen .the screen that shows health at top . Tells me what ea sensor is reading by number 1234
  5. priumium
    priumium Member
    227
    56
    Sweden
    Do a health check and validate if you have a current or historical TPMs code.
    Light will stay on with historical codes, for example if one sensor went into sleep mode and did not communicate within 20mins, dtc is set and the light will be on for 20 cycles apx, unless cleared.
    None of your mentioned values are below 26, so seems ok unless the temperature sensor part is invalid/wrong.
    Your described concept for resetting the minimum threshold value is correct, however it will unlikely remove the light. Check the actual reason is step one, especially since you have TS ready!
  6. Frontporch
    528
    120
    Nj
  7. Brian1954
    2,219
    874
    All the tire sensor data looks okay in the picture. Was the low tire pressure light on when you took the picture?
    What is the trouble code(s) shown in techstream? Post a picture please after running a health check.
    SM-S931U1 ?
  8. ChapmanF
    18,222
    That live screen shows 0 for Number of DTC. So there don't seem to be any DTCs at that moment. If the warning light was on right then, I'd be at a loss to say why.
    Brian1954 and Tombukt2 like this.
  9. Brian1954
    2,219
    874
    I missed that when I looked at the data in the picture. Nice find.
  10. Tombukt2
    13,000
    2,330
    I'm just interested if you had a code at all and what it was when it was..
