Battery level
Discussion in 'Prius v Technical Discussion' started by bikeboy999, Dec 28, 2025.
Tags:
  1. bikeboy999
    bikeboy999 Junior Member
    46
    Ottawa, Ont.
    2015 Prius v wagon
    from Canada where we get near zero F temps in winter i ran obd2 tester yesterday and it shows 11.3v on battery. It's it time to replace or do I have a year left?
    B
    52,821
    better to get a load test at an auto parts store. how old is it?
    how often do you drive, can you put a maintainer on it?
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,068
    6,936
    Texas Hill Country
    If its 11.3v, ten years old and driven every day, a load test will likely fail it. An original ten year old battery should be replaced anyway in my experience.
    If its 11.3v, one year old and driven about once a week, a load test will probably pass. A maintainer would be a good idea.
    If its 11.3v, one year old and driven every day, a load test will likely pass but you may have an excessive parasitic draw.
    So more information gets you a better guess on what the load test may show and then how to proceed.
    #3 rjparker, Dec 28, 2025
    Air_Boss and Brian1954 like this.
  4. Air_Boss
    Air_Boss Senior Member
    4,255
    1,195
    New Yawk
    Are you feeling lucky?
    VelvetFoot likes this.
  5. bikeboy999
    46
    Ottawa, Ont.
    2015 Prius v wagon
  6. bikeboy999
    46
    Ottawa, Ont.
    2015 Prius v wagon
    Yes it's a month shy of 10yrs old. So I guess it's time. At 90k and 10yrs, my maintenance app shows brakes and brake fluid. I guess time for those too.
    B
  7. bisco
    52,821
    the only brake maintenance would be lubricating the slide pins. inspect everything, and replace anything worn beyond spec.
    Air_Boss likes this.
  8. Air_Boss
    4,255
    1,195
    New Yawk
    Slide pin maintenance is really important where roads are chemically treated in winter.
  9. VelvetFoot
    VelvetFoot Senior Member
    1,408
    545
    New York State
    2026 Prius
    A ten year old battery, in Ottawas? Wow!
  10. Mendel Leisk
    42,323
    What app is that?
    With our 2010 Prius there was no mention in the Canadian schedule of brake fluid replacement. However as of model year 2014 I noticed it was added, every 48k kms (~30k miles) or 3 years, whichever comes first.
    In the US schedule, general brake inspection (vaguely described but apparently more in-depth than “visual” inspection) is the same interval.
    #10 Mendel Leisk, Dec 29, 2025
