Signs/hints that your hybrid battery was on its last legs
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by rubia, Dec 28, 2025 at 7:17 PM.
  1. rubia
    rubia Junior Member
    35
    Saratoga Springs, NY
    Just curious what peoples' personal experiences were around possible failure of the hybrid battery. What mileage, what was the car doing or not doing, etc. Interested in hearing from those of you who caught it before the red triangle of death and those of you who were, I don't know, running errands or something and then... what? Also, I think it might matter if you live in a cold climate and if that had any effect or not. TIA.
    ETA: Just to be SUPER CLEAR: I am looking for personal experiences and simple language. Did your battery fail? How, when, what were the signs ahead of time or were there no warnings you noticed as a civilian Prius driver and not an amateur mechanic or detective? What's the weather? Not guides, not step-by-step DIY anything. I know there's a lot of knowledge on this site but that is not helpful for me right now.
    #1 rubia, Dec 28, 2025 at 7:17 PM
  2. PriusCamper
    PriusCamper Senior Member
    12,809
    5,193
    Pacific Northwest, USA
    There's so many different scenarios it's hard to say without writing something really long. But basically your charge meter indicating how much battery charge you have barely changes much with a new pack and a realy old pack fluctuates rapidly from full charge to no charge and requires deep cycling to restore capacity. This is a great overview: http://www.hybridautomotive.com/frequently-asked-questions
    You can keep your pack going way longer than the Toyota Dealerships wants you to think... Cleaning the corrosion out and inspecting the pack can help prevent lots of failure points. Also deep cycling the pack every 18 months will keep it lasting way longer.
    The biggest thing people get wrong is trusting a Toyota Stealership or an auto shop that has lots of overhead, both of which will prefer to replace everything with brand new rather than taking care of what you already got to keep costs down.
    Do you or friend or family member have experience working on cars? Because that's going to be the best path forward and PriusChat folks will walk you through all the details.
  3. indel
    indel Member
    143
    52
    Northwest Indiana
    I am very interested in this topic because my battery is in a downward spiral too at 143K. I am now beginning to learn and these are the videos I have watched (or queued up) so far:
    Gregg Festo's introduction to refurbishing a hybrid battery pack with the CQ3 charger:
    Some very ingenious methods to streamline and make the charging efficient by Fix it Fox:
    A three part series on battery charging (step by step), also by Fix it Fox:
    2 years after refurbishing the battery pack, again by Fix it Fox:
  4. Mendel Leisk
    41,545
    Just editorial: what do you mean by “ETA”? Pretty sure not “Estimated Time of Arrival”.
  5. indel
    indel Member
    143
    52
    Northwest Indiana
    The most important parameter I have observed is how fast the battery is replenished and spent while driving. For me, it happens very fast. Hey, the battery was 80% full just a minute ago, now it's down to 20%. This is a classic sign of poor battery health.
    Brian1954 likes this.
  6. BiomedO1
    3,689
    1,914
    SacTown, Ca
    There's no such thing as short-cuts! To nail-down an issue, you need to find anything that can cause that issue and start eliminating each potential issue, one by one - thru testing. Some people here just aim a 'parts cannon' at the car and ask why it doesn't fix their problem. Because they skipped step-one to begin with. IMHO; easy answers is just a guess that someone thinks is a solution. It's up to you to test their solution, because they could be dead wrong - same as some questionable YouTube videos - there are NO editors to validate those findings or conclusions. Telling the most experienced and senior people here; that you don't want to hear from them is questionable at best.
    A one part solution requires some detective work. Those 'mechanics' that just replace parts that the scanner tell them to, will just keep replacing parts and not nail-down the real problem without some detective work. In other words, their fix is just temporary. Those are the cars that keep returning to the mechanic because the same part or something else broke.
    Good Luck.
    #6 BiomedO1, Dec 29, 2025 at 11:14 AM
    indel likes this.
  7. DirkAshburn
    DirkAshburn Member
    151
    63
    Virginia
    Like PriusCamper said it could be many things. In May of 2022 I tested my battery, it was 48% with 137k miles and listed as bad. Soon after I started looking at options for replacement figuring its death was imminent. It's still going 3+ years later. I'm still on the fence on trying the deep cycling vs just replacement.
    BiomedO1 likes this.
  8. BiomedO1
    3,689
    1,914
    SacTown, Ca
    IMHO; deep-cycling will only buy you a year or two - It's not going to magically rejuvenate the pack. You've got gel solidifying and sulfation of the plates in each of those modules.
    Your simply going to get less mpg, until you start getting the death triangle. You just need to figure out if the car is worth putting in a new pack. You already know that the gen3 has the worse reliability track record out of the entire Prius line.
    Good Luck.
  9. rubia
    rubia Junior Member
    35
    Edited to add.
    #9 rubia, Dec 29, 2025 at 3:39 PM
  10. rubia
    rubia Junior Member
    35
    I'm not sure where the confusion is. I'm not looking for short cuts. I'm not asking for solutions. I'm asking about experience. From drivers. That's it.
  11. rubia
    rubia Junior Member
    35
    What are you looking at to determine this?
  12. rubia
    rubia Junior Member
    35
    Is this for me? I'm confused. I don't know what this is referencing or who, or what this even means. This is not an answer to the question I asked.
  13. rjparker
    10,188
    6,336
    When you see a vertical quote bar (in this case by Dirk) followed by a response, the responder is not talking to you. Unfortunately the thread you start does not necessarily stay focused on your questions.
    Step 1
    Fast discharge is a sign of a weak battery and one I saw when my oem pack was going bad. As it progresses you can get to the point where the engine won't stay off during a traffic light stop. That is weaker yet. When it further loses capacity it might be noticeably slower accelerating from a stop. Truly weak results in lower mpg of at least 5 mpg - sometimes 10 mpg.
