rear defroster fuse location?
Discussion in 'Gen 2 Prius Technical Discussion' started by findlj, Feb 23, 2016.
  1. findlj
    findlj Junior Member
    47
    I'm trying to find the fuse for my rear window defroster. The manual doesn't show it. The fuse panel under the dash on the drivers side doesn't have it marked and the local dealer can't tell me where it is either. They want me to bring it in, of course! ;)
    Anybody know exactly where this fuse is located?
    Thanks for the help, in advance!
    Braveslice likes this.
  2. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
  3. CooCooCaChoo
    CooCooCaChoo Senior Member
    957
    535
    Cow-lee-fornia
    2023 Prius
    Where is this fuse box location? :/
  4. dorunron
    3,318
    1,105
    Houston, TX
    Gen II Fuse Panel is on the lower left hand side of dash. To access the two hidden fuses you have to remove the lower panel which is held in place with screws.
    See this link for more information.
    Cannot find these two fuses | PriusChat
    #4 dorunron, Feb 23, 2016
    HeadOfJarg and Braveslice like this.
  5. koichikitazumi
    koichikitazumi New Member
    Yesterday
    seattle
    I
    Thank you Dorunron! which is the defogger? the green one? also was it easy to remove?
