Replacing spark plugs
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by avoice217, Dec 19, 2025.
  1. CR94
    CR94 Senior Member
    2,734
    1,193
    Northwestern S.C.
    Couldn't unequal clogging of EGR ports of the manifold be a plausible culprit for "starting to shake while ... accelerating", even if the head gasket is ok?
  2. ChapmanF
    18,429
    As I understand things, shakes on initial startup, after sitting for a while, and quickly clearing up, would cast suspicion on the head gasket.
    Shakes while driving, if they are not present at idle and not present at full throttle, but show up at moderate loads when EGR is used, would cast more suspicion on the manifold EGR passages, and wouldn't be very consistent with a head gasket problem.
  3. avoice217
    avoice217 Member
    177
    22
    Hey guys, let me put everything back together and take it for a drive. I certainly hope that its not the head gasket, but we shall see. I did notice at least 1 of the small holes clogged inside the intake manifold, so tomorrow I'm going to put the intake manifold back into the car and see how things go. I'm also going to inspect the pcv valve while I have to intake manifold out. I did watch a video on how to interpret the sound on that.
  4. ASRDogman
    ASRDogman Senior Member
    7,746
    3,962
    You might as well replace the pcv valve while it's out. It's $10-15 part. And not fun
    to get it with the intake manifold on.....
  5. avoice217
    avoice217 Member
    177
    22
    Hey all, so heres the current situation: I'm working on trying to put the car back together. However, there's a few hoses that I'm not sure of the location. I've tried finding pdf's of diagrams regarding the location and can't seem to find them. As soon as I plug all the hoses back into place, then the rest of the car will get put back together.
  6. avoice217
    avoice217 Member
    177
    22
    Hey all so this is where I am at currently. I've been able to find most of the hose locations. However, I'm having a difficult time finding the hose that goes here.
  7. indel
    indel Member
    255
    Northwest Indiana
    Look for a coolant hose that's hanging unattached.
  8. avoice217
    avoice217 Member
    177
    22
    Yes so for the coolant hose thats hanging unattached, unfortunately I can't seem to find where it's supposed to go. I've looked all around and have no idea where it's supposed to go back to. For the metal pipe that doesn't have a hose attached, the only information I have refers to a half part number, which is 16267. Problem there is that there's many Toyota parts with that first half, so that doesn't help.
  9. indel
    indel Member
    255
    Northwest Indiana
    Can you post a zoom out picture so we can see what the metal tube is attached to? It looks to me like the EGR cooler coolant port. Also, take a look at page#2 of the attached diagram. It might help you figure out what's missing.
    #49 indel, Jan 13, 2026
  10. avoice217
    avoice217 Member
    177
    22
    So based on the diagram that you should, its the larger hose coming out of the egr cooler. However, I'm not getting any help from Google on that.
  11. indel
    indel Member
    255
    Northwest Indiana
    There should be four coolant hoses attached to the cooler. You have one missing. You may have attached it to something else.
  12. avoice217
    avoice217 Member
    177
    22
    As you requested, here's zoomed out photos of those areas.
  13. rjparker
    10,390
    6,506
  14. avoice217
    avoice217 Member
    177
    22
    Hey rjparker, so I looked it up and found the hose. However, the split at the end I honestly dont remember.
  15. avoice217
    avoice217 Member
    177
    22
    Now any ideas where the hose that's connected to the green clamp goes by chance? I've been looking constantly and can't seem to figure out where to put that.
  16. rjparker
    10,390
    6,506
    Looks like bottom reservoir hose to radiator
    #56 rjparker, Jan 13, 2026
  17. avoice217
    avoice217 Member
    177
    22
    Hey all, so possibly my last update. So my mom happens to own the same generation model car, so I was able to remove the engine air filter and assembly in order to understand what's going on with my car. It just happened that I moved the house from that area to the left side so that I could get a better understanding of the car and that's how it messed with my head. Needless to say, I was able to move it back to the other side and it fit into that metal pipe.
    So overall, I'm only missing one hose, which connects the purge control solenoid valve to the metal pipe. The good news is that I was able to get the car off the road (which is short term goal). Now I just need to find a possible new hose for that area and then I'm all set. The hose actually busted on me today.
    I would like to apologize to all those that got nervous about my work. In all fairness, there's no places here in Texas where they can teach someone how to work on a car and thus I had to learn it on my own. If I had to do everything again, I definitely would've just ordered a brand new intake manifold (they're sold on eBay for around $90), but I still would've had to deal with that one dumb hose.
  18. Mendel Leisk
    41,798
    You were ostensibly doing an EGR cleaning? The only coolant hoses you needed to touch were the two at the EGR cooler, and just the cooler ends of those.
    the coolant hoses connecting to the throttle body do NOT need to be disconnected: just unbolt the throttle body with hoses, lift it off, tie it to the adjacent inverter conduit.
    Regarding the myriad hose clamps: they’re largely ineffective at preventing spills. A better ploy is to drain 2 quarts of coolant at the outset, at the radiator drain spigot, into a clean container. This leaves the EGR components high and dry. When done, pour it back into the reservoir, while leaving the engine coolant air vent open till coolant starts coming out (model year 2010~2011), or the topmost cooler hose pulled off, for subsequent years that nixed the vent.
    seriously, have a read through the top two links in my signature. (On a phone turn it landscape to see signatures)
  19. ChapmanF
    18,429
    The subsequent years dropped that vent, and dropped all instructions about using that vent from the repair manual, and did not add any new instruction to pull any hose off or engage in any other new hocus pocus.
    That sequence of events could lead one to suspect that for 2010-11 there was still somebody on the engineering team unconvinced that their new degas-bottle cooling system would self-purge as designed without the extra valve, and that by 2012 experience had allayed that concern.
  20. Mendel Leisk
    41,798
    I changed both coolant circuits last fall, and when refilling engine coolant, I left that vent open with a clear tube attached, both to keep things tidy and to help spot any coolant. It's at a high point of the circuit. Near the end of the fill coolant started coming out, and once it was a steady flow I closed it off.
