Gen 4 engine swap worth it?
Discussion in 'Gen 3 Prius Technical Discussion' started by butchbs1985, Oct 25, 2025.
  1. Mendel Leisk
    41,850
    When you enter a zip code, the main Toyota Parts website will display dealerships near you. The link (somewhat subtle) I posted in #13 is to a US dealership website most convenient to me (just over the border in Washington State):: they're price, for the brand-new short block (which WILL have the revised pistons/rings) is $2129~ USD.
    Short Block Assembly #11400-37140 | Autoparts.toyota.com
  2. butchbs1985
    butchbs1985 Taking things apart is fun!
    245
    ChicagoLand
    2013 Prius v wagon
    Yeah. I figured if I'm going that route I may as well do the head assembly too so added that to my cost. This is my point of comparison. Hoping for a call back Monday from Hybridpit too
  3. butchbs1985
    245
    ChicagoLand
    2013 Prius v wagon
    Well I didn't even bother borescoping it. Started it to move into the garage and get sweet white some so... There's for sure an issue as suspected.
  4. Mendel Leisk
    41,850
    As Dylan said, it don' take a weather man, to know which way the wind blows.
  5. George Jung
    George Jung Junior Member
    Las Vegas Nevada
    Ive done gen 4 swap, I wouldnt say i had "no Issues", but after alot of tears everything is working good. I dont have issues with over heating. If i did it again i think i know now how to do it easily. This was the first time I ever attempted a repair like this, In fact this prius is the first car ive ever worked on, and that was just a year ago when i cleaned my egr and air intake. I think i paid like $1300 for it from lkq. I think its a good option, much simpler than buying a new block and switching over the head. Plus my engine was burning a lot of oil and i didnt know if it was the piston rings or the valves causing it.
  6. butchbs1985
    245
    ChicagoLand
    2013 Prius v wagon
    It's been a while but I'm back and I'm seeking help.
    I did end up buying a reman engine from Hybrid Pit and that experience was great!
    Finally got time and warmer weather this weekend so I did the swap which was physically not a terrible process though galvanic corrosion is certainly a thing.
    Today I had help from my brother to get the engine back in and he stuck around and helped reassemble. We got it back together with a couple challenges but eventually fired it up in test mode and.... It started but it wasn't happy. Ran OK with throttle applied.
    Checked codes: code 1 indicated MAF sensor high input. OH Crap. Forgot the connector on the air box.
    Fixed that and fired it up again and it was similarly rough but ran.
    Checked codes: code 2 indicated Manifold pressure high input. Pulled the air box and that sensor wasn't fully clipped.
    Reseated that and test mode again... Now. It turns over then gets slower and quits. Code P3191
    Disconnected 12V just to reset everything and got dinner.
    Tried again after dinner with the same result but didn't check the codes.
    So I'm well aware that two critical systems weren't properly functioning and that's mostly on me. Not to make excuses but the power went out during final assembly and we finished wiht one shop light on the generator. I'm looking for constructive stuff not 'you're a bonehead' because I know that already.
    Other possibly relevant information:
    Before the work, the 12V was dead after sitting for a couple months. It's a nearly brand new Interstate battery but I know my kids left the rear hatch open for quite some time. I noticed that and at the time, the locks at least were still responding. I had a charger on it all day saturday. I have no placed it on a charger again and it's drawing 6A using the under hood terminals.
    Power's back on now (just as I finished wiring up the generator for 12 hour predicted outage...) so here I am trying to unwind.
    Thanks for any direction. My next thoughts are to disconnect the manifold pressure sensor and see if it starts again?
  7. ASRDogman
    ASRDogman Senior Member
    7,788
    3,975
    You are not a bonehead, you had difficult situations when working.
    It is easy to miss something even under ideal conditions. Everyone has done that.
    Go back over EVERYTHING, slowly. Make sure everything is connected. Check the pvc hose,
    that's easy to forget to connect.
    Check for bent pins on the connectors, loose hoses, connections are connected to the correct spot.
    Check that the injectors are fully seated.
    If everything was functioning before the engine swop, it's likely something is not connected correctly.
    When you are certain everything is correct, You can check that the timing is correct for the engine.
    Put the crank at TDC, remove the valve cover gasket and check the timing. If the marks are not on their
    marks, you may have to rotate the engine another turn. The shiny mark likely won't be in there spots,
    butt the cams should.
    I know they do a good job, but they are not perfect, and could have possibly missed it.
    butchbs1985 likes this.
  8. Brian1954
    Brian1954 Senior Member
    2,386
    958
    South Central PA, USA
    As ASRDogman already mentioned, something did not get reconnected properly during the installation of the engine. My first guess would be vacuum hoses. Remove the air box again and check that the 4 to 5 vacuum hoses are all connected. Those hoses seem to be the number one reason why the engine will not start.
    #28 Brian1954, Dec 29, 2025
  9. butchbs1985
    245
    ChicagoLand
    2013 Prius v wagon
    Thanks both. I'll be on it either evenings after work or new years day.
  10. butchbs1985
    245
    ChicagoLand
    2013 Prius v wagon
    You were pretty close with vacuum hose. Hose off the bottom of the purge valve though I'm surprised that's enough to prevent starting.
    To be fair, I do not fully understand that system at this time.
    If wishes a 20 mile test drive with no issues!
    mjoo and Brian1954 like this.
  11. ASRDogman
    7,788
    3,975
    It is very common to miss a vacuum line.
    Glad you got it working.
    It was sucking a lot more air and there wasn't enough fuel.
  12. indel
    indel Member
    267
    87
    Northwest Indiana
    So the problem is solved? Engine running as expected?
  13. Mendel Leisk
    41,850
    By that do you mean hose between PCV valve and intake manifold?
    I've missed that, will shut the engine right down, since it introduces a massive vacuum leak. Very easy to miss during reassemble: the intake manifold goes on, and the loose PCV hose is hiding underneath.
  14. butchbs1985
    245
    ChicagoLand
    2013 Prius v wagon
    Working Great!
    Circled in green (not my photo)
    Mendel Leisk and Brian1954 like this.
  15. Mendel Leisk
    41,850
    It returns gasoline vapours to engine, and yeah, if disconnected a massive vacuum leak.
    Brian1954 and butchbs1985 like this.
