Battery level
Discussion in 'Prius v Technical Discussion' started by bikeboy999, Dec 28, 2025 at 1:47 PM.
Tags:
  1. bikeboy999
    bikeboy999 Junior Member
    46
    Ottawa, Ont.
    2015 Prius v wagon
    from Canada where we get near zero F temps in winter i ran obd2 tester yesterday and it shows 11.3v on battery. It's it time to replace or do I have a year left?
    B
    52,012
    better to get a load test at an auto parts store. how old is it?
    how often do you drive, can you put a maintainer on it?
  3. rjparker
    10,179
    6,332
    If its 11.3v, ten years old and driven every day, a load test will likely fail it. An original ten year old battery should be replaced anyway in my experience.
    If its 11.3v, one year old and driven about once a week, a load test will probably pass. A maintainer would be a good idea.
    If its 11.3v, one year old and driven every day, a load test will likely pass but you may have an excessive parasitic draw.
    So more information gets you a better guess on what the load test may show and then how to proceed.
    #3 rjparker, Dec 28, 2025 at 2:02 PM
    Air_Boss and Brian1954 like this.
  4. Air_Boss
    Air_Boss Senior Member
    4,202
    1,186
    New Yawk
    Are you feeling lucky?
    VelvetFoot likes this.
  5. bikeboy999
    46
    Ottawa, Ont.
    2015 Prius v wagon
  6. bikeboy999
    46
    Ottawa, Ont.
    2015 Prius v wagon
    Yes it's a month shy of 10yrs old. So I guess it's time. At 90k and 10yrs, my maintenance app shows brakes and brake fluid. I guess time for those too.
    B
  7. bisco
    52,012
    the only brake maintenance would be lubricating the slide pins. inspect everything, and replace anything worn beyond spec.
