Losing coolant but car runs fine
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by andy song, Dec 27, 2025.
  1. andy song
    andy song Junior Member
    I have been needing to put in about a quart of coolant every 3 days into the bottle
    I can see white smoke from the tail pipe
    But the car drives fine. No misfire. No check engine light
    A friend said it is a head gasket but I don't think it is as i never feel any shaking from the engine.
    Anyone losing coolant from the gen 4 prius?
    Car is a 2021 AWD
  2. Bill Norton
    Bill Norton Senior Member
    2,208
    744
    MONW, Ks.
    2019 Prius
    L Eco
    I just bought a '19 Gen 4, so I've been doing a bit of research.
    There was a problem with the EGR coolant getting into the exhaust system directly in the Catalytic Converter area.
    I think there was a TSB or recall on this problem.
    You may qualify!
    Good luck!
  3. Brian1954
    Brian1954 Senior Member
    2,371
    954
    South Central PA, USA
    It is not the EGR system but the exhaust heat recovery system (EHRS). Coolant is leaking from the heat exchanger into the exhaust system just in front of the catalytic converter. Very common problem on the Gen 4 Prius. Do a search in this forum and you find a lot of information. This should be covered by the Toyota warranty.
    @andy song , Take the car into your local dealership to get it fixed under warranty.
    #3 Brian1954, Dec 27, 2025
  4. BiomedO1
    4,019
    2,109
    SacTown, Ca
    That would be covered under the federal emissions warranty 8yrs or 100K miles or you may be able to talk the dealership into replacing it for free, reference the TSB. I don't believe the 2021 model year was covered under that - but it doesn't hurt to ask.
    If they refuse to cover it for free; just by-pass/loop the hose at the heat recovery unit, behind the CAT. There's a few YouTube videos and multiple threads on this forum about this. Search 'exhaust gas heat recovery'
    Hope this helps.....
    #4 BiomedO1, Dec 27, 2025
  5. Mendel Leisk
    41,826
    Bill did you forget your Ginkgo Biloba this morning? ;)
    Bill Norton likes this.
  6. Bill Norton
    2,208
    744
    MONW, Ks.
    2019 Prius
    L Eco
    No, just new to a Gen4.:rolleyes:
    Isn't there something about EGR being taken post CAT?
    I've had mine for exactly 2 weeks now and loving it!
    Still learning the systems and their names....:whistle:
    It's a '19 ECO with only 235k miles on it. So I got it for a song!
    The Champ!!
    Next I'm buying a Comma for it. That was the driving force to give up on Gen3's.
    That and head gaskets. Once is enough.....:mad:
    But the quietness and improved fuel economy are added treats !
    I cleaned the battery fan filter, for the first time from the looks of it, but it was easy and satisfying!
    And today the engine oil/filter and transaxle ATF. Mobil 1 all the way! I won't argue about using WS, again...
    I like premium lubes !!:whistle:
    And soon both air filters will arrive.
    I'll test the engine coolant and then, relax and drive the Hay'L out of it. while I wait for the Comma to arrive.
    Are there threads here about setting up the Comma?
    Updating my signature soon.
    How about that for jacking a thread???? o_O
  7. rjparker
    10,412
    6,521
    Leaking coolant into the Exhaust Heat Recirc system at a high rate needs repair or bypass asap. Otherwise you risk a badly overheated engine and then a head gasket.
    Brian1954 and BiomedO1 like this.
  8. BiomedO1
    4,019
    2,109
    SacTown, Ca
    thanks @rjparker - I guess my memory isn't that bad from old age.o_O:rolleyes::ROFLMAO::whistle::love:(y)
    I don't believe Wisconsin is a CARB state.
  9. Mike Porter
    Mike Porter New Member
    Nashville tn
    Looking for someone in or near Nashville tn to help me do the heat exchanger bypass
  10. ChapmanF
    18,458
    For what it's worth, I'm pretty sure that heat exchanger is just behind both catalytic converters.
    In a gen 4, the first catalytic converter is built right into the exhaust manifold. The second converter is the first bulge in the exhaust pipe. The next bulge is the EHRS heat exchanger, and there's probably a resonator/submuffler bulge after that.
