Help with multimeter settings to manually bleed coolant
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Collie, Jan 9, 2026.
  1. Collie
    Collie Junior Member
    Hi! Can anyone help me out? I have a brain injury and it’s hard to digest manuals.
    I’m trying to manually bleed the coolant in my prius as per the instructions in the video linked at about the 1:00-2:00 mark
    I have included a photo of my multimeter held next to the video of his and his settings. I’m lost, can someone circle the proper settings on mine and reupload?
  2. Collie
    He uses a 10amp connection but mine is 15amp, that should be fine right?
    He also says something about continuous mode?
  3. ChapmanF
    18,560
    First double-take: why is there a video saying you need a multimeter to bleed coolant?
    Ok, the video shows using a multimeter as a jumper wire across the CHRS pump relay socket, as a way to get that pump to run without using a scan tool.
    If you don't care about seeing an amps reading while the pump runs, you can do the same thing with a humble jumper wire.
    Collie likes this.
  4. Collie
    Thank you for the reply!
    Got gnarly sparking when trying the jumper wire last time… and since this is the 3rd time replacing the same pump (2 amazon and now OEM) I decided to try this other method I saw him and a toyota tech use.
    The supposed benefit of the multimeter is to be able to supply the approximately 3-5 amps the jumper cable cannot, activating the pump without a need for the car to even be on or in maintenance mode etc.
  5. PriusCamper
    PriusCamper Senior Member
    13,078
    5,306
    Pacific Northwest, USA
    I thought Gen2 Prius engine water pump is belt driven?
  6. Collie
    I’m not mechanically inclined just asking people around here, toyota and watching youtube.
    One thing toyota said is if you use a jumper cable it better be fused…thats probably why I got the sparking last time as I do not own a fused jumper cable, just used a normal one. All the videos I’ve seen where people use a regular jumper you can see a little spark as well.
  7. ChapmanF
    18,560
    Gen 2 Prius has three engine water pumps: the belt-driven one, the electric one that shifts hot coolant in and out of the thermos on shutdown and startup (the "CHRS pump"), and the electric one that circulates coolant through the heater when the engine is off.
    (Of course, none of those three should be confused with the other electric one that's for inverter cooling, and not any part of the engine cooling system.)
    The video shows jumping across the relay socket to run the CHRS pump, in case you think there could be air in the thermos and its part of the flow path.
    If you stuck a humble jumper wire between the same two relay terminal sockets where this guy puts the meter probes, the pump will run, and will draw the same amount of current it would with your multimeter. The multimeter is a current measuring device, not a current limiting device.
    (The multimeter does, though, have a limit to the current it will withstand, which is why you'd have to be sure the probes are in the higher-range sockets on the meter. Exceeding the limit will blow a replaceable internal fuse in a good multimeter, or do something else in a cheap multimeter.)
    Toyota folks can say creative things sometimes. The car already has a fuse for the circuit that you are completing with a wire there.
    I wasn't around to see the sparks that concerned you, but having a fuse in the wire doesn't make sparks not happen. If the pump draws too much current, a fuse will (eventually) blow, but it isn't a current regulating device.
    An electric pump is an inductive load that's likely to show you some nice sparks when you complete and open its circuit. That's just the way of things. Making the connection quickly and surely (rather than bouncing the wire ends around) minimizes the light show. Multimeter probes might have a better shape for making a quick sure connection there, compared to the ends of some random wire.
    If so, you could also use two multimeter probe leads connected together, without a multimeter. :)
    #7 ChapmanF, Jan 9, 2026
    PriusCamper likes this.
  8. Collie
    I’m trying to accomplish the method in this video because the car has other issues and would like to do this without it running.
    Are you saying the pump will run without the car being on like it does in this video by using the multimeter? Thanks for any help
  9. Collie
    Also wanted to add my multimeter is cheapish, but it does have a fuse
  10. ChapmanF
    18,560
    The only difference between a multimeter set for amps stuck between those socket terminals, and a plain wire between the same two terminals, is that the multimeter will show you how much current is going through it, and the wire won't. Everything else that happens will be the same.
    The way you say "the pump" makes me wonder if you're forgetting that the car has three pumps for the engine cooling system. (See post #7.)
    The only pump that guy is running with the multimeter is the one for the coolant heat storage tank (thermos).
    The belt-driven pump only runs when the engine does. No way around that.
    The one for the heater will run if the car is IG-ON, the heater is calling for heat, the engine is stopped, and the coolant is hot. But then again, getting the coolant hot usually involves running the engine.
  11. Collie
    Thanks again for helping out! Ok, so I’ve changed all 3 pumps at this point (OEM Toyota)
    The pump in question is the one you mentioned, the heat storage tank pump. I can’t get the dang thing to kick on in maintenace mode, heater on, you name it. This is kinda my last resort.
