Oil marks on dipstick
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by C Clay, Jan 8, 2026 at 11:09 AM.
  1. C Clay
    C Clay Member
    346
    66
    Lexington, KY
    Nothing too important here. Just some conversation. Wonder what these burnt places are on the dipstick. For perspective my car has 360,000 miles and in the last year it has actually stopped burning oil , or I will state I don’t need to add any between 5000 mile changes. I use the restore and protect and everything is going well but I have noticed these burned oil places on the dipstick and I've actually cleaned them off about a month ago and these are new. What do you think this means? Is this normal?
  2. Tombukt2
    13,110
    2,352
    When my persona was doing that that. That crusty shiet on dip was coolant hardening . Smelled like it tasted like it . Coolant that is . And sure enough about 3 weeks later the rattling and HG issues started . That was end of that .
  3. C Clay
    C Clay Member
    346
    66
    Lexington, KY
    I have posted on here that I have had periods of infrequent coolant loss and some knocking. It seemed to happen several days in row- lost maybe several ounces of coolant . Hasn’t done it in a couple of weeks. I did clean the EGR cooler, manifold, replaced PVC. Maybe that helped, I don’t know anymore.
  4. CR94
    CR94 Senior Member
    2,705
    1,177
    Northwestern S.C.
    "Burned"?? Is that stuff easy to wipe off? Could it be from carbon deposits liberated by the Restore and Protect? It might be interesting to see what your oil filter has captured since you started using it.
  5. C Clay
    C Clay Member
    346
    66
    Lexington, KY
    You would have to scrape it off with your fingernail or a plastic scraper or something .
  6. Tombukt2
    13,110
    2,352
    I clean my dipsticks with a Scotch-Brite pad till clean n silver
  7. indel
    indel Member
    176
    64
    Northwest Indiana
    Hey look, Tombukt2 is using punctuation. Yay!
    CR94 likes this.
  8. ASRDogman
    ASRDogman Senior Member
    7,647
    3,936
    If the dipstick is burning, so is the rest of the engine...... :whistle:(y)
    C Clay likes this.
  9. C Clay
    C Clay Member
    346
    66
    Lexington, KY
    I was checking something today and noticed the following:
    When engine is cold- and you release the reservoir cap, there is a hiss as if it is under some amount of pressure. Some of this is normal, or is it?
    I started the car and let it run for a bit - I noticed 2 things I had never noticed before-
    When the gas engine shut off, the engine fan came on for a bit.
    I can hear the water pump running with the gas engine off. The engine temperature, according to my scanner app was only 110%.
    It sounds like a head gasket failure all the way around just wondering about the last two observations? Any thoughts?
  10. Mendel Leisk
    41,629
    Ugh, the plot thickens. Borescope inspection?
    BTW, should 110% read 110C?
  11. CR94
    CR94 Senior Member
    2,705
    1,177
    Northwestern S.C.
    That's how you can have a little heat while stopped with the engine automatically shut off.
  12. C Clay
    C Clay Member
    346
    66
    Lexington, KY
    What do you mean exactly I had just never noticed this when I very first started in the morning. It is unusual anyway just to start the car and then go do other things so maybe it happens and I just don’t notice.
  13. C Clay
    C Clay Member
    346
    66
    Lexington, KY
    110°F, I haven’t done that, that would be easy enough. I assume it is just a sure thing.
  14. Mendel Leisk
    41,629
