Prius Tire Valve Cap
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Gokhan, Oct 29, 2025.
  1. Mendel Leisk
    42,347
    Been wondering the same...:whistle:
  2. VelvetFoot
    VelvetFoot Senior Member
    1,408
    545
    New York State
    2026 Prius
    In looking at my tpms' rubber stem, it doesn't seem to have enough room for the skirted model, but who knows.
    I ordered some of the short ones.
    I like the gasket.
    Thanks.
    Gokhan likes this.
  3. Gokhan
    Gokhan Senior Member
    6,714
    2,672
    Paramount CA
    Metal TPMS valves are using the small caps.
    The long caps with a skirt are for rubber TPMS valves with a tapered end.
    But then some rubber TPMS valves are also using regular plastic caps (with a rubber bushing inside). See the second link.
    A2Z 2024 dual-band TPMS sensor, universal fixed-angle rubber + metal valves (315/433 MHz)
    OE rubber valve Kit | Bartec USA LLC
    #83 Gokhan, Dec 21, 2025
  4. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    Mine are rubber stems. Replaceable, supposedly.
    Gokhan likes this.
  5. kev604
    kev604 Junior Member
    56
    50
    Vancouver, BC Canada
    2026 Prius Plug-in
    My previous car a Nissan with TPMS I used metal valve caps without issue. I do use plastic valve caps for my winter wheels.though as I've had the metal ones seize.
  6. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    The car that I had the problem with was a MINI. I put some fancy valve caps on. As I recall, I tried a pliers on one-pro tip: don't. The tire shop ground (cut) the others off.
    Gokhan likes this.
  7. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    The short black caps from Amazon arrived. They seem to fit perfectly, and you really have to look close to notice any difference.
    2023p and Gokhan like this.
  8. Gokhan
    6,714
    2,672
    Paramount CA
    I will order them, too. They are a good alternative to the OEM tire valve caps, which the dealers are losing all the time during service. And they aren’t carrying the OEM caps in stock to save money. The aftermarket caps they use don’t even have the rubber bushing inside. I like the red silicone rubber bushing inside the Amazon caps.
    The really long TPMS tire valve cap with a skirt I also mentioned is only compatible with the tapering-type rubber TPMS valve stems, not with the metal stems on the Prius.
    Toyota OEM TPMS cap made by Pacific Industrial Co., Ltd. has the part number 90942-05039 (Japan packaged in bags of ten, made in Japan) or 90942-A5002 (apparently identical part, US packaged in bags of ten, made in Japan).
    Amazon has cheap options for this TPMS tire valve cap. It is is also available in gray.
    Really small black TPMS tire valve cap on Amazon (same type and color as the one made by the Toyota OEM Pacific)
    2023p likes this.
  9. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    My stems are rubber and I still think they won’t fit.
    Gokhan likes this.
  10. Gokhan
    6,714
    2,672
    Paramount CA
    The very long TPMS tire valve caps with a skirt apparently only fit the tapered-type rubber TPMS valve stems as in models B-9073 and B-9100 in the picture below.
    2023p and VelvetFoot like this.
  11. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    That makes sense. :)
  12. RRxing
    RRxing Senior Member
    2,563
    1,842
    NEPA
    This is the best thread ever! ;)
  13. Mendel Leisk
    42,347
    Yeah, amazing longevity, for what's essentially a dust cap.
  14. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    Unfortunately with tpms, one cannot just unscrew the old Schrader valve insert and replace with a new one. So, if water, (who cares about dust?), gets in there and does harm...
    Gokhan and Mendel Leisk like this.
  15. Gokhan
    6,714
    2,672
    Paramount CA
    Here are the Toyota Pacific OEM TPMS tire valve cap (part no. 90942-05039, or equivalently, 90942-A5002) and Amazon TPMS tire valve cap pictured side by side, the Pacific OEM cap being on the left. They are certainly quite different, with the OEM cap having a lot more threads, a smaller outer diameter, a deeper rubber bushing, and a larger-diameter inner concentric cylinder. The made-in-Japan Pacific OEM cap is of a lot higher quality than the cheap Amazon Chinese cap, but that is expected.
    The only difference between the Amazon TMPS tire valve cap and a standard tire valve cap with a rubber bushing is the outer appearance.
    The Toyota Pacific OEM TMPS tire valve cap offers a higher margin of protection with a lot more threads and a longer and wider concentric cylinder mating with the inside of the valve. It also threads on the valve deeper. Moreover, it looks significantly nicer.
    However, any halfway-decent standard plastic tire valve cap with a rubber bushing will work OK with TPMS valves.
    theRob and VelvetFoot like this.
  16. RRxing
    2,563
    1,842
    NEPA
    Like Timex watches, this thread just keeps on ticking...
    VelvetFoot likes this.
  17. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    I will say OEM does look more high quality.
  18. Gokhan
    6,714
    2,672
    Paramount CA
    Yep, in summary:
    • The Toyota Pacific OEM TPMS tire valve caps (part no. 90942-05039, or equivalently, 90942-A5002) are of far higher quality than anything else out there, with many threads that go in and a greatly mating high-quality rubber bushing deep below a mating inner concentric cylinder. The only downside is that they are not cheap, and you need to special-order them. Chances are that they will lose them every time you take the car to service; so, swap them with cheaper caps before you take the car to service.
    • If you can’t get the Toyota Pacific OEM TPMS caps, any cheap plastic cap with a rubber bushing inside will be OK.
    • OEM-cap knockoffs sold on Amazon etc. are nothing like the OEM caps inside. They are actually like regular caps inside. They only match the outer appearance of the OEM caps.
    • Never use metal caps with TPMS valves, as they could lead to corrosion.
    #98 Gokhan, Dec 31, 2025
