Replacing spark plugs
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by avoice217, Dec 19, 2025.
  1. ASRDogman
    ASRDogman Senior Member
    8,018
    4,071
    You can drain about a half gallon of coolant to a clean container so you can reuse it.
    And the car is NOT running properly if it is only running on the battery.
    You said after you connected the hose, it started running fine.
    But only on the battery?
    Seanathon likes this.
  2. Brian1954
    Brian1954 Senior Member
    2,648
    1,057
    South Central PA, USA
    Do not remove the intake manifold or the EGR system! You need to first get the engine running like it was running before you replaced the spark plugs. Working on a different part of the engine will only make things worse. You do not want to go down any more rabbit holes. You seemed to go down many rabbit holes with the Gen 2 that you previously owned.
  3. indel
    indel Member
    283
    89
    Northwest Indiana
    If you don't know when the coolant was changed last, you might as well change it now. Drain coolant before removing EGR parts. But if you don't want to go that route, don't worry about losing too ouch coolant. May be a cup or two will come out of the hoses. Just refill the reservoir to the top line.
  4. Mendel Leisk
    42,237
    And a frenzy of belated and misguided “maintenance” ain’t helping matters. I was thinking to mention the “drain two quarts of coolant into clean container at the outset” ploy (alluded to by @ASRDogman ?), and mention the relevant links in my signature, but maybe it’ll just muddy the waters more.
    OP’s most likely got a blown head gasket. It’d be best to slow down, check that first, preferably by a pro. Or just sell it, move on.
  5. avoice217
    avoice217 Member
    180
    22
    Hey all, so here's a little update. So I do apologize for not reading the messages earlier. I have actually removed the intake manifold as well as the egr pipe. I am currently cleaning the intake manifold and its a good thing that I removed it because the little holes are really clogged up. I bought the brushes from HF and have been using those to clean everything out. The egr pipe just had dust in it (thankfully) and so soon I'll be using parts cleaner to finish that up. However, I'm wondering what all I should use for the small holes in the intake manifold so that I can get the best possible clean on those?
    Everything else on the manifold seems to be fine. Also in terms of the coolant, I've honestly never done a coolant flush on a Prius. However, when I finish getting the intake cleaned up and put back together, then I'll try driving it around. Man just taking it apart took a lot of patience out of me (took around 2 hours to remove the intake). I know I have a bottle of the coolant around somewhere, I just have to go look for it. Hopefully by Friday I can get the intake back in the car.
    By the way Mendel, i've been watching Merv's video about cleaning the intake manifold and apparently the guy appreciates you.
  6. indel
    indel Member
    283
    89
    Northwest Indiana
    You cannot ignore the EGR cooler and the EGR valve. They are critical blockages in addition to the intake.
  7. ASRDogman
    8,018
    4,071
    Are the holes completely blocked? If not, use a .22 cal gun bore brush and a drill.
    With Gunk, the flammable one, not the foamy one, that is useless.
    It cleans them out in seconds. If you aren't going to clean the cooler, don't waste your time
    on the pipe. The EGR Cooler is what clogs.
    Make sure you use the Toyota 50/50 coolant or you could turn whatever is in there to jell....
    Drain it from the radiator. And you might as well drain the inverter coolant also.
    Don't be fooled into believe anything else is "compatible", it really isn't.
    When you refill the coolant, go very very slow, one or two cups at a time. You'll hear it trickle down.
    And it will push the air out. If you go to fast, you'll trap the air.
  8. Mendel Leisk
    42,237
    I would just run a slim brush a bit, give it a squirt of brake cleaner, work it around with the brush. Don't use anything caustic, Oxi-Clean, oven cleaner, lye solution, they'll all react with the embedded metal bits in the intake manifold.
  9. avoice217
    avoice217 Member
    180
    22
    Hey guys, so I just want to clarify something. I completely understand just how crucial the egr valve and the cooler is. I do plan to remove those tomorrow since I won't be working til Friday. Thankfully I can borrow my mom's car on Friday for work. My plan is indeed to clean those out as well.
    I also forgot to mention that I was able to get the small holes unclogged. I just had to be a little more patient with those. Apparently Merv has some special tool available that he was able to put into his drill to make the process that much faster and I don't have that brush tool right now. Also in terms of the coolant, I do plan to ONLY use Toyota because I understand their mixture and willing to invest in that to ensure that the car stays running.
    ASRDogman likes this.
  10. Mendel Leisk
    42,237
    If you drain a couple of quarts of coolant (into a clean container) before disconnecting hoses to the EGR cooler, it's more or less dry, above the waterline. The only other coolant hoses involved are at the throttle body, and they don't actually need to be removed: the throttle body can be lifted off and cleaned right there, and/or tied to the inverter cables.
    When everything's reassembled, just pour that drained coolant back into the reservoir, worked for me.
    Check out the top 2 links in my signature, lots of EGR info. If you're on a phone turn it landscape to see signatures.