    All the above without throwing a code or "the red triangle of death".
    Step 2
    Even when it throws a code and lights up the dash, the car will normally still run for a month or more. Your time is short.
    Step 3
    The real problem is when the hybrid battery is so weak (after coding in 95% of the cases) that it can not supply the nominal 201 vdc long enough to spin the engine to a start.
    I elected to change the hv battery after Step 1 had been a concern for two months. I did not want to tear it down and replace bad modules and spend days or weeks of effort.
    Factors Influencing My Decision:
    I did not go refurbished due to poor reliability. I wanted 10 to 12 more years of no battery issues, not 10 to 12 months typical of mix and match refurbs. Refurb guarantees are worthless.
    I did not go with the new aftermarket nimh or lithium modules because the companies selling them were not engineering outfits and relied on beta testers/salesmen like Priuscamper to hype their product for a commission. The aftermarket cells were from China and locally packaged to fit in the existing battery housing. The nimh versions failed in less than two years and the company disappeared. The lithium also failed quickly and some burned. The company and their salesmen denied everything until the day a new sodium version was ready for business. THEN the lithium retrofits were admitted to be flawed. Guarantees on the lithium modules disappeared and were replaced with mildly discounted sodium offers.
    So factory oem was my choice. If serious financial concerns required refurb, I would go that route and save for new oem modules or trade the car.
    #13 rjparker, Dec 29, 2025 at 5:05 PM
    priumium and Winston Smith like this.
  14. indel
    indel Member
    143
    52
    Northwest Indiana
    The battery graphic in the energy monitor screen.
    rubia likes this.
  15. indel
    indel Member
    143
    52
    Northwest Indiana
    Did you do the replacement yourself or let the dealership handle it? How many hours of labor, if the latter?
  16. rjparker
    10,188
    6,336
    An independent did it in 45 minutes. He had already swapped the batteries into a spare housing with wiring, fan and electrical modules. A v is easier access than a hatchback.
    #16 rjparker, Dec 29, 2025 at 5:53 PM
  17. PriusCamper
    12,809
    5,193
    I used to work on lots of packs before I moved on to Lithium and then Sodium packs and I can assure you that deep cycling every 18 months can restore a decade plus old pack back to 96% of brand new, and yes I've compared reconditioned pack to brand new... This can prolong the pack's lifetime up to 5 years longer... But once you get your first failed cell, the other ones aren't far behind and if you don't drive your car near every day then getting an extra 5 years might not be realistic, as packs that last the longest are ones that don't sit around for very long. Battery University | BU-807: How to Restore Nickel-based Batteries
  18. BiomedO1
    3,689
    1,914
    SacTown, Ca
    Sorry; I'm confused. You had $2000.00+ burning a hole in your pocket, so you decided to switch to Lithium. Then you had another $2000.00+, burning another hole in your pocket and replaced it with Sodium. Rather than deep cycling your original traction pack every 18 months, to get 96% of OEM traction pack specs. Why are people buying new traction packs then????
    I used to work on life support systems and was required to change backup batteries at set intervals or when they fail during routine maintenance checks. I used to take a lot of those batteries home for pet projects; if they were at least 85% of factory specifications. I ran them through our battery tester/balancer first. Only about 5% of those batteries would pass that test. The battery tester was programmed for three full discharge and recharge cycles to determine average final results. Green lamp if it passes all three, yellow if it passed two, and red if it failed two or more cycles. A yellow lamp battery had a 50:50 chance of turning green, if you run it again - depending on how far off the first cycle was.
    I always ran new batteries thorough the tester to take them all the way up to a full charge and set the threshold at 95%. Even then I'd get a 1%-3% failure rate. Due to the nature of equipment, everything is over-specs and minimum down-time is over-reported as an extra level of protection and CYA.
  19. PriusCamper
    12,809
    5,193
    Life support system batteries and Toyota Stealership profitering are way different then helping poor people keep their vehicle on the road.
    When Jack first announced his aftermarket packs going into final protoype testing in December 2019 I was super excited and started promoting his work. Then in October 2020 he shipped me two protoypes for winter testing and I gave one to my Gen3 friend in town and put the other one in my daily driver. I did lots of analysis and stress testing for Jack so the packs were free: Dr. Prius Packs Less Than A Year Away? | PriusChat
    After 5+ years that pack is still in my Gen2 daily driver... Just drove 1500 miles to California and back for the holidays with no issue. Jack's lithium packs have never been an issue for my Prius, nor for thousands of others.
    However, as a product their failure rate was too high and almost led to bankruptcy. I installed lots of packs for people who had failures too and felt terrible about it, but I've never had to spend thousands on a new pack of Lithium or NiMH because helping others, often for free, led to me having lots of spare packs for cheap/free.
    On a similar note I helped with a free proto-type testing of a sodium pack Jack sent me, which I put in a friends car because I wanted to see how long the orginal lithium proto-type lasts in my daily driver.
    In general, being on PriusChat everyday has taught me that giving your time to help others free of charge can open lots of doors to paying work as well as a well stocked parts rack, and buying cars as parts cars to eventually fix up and resell. It's changed my way below poverty income to normal poverty level income.
    What's even better my friendship with Jack made it easy to move on from testing and rebuilding NiMH battery packs 4 years ago and I still have the gear to do it, but would rather teach people how to DIY than charge people.
    #19 PriusCamper, Dec 29, 2025 at 8:10 PM
    VelvetFoot likes this.
  20. rubia
    rubia Junior Member
    35
    It hasn't stayed on my question at all. It's been utterly useless, in fact, and very frustrating.
