Prius Tire Valve Cap
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Gokhan, Oct 29, 2025.
  1. Mendel Leisk
    41,518
    Been wondering the same...:whistle:
  2. VelvetFoot
    VelvetFoot Active Member
    755
    268
    New York State
    2026 Prius
    In looking at my tpms' rubber stem, it doesn't seem to have enough room for the skirted model, but who knows.
    I ordered some of the short ones.
    I like the gasket.
    Thanks.
    Gokhan likes this.
  3. Gokhan
    Gokhan Senior Member
    6,249
    2,479
    Paramount CA
    Metal TPMS valves are using the small caps.
    The long caps with a skirt are for rubber TPMS valves with a tapered end.
    But then some rubber TPMS valves are also using regular plastic caps (with a rubber bushing inside). See the second link.
    A2Z 2024 dual-band TPMS sensor, universal fixed-angle rubber + metal valves (315/433 MHz)
    OE rubber valve Kit | Bartec USA LLC
    #83 Gokhan, Dec 21, 2025 at 6:01 PM
  4. VelvetFoot
    755
    268
    New York State
    2026 Prius
    Mine are rubber stems. Replaceable, supposedly.
    Gokhan likes this.
  5. kev604
    kev604 Junior Member
    53
    47
    Vancouver, BC Canada
    2026 Prius Plug-in
    My previous car a Nissan with TPMS I used metal valve caps without issue. I do use plastic valve caps for my winter wheels.though as I've had the metal ones seize.
  6. VelvetFoot
    755
    268
    New York State
    2026 Prius
    The car that I had the problem with was a MINI. I put some fancy valve caps on. As I recall, I tried a pliers on one-pro tip: don't. The tire shop ground (cut) the others off.
    Gokhan likes this.
  7. VelvetFoot
    755
    268
    New York State
    2026 Prius
    The short black caps from Amazon arrived. They seem to fit perfectly, and you really have to look close to notice any difference.