    If you think EGR cleaning this late, is going to somehow stop the engine shakes, well what can I say. It's commendable, but you likely will be dealing with head gasket soon. My 2 cents, properly functioning EGR is crucial to head gasket wellness, and that requires cleaning at least every 50k miles.
  11. avoice217
    avoice217 Member
    180
    22
    Hey all, here's my latest update: so unfortunately I've come into the situation where the bolt requiring the e8 socket has broken off. Google says to use penetrating oil and vice grips, but due to the lack of space, I don't really see a way to make the vice grips remove that bolt. Any ideas on how to remove this by chance?
  12. avoice217
    avoice217 Member
    180
    22
    So I was just watching the video on how to replace the head gasket and I learned that I did the process backwards. I just noticed that I was supposed to remove the 12 mm nut before I even try to remove that e8 bolt. In all fairness, the whole area was so dirty that the 12 mm nut looked like it was apart of the engine, so it fooled my eyes. Just a simple mistake.
  13. Mendel Leisk
    42,237
    There's four, E8 studs attaching the EGR system: which one did you break?
    Keep in mind, you can remove the other nuts-on-studs, and perhaps some of the other studs as well, get the valve/cooler assembly off and then deal with the broken stud. FWIW, a lot of DIY'rs remove the stud and nut at #2 location, and never reinstall. You could likely remove the #1 stud/nut combo as well, with no ill effects.
    Again, while cleaning the EGR is commendable, I'd be checking head gasket integrity first.
  14. avoice217
    avoice217 Member
    180
    22
    Hey Mendel, thanks for the diagram. It does look like its the 1st bolt. After further inspection, I haven't even touched the bolts in the back (however that's what I'm currently working on.
    On a side note, I have considered looking into head gasket while the car is still torn apart. My biggest concern is the bolt under the car based on this one video. I'm not sure I have the proper tools to get what looks to be the drive train bolt loosened (of course bare in mind I might be talking about the incorrect bolt to begin with). But ya I'm totally willing to take a look at the head gasket and take a photo of it so that you can see what it currently looks like. Another thing I'm having to figure out is how to get at the 'death bolts' as Youtube likes to call them. I have most of the hoses removed so far and just taking a break because of how much energy its taking out of me.
  15. Seanathon
    Seanathon Junior Member
    27
    Orange, CA
    Every "small update" so far has made me gasp. OP, are you pranking us? If so, bravo. If not, I think you need a hand and you may consider to pause before continuing down the path.
    Okay, that's troubling, it shouldn't shake.
    Good catch, but it doesn't sound like it resolved the problem since it can only run properly on EV?
    This horrified me, I've broken a bolt once and was a whole ordeal.
    I think this should give you pause. Realizing you did it backwards after the fact, means you may needed to prepare more beforehand? I think Mendel's advice is most appropriate here:
    I commend you for working on the car yourself, but I have to say, the updates have kept me on my toes and made me gasp audibly a couple of times. I don't have advice, fortunately I didn't encounter these issues when I did my spark plug change.
    Brian1954 likes this.
  16. Brian1954
    2,648
    1,057
    I tried to warn him in post #22. You should read some of the threads he created when he owned a Gen 2 Prius. I gave him advice in some of those threads. He went down many, many rabbit holes. He is now doing the same thing with his Gen 3 Prius. Some people never learn.
  17. rjparker
    rjparker Tu Humilde Sirviente
    10,958
    6,874
    Texas Hill Country
    I have to agree with Mendel, Brian and Seanathon - stop, answer questions and reconsider the need to do the egr cooler now.
    The egr can be easily blocked and the engine should run fine if the egr is at fault.
    No cost egr block flow test
    At about 10:15 in the video he starts talking about the egr valve letting "air" into the intake manifold. He means exhaust gasses. A blocked egr cooler won't cause death rattle or misfire codes. A sticking open egr valve can cause rough low speed engine operation.
    Finally I have no idea how you are going to get a picture of the head gasket without removing the head. Maybe you mean a borescope inspection of the pistons.
  18. avoice217
    avoice217 Member
    180
    22
    Hey guys, so based on the video, I was right about the intake manifold being the possible primary culprit. So currently I am working on getting it cleaned up as best as possible. So if anything, I do apologize for getting ahead of myself and not reading the comments sooner. Also I noticed, that the pipes coming out of the engine and massively gunked up and I have NO idea how to properly clean those up.
    Also I've given up on trying to remove the egr valve and cooler, so when I get enough $$ saved up, I'll take it to a professional and have them swap out the valve & cooler with one I currently have.
  19. indel
    indel Member
    283
    89
    Northwest Indiana
    What issues are you having removing the valve and cooler? It can be difficult but certainly not worth giving up over.
  20. Mendel Leisk
    42,237
    Possible primary culprit? For what exactly?
    With 197k miles, EGR never touched, engine shakes, you very likely have a blown head gasket. Here comes the broken record:
    While cleaning the intake manifold, and/or EGR compenents is always a good idea, you need to address the head gasket failure first.
    My 2 cents: if you can't manage to remove the EGR components, you'd be way out of your depth DIY'ing the head gasket. Are you making payments on it?
