WHich other gen 5 Prius has the same donut wheel bolt pattern so I can buy one?
Discussion in 'Gen 5 Prius Main Forum' started by henry phillips, Dec 29, 2025.
  1. henry phillips
    henry phillips New Member
    lex ky
    Does anyone know Which other toyota as the same Lugnut donut wheel bolt pattern as my gen 5 Prius? I need to buy / order one.
  2. PriusCamper
    PriusCamper Senior Member
    13,055
    5,304
    Pacific Northwest, USA
    Here's a comprehensive list:
    ChatGPT - 5x100 Bolt Pattern Vehicles
    Prodigyplace likes this.
  3. VelvetFoot
    VelvetFoot Active Member
    1,212
    473
    New York State
    2026 Prius
    100? Gen 5, man.
  4. VelvetFoot
    1,212
    473
    New York State
    2026 Prius
    For the OP, there's a thread by @Hammersmith that has a lot of stuff in it. I got the part numbers for a new oem wheel and jack and bought a tire from Tire Rack. A tad more expensive I'm sure.
    You didn't mention your model. I went with putting it in bag with a black winter coat on it behind the passenger seat on my LE. I felt I'd lose trunk space if I put it in the well. AWD and higher end models have a higher deck, so tire in well more doable. Still work to do. :)
    edit: If you wanted to, you could probably fit a full-sized spare in back of the passenger seat.
  5. BiomedO1
    4,129
    2,169
    SacTown, Ca
    Gen5 are NOT 5x100; those are gen4's
    I believe gen5 is 5x114.3 pattern, same as Subaru 5-lugs.
    GcinFl likes this.
  6. Gokhan
    Gokhan Senior Member
    6,533
    2,608
    Paramount CA
    OEM spare tire install | PriusChat
    GcinFl, Gorgonzola and Mendel Leisk like this.
  7. PriusCamper
    13,055
    5,304
    VelvetFoot likes this.
  8. kev604
    kev604 Junior Member
    56
    49
    Vancouver, BC Canada
    2026 Prius Plug-in
    Bolt pattern is 5x114.3 and hub is 60.1 so any wheel with same Bolt pattern and hub that is same size or bigger will fit. Honda and I believe Nissan have the same Bolt pattern. Also be.careful with lug nuts different wheels from different manufacturers and aftermarket wheels use different style of lug nuts so make sure your using lug nuts compatable with those wheels and if the wheel bore is bigger than the hub than using hubcentrc rings is highly recommended.
