broken thermostat bolt
Discussion in 'Gen 3 Prius Main Forum' started by mhdriver, Jan 14, 2026 at 2:02 PM.
  1. mhdriver
    mhdriver Member
    84
    34
    florida
    Yeah, I'd say the epoxy is useless. Calling a mobile welder.
    #21 mhdriver, Jan 16, 2026 at 10:47 PM
  2. douglasjre
    douglasjre Senior Member
    2,194
    730
    Null, NL
    A mechanic has a big mental tool bag of skills. You need to use AI to get a list of the possible methods. Problem is you haven't the muscle memory of any of these skills and you don't have the tools.
    Solutions:
    1. Electromagnetic induction heater: Magnetic Induction Heater Bolt Removal https://a.co/d/0ZqvJ1Y
    2. Weld a nut onto it and use that plus heat
    3. Use grinding wheel to grind bolt flat and used hi carbon steel bits purchase anywhere except harbor freight after using a center punch to drill into that bolt with left-handed drill bits and then an easy out
    4. Cut a piece of aluminum off and TIG weld in other piece of aluminum on drill it and start over
  3. Mendel Leisk
    41,664
    Eric the car guy weighs in:
