How old is the serpentine belt?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by pasadena_commut, Jan 8, 2026.
  1. pasadena_commut
    pasadena_commut Senior Member
    2,776
    831
    Southern California
    Reviewing the CarFax records for our car from before we bought it, it had:
    75K service, includes "drive belts replaced" Since there is only one belt, it must have been changed. 2012
    90.5K "water pump replaced" 2014
    Both of those were at a Toyota dealer. When they replaced the inverter pump it said that, not "water pump" -presumably "water pump" is the one on the engine.
    So it looks like they changed the serpentine belt at 75K. I would assume that they put a new one on when they changed the water pump, because it would be stupid not to spend the $20 (or whatever it was at the time) since the old belt was already off.
    The car is now at 143K miles. So does the serpentine belt have 68K miles on it or 52.5K miles?
    Hard to inspect this belt, I can only see about 3 inches of it from the top of the car. It is a bit shiny but no cracks visible on the outside. Can't see the inside from there at all. Tried to reach around the water pump from the top to get some fingers on the inside, but couldn't manage it.
  2. pasadena_commut
    2,776
    831
    Southern California
    Took a couple of pictures with the cheap Teslong endoscope. The first picture is from the coaxial camera (looking down, I think on the section where the belt is contacting the pulley on the pump, which is the grey metal above it), the second from the sideways camera (looking up, on the free section of the belt before the tension pulley [I think] before the pump). Lots of cracks but no chunks missing. The belt is about .42" wide, and it looks like around 5 to 6 large cracks per inch. The cracks open up a bit when the belt is on the pump, as that bends the belt backwards slightly. Guess I'll change it when I get back from a visit to the Bay Area. Hopefully it has another 1000 miles or so of life left in it! Also looked around the water pump and there were no signs of a leak, which is consistent with the observed zero coolant loss.
  3. Rennie
    Rennie Junior Member
    Australia
    Wouldn't hurt to replace it. It's pretty easy to do; loosen 14mm pulley bolt (no need to remove) then adjust the pulley up/down with 12mm.
    That said I think my cracked belt lasted for years. When you feel how easy it is to spin that water pump, it's little wonder you can get away with trashy belts for so long. There's no alternator or power steering or A/C compressor to create load in general.
  4. jonsey1886
    jonsey1886 Junior Member
    Roanoke
