Help! Dashboard lit up after cat replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PerezPrius, Dec 20, 2025 at 2:38 PM.
  1. PerezPrius
    PerezPrius New Member
    Yesterday
    New York
    3146306852184853193.jpeg 7888010798158439409.jpeg IMG_6898.jpeg 3146306852184853193.jpeg 7888010798158439409.jpeg IMG_6898.jpeg I have a Gen 3 (2014) that got the cat stolen in NYC. The mechanic shop quoted $1500 for aftermarket install. The car had no problems when we dropped it off, just missing cat and O2 sensor.
    When we went to pick it up the mechanic said the car has computer problems also and we saw the dash was lit up. He say his upscale computer isn’t resetting it.
    I attached a pic but It’s ABS light, brake light, traction control, and some others. The codes are C1203, C1232, C1336, C1345.
    After driving a couple days as he suggested the codes didn’t go away so he opened the steering wheel and say we may need to replace the clock spring and Steering Angle sensor.
    I asked him if maybe the tech working on the Catalytic converter messed something up but he says he checked everything. This shop did a bunch of work on another car of mine recently and there wasn’t an issue after ward so I’m confused.
    Anyone have a clue what might cause this? I saw there’s a bobby pin method to reset the lights but I haven’t tried it yet.
    Any input appreciated!!!
  2. PriusCamper
    PriusCamper Senior Member
    12,786
    5,177
    Pacific Northwest, USA
    Ask the mechanic who worked on the car about the condition of the wires that were cut/torn from O2 sensor when Cat was stolen? Those loose wires can short out one of the computer's vehicles if they touch metal and because it had not failed when you dropped it off it means that swapping out that ECU to fix the problem might be covered by them partially or fully. Of course you don't have an ECU failure code so...
  3. PriusCamper
    12,786
    5,177
