Oil marks on dipstick
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by C Clay, Jan 8, 2026.
  1. C Clay
    C Clay Member
    352
    68
    Lexington, KY
    Nothing too important here. Just some conversation. Wonder what these burnt places are on the dipstick. For perspective my car has 360,000 miles and in the last year it has actually stopped burning oil , or I will state I don’t need to add any between 5000 mile changes. I use the restore and protect and everything is going well but I have noticed these burned oil places on the dipstick and I've actually cleaned them off about a month ago and these are new. What do you think this means? Is this normal?
  2. Tombukt2
    13,226
    2,392
    When my persona was doing that that. That crusty shiet on dip was coolant hardening . Smelled like it tasted like it . Coolant that is . And sure enough about 3 weeks later the rattling and HG issues started . That was end of that .
  3. C Clay
    C Clay Member
    352
    68
    Lexington, KY
    I have posted on here that I have had periods of infrequent coolant loss and some knocking. It seemed to happen several days in row- lost maybe several ounces of coolant . Hasn’t done it in a couple of weeks. I did clean the EGR cooler, manifold, replaced PVC. Maybe that helped, I don’t know anymore.
  4. CR94
    CR94 Senior Member
    2,733
    1,193
    Northwestern S.C.
    "Burned"?? Is that stuff easy to wipe off? Could it be from carbon deposits liberated by the Restore and Protect? It might be interesting to see what your oil filter has captured since you started using it.
  5. C Clay
    C Clay Member
    352
    68
    Lexington, KY
    You would have to scrape it off with your fingernail or a plastic scraper or something .
  6. Tombukt2
    13,226
    2,392
    I clean my dipsticks with a Scotch-Brite pad till clean n silver
  7. indel
    indel Member
    251
    78
    Northwest Indiana
    Hey look, Tombukt2 is using punctuation. Yay!
    Cornvalue and CR94 like this.
  8. ASRDogman
    ASRDogman Senior Member
    7,724
    3,960
    If the dipstick is burning, so is the rest of the engine...... :whistle:(y)
    Kasra and C Clay like this.
  9. C Clay
    C Clay Member
    352
    68
    Lexington, KY
    I was checking something today and noticed the following:
    When engine is cold- and you release the reservoir cap, there is a hiss as if it is under some amount of pressure. Some of this is normal, or is it?
    I started the car and let it run for a bit - I noticed 2 things I had never noticed before-
    When the gas engine shut off, the engine fan came on for a bit.
    I can hear the water pump running with the gas engine off. The engine temperature, according to my scanner app was only 110%.
    It sounds like a head gasket failure all the way around just wondering about the last two observations? Any thoughts?
  10. Mendel Leisk
    41,786
    Ugh, the plot thickens. Borescope inspection?
    BTW, should 110% read 110C?
    Cornvalue likes this.
  11. CR94
    CR94 Senior Member
    2,733
    1,193
    Northwestern S.C.
    That's how you can have a little heat while stopped with the engine automatically shut off.
  12. C Clay
    C Clay Member
    352
    68
    Lexington, KY
    What do you mean exactly I had just never noticed this when I very first started in the morning. It is unusual anyway just to start the car and then go do other things so maybe it happens and I just don’t notice.
  13. C Clay
    C Clay Member
    352
    68
    Lexington, KY
    110°F, I haven’t done that, that would be easy enough. I assume it is just a sure thing.
  14. Mendel Leisk
    41,786
    110F is tepid.
  15. Cornvalue
    Cornvalue New Member
    Internet
    Business Ed. Plus
    Who uses Fahrenheit? All hail Celsius.
    Just wipe the dip stick and perhaps you can check the oil pan for residue?
    #15 Cornvalue, Jan 12, 2026
  16. Gokhan
    Gokhan Senior Member
    6,455
    2,578
    Paramount CA
    That is some kind of oil deposit and/or varnish. If there is that much on the dipstick, you can only imagine how much there is in other places in the engine.
    Switch to Valvoline Restore & Protect. It has been proven to work to clean oil and other engine deposits 100%. No one knows how it works, but it is like magic.
  17. ASRDogman
    7,724
    3,960
    NO, it hasn't been proven to work to clean oil or other engine deposits 100%.
    In a clean engine maybe... It's snake oil...
  18. Gokhan
    6,455
    2,578
    Paramount CA
    I have never used it and don’t plan to.
    However, the claims are entirely true, as reported by many owners on BITOG and elsewhere. They used to have a POE- and AN-based version for heavy-duty diesel trucks, but this new general-use version, without a special base oil, works wonders too.
  19. ASRDogman
    7,724
    3,960
    :eek:o_O You've never used it, but you claim it works.....(n)(n)
    I've been using it for 52,000 miles, and it hasn't cleaned out the rings like it claims.
    5000 miles oil changes. I'm still burning oil, a little more than it was.
    So that's proof it doesn't work.
    Several emails, phones calls to valvoline go un-answered. And I know why.....
    The ONLY was to properly clean all the burnt clogged out is taking the engine apart and cleaning it.
    MAYBE, just MAYBE, using it early could possibly you could keep it from gumming up.
    But if you use good synthetic oil and change it often, you won't have the issue.
  20. Gokhan
    6,455
    2,578
    Paramount CA
    OK, I see.
    Perhaps give the POE- and AN-based Valvoline Premium Blue Restore for heavy-duty trucks a try, then, if you can find it. You might be able to find it in truck stops. That thing is incredibly strong. You will also need a special oil filter or change it every few times during the OCI because it will remove so many deposits.
    If your rings are worn, it won’t help you, though.
    https://www.ebay.com/itm/205334737094
    #20 Gokhan, Jan 13, 2026
