Signs/hints that your hybrid battery was on its last legs
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by rubia, Dec 28, 2025 at 7:17 PM.
  1. rubia
    rubia Junior Member
    27
    Saratoga Springs, NY
    Just curious what peoples' personal experiences were around possible failure of the hybrid battery. What mileage, what was the car doing or not doing, etc. Interested in hearing from those of you who caught it before the red triangle of death and those of you who were, I don't know, running errands or something and then... what? Also, I think it might matter if you live in a cold climate and if that had any effect or not. TIA.
    ETA: Just to be SUPER CLEAR: I am looking for personal experiences and simple language. Did your battery fail? How, when, what were the signs ahead of time or were there no warnings you noticed as a civilian Prius driver and not an amateur mechanic or detective? What's the weather? Not guides, not step-by-step DIY anything. I know there's a lot of knowledge on this site but that is not helpful for me right now.
    #1 rubia, Dec 28, 2025 at 7:17 PM
  2. PriusCamper
    PriusCamper Senior Member
    12,803
    5,188
    Pacific Northwest, USA
    There's so many different scenarios it's hard to say without writing something really long. But basically your charge meter indicating how much battery charge you have barely changes much with a new pack and a realy old pack fluctuates rapidly from full charge to no charge and requires deep cycling to restore capacity. This is a great overview: http://www.hybridautomotive.com/frequently-asked-questions
    You can keep your pack going way longer than the Toyota Dealerships wants you to think... Cleaning the corrosion out and inspecting the pack can help prevent lots of failure points. Also deep cycling the pack every 18 months will keep it lasting way longer.
    The biggest thing people get wrong is trusting a Toyota Stealership or an auto shop that has lots of overhead, both of which will prefer to replace everything with brand new rather than taking care of what you already got to keep costs down.
    Do you or friend or family member have experience working on cars? Because that's going to be the best path forward and PriusChat folks will walk you through all the details.
  3. indel
    indel Member
    142
    51
    Northwest Indiana
    I am very interested in this topic because my battery is in a downward spiral too at 143K. I am now beginning to learn and these are the videos I have watched (or queued up) so far:
    Gregg Festo's introduction to refurbishing a hybrid battery pack with the CQ3 charger:
    Some very ingenious methods to streamline and make the charging efficient by Fix it Fox:
    A three part series on battery charging (step by step), also by Fix it Fox:
    2 years after refurbishing the battery pack, again by Fix it Fox:
  4. Mendel Leisk
    41,545
    Just editorial: what do you mean by “ETA”? Pretty sure not “Estimated Time of Arrival”.
  5. indel
    indel Member
    142
    51
    Northwest Indiana
    The most important parameter I have observed is how fast the battery is replenished and spent while driving. For me, it happens very fast. Hey, the battery was 80% full just a minute ago, now it's down to 20%. This is a classic sign of poor battery health.
    Brian1954 likes this.
  6. BiomedO1
    3,688
    1,914
    SacTown, Ca
    There's no such thing as short-cuts! To nail-down an issue, you need to find anything that can cause that issue and start eliminating each potential issue, one by one - thru testing. Some people here just aim a 'parts cannon' at the car and ask why it doesn't fix their problem. Because they skipped step-one to begin with. IMHO; easy answers is just a guess that someone thinks is a solution. It's up to you to test their solution, because they could be dead wrong - same as some questionable YouTube videos - there are NO editors to validate those findings or conclusions. Telling the most experienced and senior people here; that you don't want to hear from them is questionable at best.
    A one part solution requires some detective work. Those 'mechanics' that just replace parts that the scanner tell them to, will just keep replacing parts and not nail-down the real problem without some detective work. In other words, their fix is just temporary. Those are the cars that keep returning to the mechanic because the same part or something else broke.
    Good Luck.
    #6 BiomedO1, Dec 29, 2025 at 11:14 AM
    indel likes this.
  7. DirkAshburn
    DirkAshburn Member
    151
    63
    Virginia
    Like PriusCamper said it could be many things. In May of 2022 I tested my battery, it was 48% with 137k miles and listed as bad. Soon after I started looking at options for replacement figuring its death was imminent. It's still going 3+ years later. I'm still on the fence on trying the deep cycling vs just replacement.
