Hello, I have a 2013 Prius C One about 90k miles that I bought new when it came out. Pretty much no issues just until I start hearing creaking metal sounds from the front and rear as well sometimes when going over bumps and dips, not on highway. I took it in to the dealer to get diagnosed and the main things they mentioned were the front suspension components and a leak near the timing area. I'm not super knowledgeable past basic vehicle things, especially not the mechanical parts/engine, I've just ran a backup camera and head unit and added a cruise control knob. The leak seemed small and doesn't leak to the ground where I park, they recommended to clean it off and use dye to identify the exact issue. They mentioned the sway bar links bearing or bushings or whatever seem done. I believe also the front brake pads, which I thought on these cars should last the life due to the regenerative brakes? I'm just looking for opinions on what actions I should take and advice. I like to DIY as much as I can, I have jacks and most tools but no specialty tools besides a torque wrench if that even counts. I've included the documents and off screen pictures of the relevant images they took during the inspection. The car drives and feels just like it always has, just started hearing the sounds now. They said it's safe to keep driving if I want. Any and all help and insight is appreciated.
you can measure the brake linings yourself, pretty easy. they have warning noisemakers when replacement is needed. ignore the leak, it's the timing chain cover, and a profit center for stealerships. the suspension might need some work if it's bothering you, any unusual wear on the tyres? it might just need new bushings
I'll have to research how to check the front brake linings (same as pads?) I don't believe they are making a warning noise yet. Good to know the leak is not worrying. I don't think the tires have uneven wear either. So I should research the sway bar links bushings replacement? Are they bearings or bushings, I thought something about bearings might have been mentioned as well but don't quote me on that. Anything I should to do get rid of the creaking from the rear? it's not as audible as the front I believe but it's hard to trigger it on command, had trouble reproducing it loudly during a test drive at the dealer. I have seen some things about lubing the components with silicone spray, might that help the creaking sound? Thanks again.
Here are the best images I could get of the front brake pads without having the time to take off the tires. *edit* I noticed that the inspection report says the front brake pads are at 7mm, which according to the infallible chatgpt is plenty good until it gets to 3-4mm. I guess what I measured in the photos is not indicative of the lining thickness.
the pads probably aren't touching the discs. you would need to get a look on the same plane as the disc. i'm not a suspension expert. you could take it to a shop that would make recommendations, and cost, then decide if you want to have a go on your own.
I've changed the struts on a Gen 2 as well as a Gen 3 Prius. There are some differences with your C, but other than the rear struts, I don't think these will be all that different. You're only at 90K miles. Unless you've got a serious problem that needs to be addressed, or you wait until the last instant before mashing the brake pedal for every red light, I wouldn't think you'd have that much wear on the brakes. Having the regenerative braking (which charges the high voltage battery) makes it so that you shouldn't need as much friction (normal) braking. My bet is just cycling through your brake fluid is all you'd need at 90K miles. I had to redo the rear brakes on my Gen 2 because of a small leak in the brake cylinder at just over 200K miles, and there was still plenty of friction material left on the rear as well as the front. There may be a way of changing the brake fluid without, but really that normally takes a scantool that's capable of talking to the ABS computer, not just the main ECU. In the "old days," you could have someone pump the brake pedal while you open and close the bleeder valves at the wheels, but these days, that pisses off the ABS computer. Changing the cabin filter doesn't even require any tools, so watch some YouTube videos (more than one because some of them may not offer the best repair strategy), and you'll save yourself over half of what the dealer wants by doing it yourself. It helps if you have a 10mm wrench or socket to change the engine air filter, but after that, it's the same thing (YouTube). You shouldn't pay a shop that much to change your engine air filter either. Changing the struts is a bit more of a repair. It's a bit easier (and a lot safer) to replace the whole strut/spring assembly rather than changing just the strut part. If you decide to just change the strut part, a lot of auto parts stores will "loan" you a tool to compress the springs. There's no need to buy any specialty tool for the struts. After changing the struts, you should get an alignment. That's the only real specialty tool - the alignment rack. I'll pay for a shop to do that part (that and maybe changing out the brake fluid). After changing the front struts, you'll only be a bit out of alignment, so I've just driven the car a few miles to the alignment shop. That little bit isn't enough to mess up the tires. I wouldn't be driving the car all around town for a few months before getting the front end aligned It's your car, so you get to decide what to do. For my car, if the front struts are failing, I wouldn't think the rear ones aren't that far behind. That's the one thing where your C may be different from the cars I've worked on. If the C is similar to the regular Prius, then the rear struts aren't inside the spring, and you can pretty much just change the strut. The Gen 2 and Gen 3 I've worked on didn't have a small access panels in the interior, so I had to remove the interior trim rear side panels just to get to the upper nuts. Again, watching a couple of YouTube videos to see what you'll have to do is the best plan. If your C has an access panel to get to the top of the rear strut, it would be a much easier repair. For what they quoted you on changing the struts, you could pay for new struts all around for several cars, get the front ends aligned, and buy a scantool (at least the one I got). If I read your original complaint, you heard a noise in the rear, and the shop diagnosed the suspension problems in the front. That doesn't make sense to me, so I'd start by having someone drive the car (10 mph or so) over a small bump while you stand off to the side. Maybe braking while they go by where you're standing in a flat parking lot, too. That way, you can hear where the noises are actually coming from and when. Are the noises coming from the front or the rear? Which side? When you go over a bump, or when you brake?
Ok so I since did a test drive around with the mechanic that inspected it and he helped me to notice the sound coming from the front, I think I just ignored it or thought it was normal because it may have been happening for a long time, just the front sway bar links like when turning over a bump. I tried hard to reproduce the sound from the rear but it's inconsistent but I hear it when I drive around my home there's an intersection with two huge dips and I always hear it going into and out of that. So I guess my current plan of action is to buy a couple sway bar links (probably MOOG) from what I've searched and pop those in and then I assume I need to have the alignment redone or? I will soon need new front tires and I was thinking I would get a couple new ones and rotate them, do they do an alignment automatically when you get a pair of new tires? Right now I don't feel concerned about the front pads because they marked them as 7mm which is supposedly perfectly fine from what I've found. I'm going to try some dry ptfe type teflon spray lubricant on some of the suspension parts instead of the silicone spray some people use because others have said it attracts dust and gunk causing issues... Thanks for the help.
So I replaced the sway bar end links and it somehow still creaking just as loud if not louder somehow. I have PTFE dry lube spray and I’ve read that you can use it to spray where rubber meets metal. Where are the likely bushings or rubber pieces that I need to check next?
Ok so just reporting back with an update… I drove my car around some more the next couple days and No creaking at all that I could reproduce! I guess the end links needed to break in or something?
Creaking and squeaking is usually due to the rubber grommets holding your stabilizer bar or your rotation bearing at the top of your strut tower. Give them a squirt of lubricant and it'll go away for a while.There should be at least 3 rubber bushing holding that bar across the bottom of your car. Also look for rubber bushings in the rear and give them a shot.
