red triangle of death—help?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by robodog, Nov 23, 2025.
  1. trsandy2000
    trsandy2000 Junior Member
    29
    I spent today looking over all the connections and testing the relays and the resistors. They all test good and continuity is good. The battery block voltages are all close together at 15.+ volts. The continuity for the orange cables on the battery tested good and they are clean since I just had it out of car and reconditioned it. I inspected the HV wires at the inverter as well as I could and didn't see any corrosion. I tried to get the connector in the front of the inverter pulled to look inside but could not figure out how to do it. I tested the A/C by turning it on and turning up the fan and it was working as far as I could tell. So I am stuck at what to do next. I've thought of just breaking down and installing another HV battery but I'm not sure that is the problem. Any suggestions from anyone?
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,083
    1,995
    NJ-USA
    Again, can you post pics of the HV relays and wiring?
    The ecu actuates the main relay 3 (high current negative) and main relay 1 (low current positive through the resistor).
    If the ecu doesn't detect the correct (high) voltage at the inverter at that time, it sets P3004-131.
    If the voltage is ok, then relay 2 (high current positive) is closed and the car "goes ready".
    Brian1954 likes this.
  3. trsandy2000
    29
    Trying to upload pics but can't seem to get it done. Tried different things but I think I have forgotten how I did it before. I'll get it done.
  4. trsandy2000
    29
  5. trsandy2000
    29
    If you need more I can do that.
    Andy
  6. trsandy2000
    29
    Tonight I came out and took the cover off to test all the modules to find out how much they have dropped since balancing them. They were at 8.1 a few days ago and now they are 7.92. out of curiosity I tried to read the total voltage between the two orange wires going from the hybrid battery up to the inverter. I could not get a reading. I set the volt meter to 600v and put the black lead from the volt meter on a shock bolt for ground and the red lead to the orange cable with the resistor hooked to it. Then I moved the black lead to the other orange cable and still nothing. What am I doing wrong or is the positive side SMR telling me it is bad? The white resistor tests at 20 ohm.i feel like I'm getting closer and that it is something simple that I am doing wrong.
  7. ChapmanF
    18,484
    You should never be able to measure from the high-voltage system to body ground. The high-voltage system is built to be completely isolated from the car's 12-volt electrical system and from body ground. If you were able to get a reading that way, there would be an isolation fault somewhere. The car actively tests for such faults, and will set a P0AA6 trouble code if one is detected.
    Does the dash say READY at this time, or not?
    Only when the car is READY are the main relays closed (conducting). If the car is not READY, then "nothing" is the proper reading to see on the car side of the main relays.
    On the battery side of the main relays, you should see battery voltage, any time the service plug grip is in place.
  8. Brian1954
    Brian1954 Senior Member
    2,385
    958
    South Central PA, USA
    Was the car off when you made the voltage measurements?
  9. trsandy2000
    29
    The car does not say ready yet. The light on the Start button is red, the red triangle is on along with brake , abs, VSC, and check engine light. I put the volt meter leads on the furthest away module on one side and the other on opposite side closest and it read 213v. I pushed the start button to get all the dash lights on and then tried to get volt readings from the hybrid battery but still could not get anything at the orange wires at the relays. I guess I don't understand where to test to find out if the voltage is getting sent to the front.
  10. trsandy2000
    29
    I tried it both ways, off first and then on. I hear the relays clicking.
  11. mr_guy_mann
    4,083
    1,995
    NJ-USA
    Where is the HV battery cable that should go to this post on the relay? HVrelay.jpeg
  12. mr_guy_mann
    4,083
    1,995
    NJ-USA
  13. trsandy2000
    29
    Hmmm. I don't know. I don't remember taking it off. When the temp cable came in I disconnected a cable from the left and the connector from the ECU. There was also a cable that came from the last module and had a flat strap that I hooked under the bolt that held the ECU down. I will go look at it. Could it possibly be the mechanic that "diagnosed" it was a bad hybrid battery took it? I would hate to think that he did. According to your picture that cable comes from left side of the battery pack. What is that cable that goes through the white thing, I don't know what it is called, and hooks to the left relay? I'm sure that when I took the old cables off I just threaded the replacement thru that hole and onto the relay. I'm on my way out to the garage now.
  14. trsandy2000
    29
    Oh my gosh. I feel like a fool. I apologize for even thinking the mechanic didn't leave it in the car. I found a short orange piece of cable underneath other parts on my workbench. I remembered that it goes on the first module and to the relay. I put it on and the car started and although my dash lights are out right now, combo meter problem, I was able to put it into drive and reverse and was able to throttle up in neutral. Now I need to get the dash lights working so I can see the warning lights and get the codes erased. I am sooo close and I have you guys here on Priuschat to thank. If we were in front of each other I would be shaking each of your hands and buying you coffee. I will let you know what happens after I get it all done and seats back in. Thank you all a million times over.
  15. trsandy2000
    29
    Well, even though it started and went into drive and reverse the warning lights were all on except the red triangle. I turned it off and disconnected the ground wire and came back to it 30 minutes later and the dash lights won't come on. I've tried all the hacks that I know to get them to come on and nothing. I'll wait till tomorrow.
  16. mr_guy_mann
    4,083
    1,995
    NJ-USA
    If your instrument panel (speedometer - aka the Combination Meter) won't turn on, the most common cause is a faulty capacitor on the CM circuit board.
    Here is a long thread about repairing it - only if you have good soldering skills.
    https://priuschat.com/index.php?posts/2293037
    Otherwise you can take the CM out and send it to TexasHybridBatteries.com for repair. They also sell exchange units.