    If you look at this new attached image do I look ready for business?
  12. pasadena_commut
    pasadena_commut Senior Member
    2,861
    850
    Southern California
    That relay socket is jumped using the ammeter setting on a multimeter. Ammeter means that it reads current. (Why not Amp Meter? Apparently because it sounded odd to people back in the day.)
    Ammeters can get a little tricky because most multimeters have sockets which must be used for particular ranges, and there is usually fine print concerning usage only found in the manual. The ammeter works by putting current through a device called a shunt, which is just a resistor with very low resistance, then it measures the voltage across the shunt. V/R=I, R is set by which mode/shunt is selected, V it measures, which gives I, the current. The multimeter on the right has a range "A" (no specified value) and 30A (30 amps). The manual for the Innova indicates that it has 3 ranges:
    https://csr.innova.com/Content/Manual/Innova/030412_3340A_93-0067_RevB_English_Final_downloadable.pdf
    (page 6)
    but you can rule out the first two because they are 40 and 400 mA, and the pump will likely exceed that. The 15A socket has a note that it shouldn't be used for more than 15 seconds continuously, and it should rest 15 MINUTES between tests. It also states that the 15A socket is NOT fused and the lower ones are. So using it in those modes would likely blow the fuse inside the multimeter. They can be replaced, but sometimes it is a royal PITA to do so. Aiman's video says to run the pump for not more than 30 seconds - 15 seconds longer than the Innova says is acceptable. In this particular situation I would suggest using that multimeter for 10 seconds in the 15A mode (one lead in the 15A hole, the other in Com(mon) hole, dial turned to 15A) to be sure the current drawn is sane - in this case less than 15A. Then just use a piece of wire to jump the relay for 30s at a time. The only danger would be if the pump shorted out completely during the bleed, which is unlikely. Well, the other danger would be sticking the probes/wire in the wrong socket holes - don't do that, it will almost certainly blow a fuse in the car.
    For whatever its worth, I did this once using a free Harbor Freight multimeter with a 10A range and only rested it a minute or so between 30s bursts, and it survived. (HF has since raised the price on similar multimeters to $4 and downgraded them to 5A DC.)
  13. pasadena_commut
    2,861
    850
    Southern California
    Yes, but read the limitations on that node in my post right before this one.
  14. PriusCamper
    13,078
    5,306
    #14 PriusCamper, Jan 9, 2026
  15. ChapmanF
    18,560
    That's because that pump doesn't kick on in maintenance mode or heater on or what have you. It only comes on for a few seconds, once, before cold-starting the engine if there's hot coolant in the thermos, and again, once, for a few seconds, when you shut the car off, to save hot coolant in the thermos.
    Yes. (Again, the meter isn't doing anything for you there that a simple wire wouldn't, but if you insist on using a meter, the way you've set that up will work.)
    They probably calculated the time limit for a current that is near the 15A maximum. You can probably get away with 3 or 4 amps for longer than that (though the meter vendor might show little sympathy if you don't).
    The factory original radiator has a bleed nipple on its upper left side. That's left side of the car, left when you're facing the same way the car is. If the guy said right, he probably meant your right if you're standing in front of the car looking back at it. But that's not the normal way to use 'left' and 'right' around cars.
    The bleed nipple on the factory radiator has a hex-socket-head bleed valve that's on the top of that corner of the radiator. You can see the guy in the video using a long Allen wrench down through the thoughtfully-provided hole in the core support sheet metal for access to the bleed valve.
    Some aftermarket replacement radiators don't have the bleed nipple or valve at all. I spent like 20 minutes questioning my sanity once when I couldn't find it. Anyway, it turns out even when the radiator lacks that, you still can manage to get the cooling system filled.
  16. Collie
    It
    My bad, it’s the one on the right side of the engine that you put a #6 allen down to open from the top, not the visible one that takes a #10 wrench
  17. Collie
    Allllrighty boys, I’ve got an update.
    I sent it for half a second, coolant went down and pump turned on
    I did have a little spark.
    Chapman, Pasadena, do I need to play with the settings on the meter before starting again? My intention is to leave it plugged in no longer than 10-15 seconds at a time
    I didn’t really comprehend the node stuff to be honest
  18. Collie
    All I did was run it as per the photo, I didn’t adjust nodes or anything else because it went over my head.
    Is that ok? Do I just run it 15 seconds and then not again until 15 minutes pass?
  19. ChapmanF
    18,560
    As has been mentioned a couple times, using the meter for that doesn't accomplish anything different from using a simple wire the same way. The wire doesn't have any settings you have to think about. If you're concerned about how to set the meter, or possibly damaging the meter, the easiest answer is don't use the meter.
  20. PriusCamper
    13,078
    5,306
    I thought there was a bleed valve on heat storage pump thermos? Wouldn't that be better to use?