  11. Bill Norton
    2,208
    744
    MONW, Ks.
    2019 Prius
    L Eco
    Shouldn't you see if the car qualifies for a free emission systems repair at a dealership first?
    There is a lot on info about this system failing.
  12. BiomedO1
    4,019
    2,109
    SacTown, Ca
    Just look for two black rubber hoses going into one of the exhaust pipe budges; that's the lines you'll need to loop.
  13. rjparker
    10,412
    6,521
    After you verify Toyota won't repair it free (which could get you a new assembly), I would have any shop with a lift immediately do a below vehicle bypass.
    Option 1
    Bypass under the vehicle
    Option 2
    A no lift, no parts required driveway bypass requiring more time.
    Bypass in Engine Compartment requires Wiper Assembly and Cowl Removal
    Long term a bypassed heat recirc/exchanger should have the internal actuator forced open. However this is not an immediate requirement as an exhaust flow still exists and normally exhaust pressure alone will open the straight through path.
    #13 rjparker, Dec 28, 2025
    Misterman74 and Brian1954 like this.
  14. Brian1954
    2,371
    954
    Thank you, ChapmanF, for correcting what I wrote in post #3.. I am not very familiar with a Gen 4 Prius and normally do not make posts in the Gen 4 forum.
    Bill Norton and Misterman74 like this.
  15. Misterman74
    Misterman74 New Member
    25
    Fresno
    2018 Prius
    mobile 1 is not a "premium lubricant "
    Amsoil is a premium lubricant.
  16. Bill Norton
    2,208
    744
    MONW, Ks.
    2019 Prius
    L Eco
    And what premium ATF should I use in my Gen 4 transaxle?
    I have a jug of Reline ATF D6. Is that considered premium?
  17. Bill Norton
    2,208
    744
    MONW, Ks.
    2019 Prius
    L Eco
    Thanks for posting this primer on this system!!
    I got to take advantage of it this 19° morning leave for work in my '19 ECO.
    I feel it did get the cabin warmer quicker than in my Gen 3.
  18. Mendel Leisk
    41,826
    Not according to toyota:
    Also, while it's not noted in the Owner's Manual, but I did come across a document, likely a dealership service department directive, saying to only use ATF WS from freshly opened bottles.
    After doing the bypass?
  19. Bill Norton
    2,208
    744
    MONW, Ks.
    2019 Prius
    L Eco
    No, my Gen 4 is doing fine. The OP has the problem.... pay attention....;)
    I feel my Gen 4 is quicker to warm the cabin than my old Gen 3.
    Technically I have not crawled under the car to see if it's using the exhaust heat recovery system (EHRS).
    OH NO,,,
    Not the dreaded 'may cause ultimately damage' .....:whistle:
    But let's do this, again.....:rolleyes:
    WS is the house generic ATF. That's what your 25 year old Tercel uses. And most everything else they drag into the shop. They want to sell their stuff that the parts room stocks.
    I choose to use a higher quality synthetic ATF. I have been using Mobil 1 or Redline ATF's in my many Gen 3's for a long time and many miles.
    I feel my transaxle is happier and that I'm getting many more mpg ;) using a modern synthetic alternative to WS. (y)
    I started a very long thread on testing the ATF that was drained at different intervals.
    ATF fluid changes ARE Required. | PriusChat
    Dang, up to 37 pages now !!! To be honest, I haven't read them all.....
    I got away from owning a Gasser for a few years when I owned a Volt, Spark EV and now a Bolt.
    #19 Bill Norton, Dec 30, 2025
  20. BiomedO1
    4,019
    2,109
    SacTown, Ca
    IMHO; If your going to run extended intervals between ATF changes - going with something like D1 or Mobil ATF may be warranted, since they resist thermal break-down better than Toyota WS. I recall a YouTube video where Toyota WS placed pretty low, below Valvoline ATF. I believe D1 came out on top, but it may've been sponsored by Redline.
    If your sticking to 50K-60K replacement intervals, Toyota WS will do fine. I ran my old Prius C for 70K miles on WS, and it came out cleaner than the 20K mile replacement.
    We still don't know if the other stuff will de-laminate the electric winding wires over time. o_O
    Your results may vary.........
