rear door won't open from inside
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 310K, Jan 14, 2026 at 12:30 PM.
  1. 310K
    310K Junior Member
    Wisconsin
    The rear passenger door won't open from the inside. Opens fine from outside. Child locks are off.
  2. BiomedO1
    3,798
    1,975
    SacTown, Ca
    More than likely the control rod clip broke off or got dislodged; leading to the rod falling out of place.
    You'll need to remove the door panel to do an inspection. DO NOT roll down that window; you can bend or deform that control rod; if it gets caught in the window mechanism.
    You may also have a defective child lock-out assembly, if the control rod isn't dislodged.
    Good Luck; Hope this helps......
    #2 BiomedO1, Jan 14, 2026 at 2:04 PM
  3. Tombukt2
    13,127
    2,355
    These are cabeled I think no rods.
  4. Tombukt2
    13,127
    2,355
    Actually This would've been a good thing in my world...