    BiomedO1 likes this.
  8. BiomedO1
    3,688
    1,914
    SacTown, Ca
    IMHO; deep-cycling will only buy you a year or two - It's not going to magically rejuvenate the pack. You've got gel solidifying and sulfation of the plates in each of those modules.
    Your simply going to get less mpg, until you start getting the death triangle. You just need to figure out if the car is worth putting in a new pack. You already know that the gen3 has the worse reliability track record out of the entire Prius line.
    Good Luck.
  9. rubia
    rubia Junior Member
    27
    Edited to add.
    #9 rubia, Dec 29, 2025 at 3:39 PM
  10. rubia
    rubia Junior Member
    27
    I'm not sure where the confusion is. I'm not looking for short cuts. I'm not asking for solutions. I'm asking about experience. From drivers. That's it.
  11. rubia
    rubia Junior Member
    27
    What are you looking at to determine this?
  12. rubia
    rubia Junior Member
    27
    Is this for me? I'm confused. I don't know what this is referencing or who, or what this even means. This is not an answer to the question I asked.
  13. rjparker
    10,185
    6,332
    When you see a vertical quote bar (in this case by Dirk) followed by a response, the responder is not talking to you. Unfortunately the thread you start does not necessarily stay focused on your questions.
    Here you say "keep it simple" but the videos you referenced did not keep it simple. So that added confusion to the rest of us.
    Step 1
    Fast discharge is a sign of a weak battery and one I saw when my oem pack was going bad. As it progresses you can get to the point where the engine won't stay off during a traffic light stop. That is weaker yet. When it further loses capacity it might be noticeably slower accelerating from a stop. Truly weak results in lower mpg of at least 5 mpg - sometimes 10 mpg.
    All the above without throwing a code or "the red triangle of death".
    Step 2
    Even when it throws a code and lights up the dash, the car will normally still run for a month or more. Your time is short.
    Step 3
    The real problem is when the hybrid battery is so weak (after coding in 95% of the cases) that it can not supply the nominal 201 vdc long enough to spin the engine to a start.
    I elected to change the hv battery after Step 1 had been a concern for two months. I did not want to tear it down and replace bad modules and spend days or weeks of effort.
    Factors Influencing My Decision:
    I did not go refurbished due to poor reliability. I wanted 10 to 12 more years of no battery issues, not 10 to 12 months typical of mix and match refurbs. Refurb guarantees are worthless.
    I did not go with the new aftermarket nimh or lithium modules because the companies selling them were not engineering outfits and relied on beta testers/salesmen like Priuscamper to hype their product for a commission. The aftermarket cells were from China and locally packaged to fit in the existing battery housing. The nimh versions failed in less than two years and the company disappeared. The lithium also failed quickly and some burned. The company and their salesmen denied everything until the day a new sodium version was ready for business. THEN the lithium retrofits were admitted to be flawed. Guarantees on the lithium modules disappeared and were replaced with mildly discounted sodium offers.
    So factory oem was my choice. If serious financial concerns required refurb, I would go that route and save for new oem modules or trade the car.
    #13 rjparker, Dec 29, 2025 at 5:05 PM
  14. indel
    indel Member
    142
    51
    Northwest Indiana
    The battery graphic in the energy monitor screen.
  15. indel
    indel Member
    142
    51
    Northwest Indiana
    Did you do the replacement yourself or let the dealership handle it? How many hours of labor, if the latter?
  16. rjparker
    10,185
    6,332
    An independent did it in 45 minutes. He had already swapped the batteries into a spare housing with wiring, fan and electrical modules. A v is easier access than a hatchback.
    #16 rjparker, Dec 29, 2025 at 5:53 PM
  17. PriusCamper
    12,803
    5,188
    I used to work on lots of packs before I moved on to Lithium and then Sodium packs and I can assure you that deep cycling every 18 months can restore a decade plus old pack back to 96% of brand new, and yes I've compared reconditioned pack to brand new... This can prolong the pack's lifetime up to 5 years longer... But once you get your first failed cell, the other ones aren't far behind and if you don't drive your car near every day then getting an extra 5 years might not be realistic, as packs that last the longest are ones that don't sit around for very long. Battery University | BU-807: How to Restore Nickel-based Batteries
