rear door won't open from inside
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 310K, Jan 14, 2026.
  1. 310K
    310K Junior Member
    Wisconsin
    The rear passenger door won't open from the inside. Opens fine from outside. Child locks are off.
  2. BiomedO1
    BiomedO1 Senior Member
    4,635
    2,433
    Left Coast
    More than likely the control rod clip broke off or got dislodged; leading to the rod falling out of place.
    You'll need to remove the door panel to do an inspection. DO NOT roll down that window; you can bend or deform that control rod; if it gets caught in the window mechanism.
    You may also have a defective child lock-out assembly, if the control rod isn't dislodged.
    Good Luck; Hope this helps......
    #2 BiomedO1, Jan 14, 2026
  3. Tombukt2
    Tombukt2 Senior Member
    13,868
    2,520
    Durham NC
    These are cabeled I think no rods.
    BiomedO1 likes this.
  4. Tombukt2
    13,868
    2,520
    Durham NC
    Actually This would've been a good thing in my world...
  5. BiomedO1
    4,635
    2,433
    Left Coast
    Rod or cables, if it's disconnected - it isn't going to work.;)
  6. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    U got 335k miles. Why do u care
