Trying to Figure out the name of the GPS Antenna Connector that's connecting to the Radio
Discussion in 'Gen 5 Prius Technical Discussion' started by Dukeasas, Dec 27, 2025 at 1:55 AM.
  1. Dukeasas
    Dukeasas New Member
    United States
    2025 Prius
    LE AWD-e
    IMG_2699.png IMG_2689 (1).png trying to figure out the name of the gps antenna connector that's connected to my 2026 prius head unit, any idea what this is? Also is this the GPS antenna? or is it the black one
  2. VelvetFoot
    VelvetFoot Active Member
    787
    287
    New York State
    2026 Prius
    In my readings on disabling Telematics (DCM), that does look similar to the gps antenna connector on the DCM unit. (I'm leaving as is for now.)
    Perhaps @soft_r knows more about the head unit aspect? It would be interesting to know what you're trying to do. :)
  3. Dukeasas
    Dukeasas New Member
    United States
    2025 Prius
    LE AWD-e
    Hey there! thank you for the information! I am trying to add a gps tracker to my new Prius! I dont want to pay the subscription on the one in market, so I reckon I can probably make one. One thing about those is that the GPS signals are some very weak signals, so I thought there's already a gps antenna poking out of my car so why not use those! My plan right now is to use a splitter, but those connectors don't look like Fakra C or Z to me, and also if the car uses the same antenna for Cellular it probably won't work, I am just looking for options here haha
    #3 Dukeasas, Dec 27, 2025 at 6:07 PM
  4. Dany Dan
    Dany Dan Junior Member
    48
    Québec, Canada
    2024 Prius Prime
    SE
    If that helps.
    Go to page 11 of the pdf.
  5. Dany Dan
    48
    Québec, Canada
    2024 Prius Prime
    SE
  6. Dany Dan
    48
    Québec, Canada
    2024 Prius Prime
    SE
  7. otatrant
    otatrant Active Member
    335
    205
    San Francisco
    2023 Prius Prime
    XSE Premium
  8. Dukeasas
    Dukeasas New Member
    United States
    2025 Prius
    LE AWD-e
    Unfortunately, it doesn't look like any of those :(
  9. otatrant
    335
    205
    San Francisco
    2023 Prius Prime
    XSE Premium
    From the couple pictures you provided it looks like it may be a Sumitomo High Frequency Connector. Here are a couple of screen shots with links to the housing Sumitomo pages where you can view detailed drawings:
    6098-9503
    6098-9506
    If you
