Replacing spark plugs
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by avoice217, Dec 19, 2025.
  1. ASRDogman
    ASRDogman Senior Member
    7,631
    3,929
    You can drain about a half gallon of coolant to a clean container so you can reuse it.
    And the car is NOT running properly if it is only running on the battery.
    You said after you connected the hose, it started running fine.
    But only on the battery?
  2. Brian1954
    Brian1954 Senior Member
    2,262
    896
    South Central PA, USA
    Do not remove the intake manifold or the EGR system! You need to first get the engine running like it was running before you replaced the spark plugs. Working on a different part of the engine will only make things worse. You do not want to go down any more rabbit holes. You seemed to go down many rabbit holes with the Gen 2 that you previously owned.
  3. indel
    indel Member
    150
    53
    Northwest Indiana
    If you don't know when the coolant was changed last, you might as well change it now. Drain coolant before removing EGR parts. But if you don't want to go that route, don't worry about losing too ouch coolant. May be a cup or two will come out of the hoses. Just refill the reservoir to the top line.
  4. Mendel Leisk
    41,556
    And a frenzy of belated and misguided “maintenance” ain’t helping matters. I was thinking to mention the “drain two quarts of coolant into clean container at the outset” ploy (alluded to by @ASRDogman ?), and mention the relevant links in my signature, but maybe it’ll just muddy the waters more.
    OP’s most likely got a blown head gasket. It’d be best to slow down, check that first, preferably by a pro. Or just sell it, move on.
  5. avoice217
    avoice217 Member
    162
    22
    Hey all, so here's a little update. So I do apologize for not reading the messages earlier. I have actually removed the intake manifold as well as the egr pipe. I am currently cleaning the intake manifold and its a good thing that I removed it because the little holes are really clogged up. I bought the brushes from HF and have been using those to clean everything out. The egr pipe just had dust in it (thankfully) and so soon I'll be using parts cleaner to finish that up. However, I'm wondering what all I should use for the small holes in the intake manifold so that I can get the best possible clean on those?
    Everything else on the manifold seems to be fine. Also in terms of the coolant, I've honestly never done a coolant flush on a Prius. However, when I finish getting the intake cleaned up and put back together, then I'll try driving it around. Man just taking it apart took a lot of patience out of me (took around 2 hours to remove the intake). I know I have a bottle of the coolant around somewhere, I just have to go look for it. Hopefully by Friday I can get the intake back in the car.
    By the way Mendel, i've been watching Merv's video about cleaning the intake manifold and apparently the guy appreciates you.
  6. indel
    indel Member
    150
    53
    Northwest Indiana
    You cannot ignore the EGR cooler and the EGR valve. They are critical blockages in addition to the intake.
  7. ASRDogman
    7,631
    3,929
    Are the holes completely blocked? If not, use a .22 cal gun bore brush and a drill.
    With Gunk, the flammable one, not the foamy one, that is useless.
    It cleans them out in seconds. If you aren't going to clean the cooler, don't waste your time
    on the pipe. The EGR Cooler is what clogs.
    Make sure you use the Toyota 50/50 coolant or you could turn whatever is in there to jell....
    Drain it from the radiator. And you might as well drain the inverter coolant also.
    Don't be fooled into believe anything else is "compatible", it really isn't.
    When you refill the coolant, go very very slow, one or two cups at a time. You'll hear it trickle down.
    And it will push the air out. If you go to fast, you'll trap the air.
  8. Mendel Leisk
    41,556
    I would just run a slim brush a bit, give it a squirt of brake cleaner, work it around with the brush. Don't use anything caustic, Oxi-Clean, oven cleaner, lye solution, they'll all react with the embedded metal bits in the intake manifold.
  9. avoice217
    avoice217 Member
    162
    22
    Hey guys, so I just want to clarify something. I completely understand just how crucial the egr valve and the cooler is. I do plan to remove those tomorrow since I won't be working til Friday. Thankfully I can borrow my mom's car on Friday for work. My plan is indeed to clean those out as well.
    I also forgot to mention that I was able to get the small holes unclogged. I just had to be a little more patient with those. Apparently Merv has some special tool available that he was able to put into his drill to make the process that much faster and I don't have that brush tool right now. Also in terms of the coolant, I do plan to ONLY use Toyota because I understand their mixture and willing to invest in that to ensure that the car stays running.
    ASRDogman likes this.
  10. Mendel Leisk
    41,556
    If you drain a couple of quarts of coolant (into a clean container) before disconnecting hoses to the EGR cooler, it's more or less dry, above the waterline. The only other coolant hoses involved are at the throttle body, and they don't actually need to be removed: the throttle body can be lifted off and cleaned right there, and/or tied to the inverter cables.
    When everything's reassembled, just pour that drained coolant back into the reservoir, worked for me.
    Check out the top 2 links in my signature, lots of EGR info. If you're on a phone turn it landscape to see signatures.
    If you think EGR cleaning this late, is going to somehow stop the engine shakes, well what can I say. It's commendable, but you likely will be dealing with head gasket soon. My 2 cents, properly functioning EGR is crucial to head gasket wellness, and that requires cleaning at least every 50k miles.
