HID to LED conversion
Discussion in 'Gen 2 Prius Main Forum' started by Lloyd-ss, Jan 14, 2018.
  1. Classic Car Guy
    Classic Car Guy Active Member
    469
    127
    Northwest, USA
    Can you please provide a good link for this conversion? I also have a 2007 that originally uses a HiD. The car is called 2007 Prius (Not Touring) Pacific Northwest package 6 basically fully loaded with leather seats, JBL system, Navigation, Alarm and HiD. My car has been getting this issue of headlights on and off for a year now and I cant use it at night. I couldn't replace the original because it requires a ballast and the new bulb that will cost over $500 bucks from the dealer. Is this LED a direct replacement bulb? Anything will help and thanks,
    Edited:
    This is my actual car headlight. It has fog lights too below.
    242629_2007_Prius_Specs_highlights.jpg 242631_image9.jpeg 242634_Lights_on.jpg 242632_image11.jpeg
    #141 Classic Car Guy, Jan 2, 2026
  2. outtabounds
    outtabounds Junior Member
    52
    Metairie, LA
    Just checked this. The lights are chopdark on amazon. They hook directly to the two 12v wires and bipass ballast.
  3. outtabounds
    52
    Metairie, LA
    Classic Car Guy likes this.
  4. outtabounds
    52
    Metairie, LA
    Yes it fits in the same slot and mounts fine. Inside the assembly wire the two wires connected to/thur the dust cap and disconnect the ballast completely. I removed the ballast completely and put the seal and metal ballast cover on to seal the hole.
  5. Classic Car Guy
    469
    127
    Northwest, USA
    I'll just go with the LED and get rid of my HiD is it will work. So is this the one?
  6. Lloyd-ss
    Lloyd-ss Member
    92
    89
    Ivy, VA
    Four Touring
    Hello everyone. This is Lloyd-ss, the OP of this thread. Pretty amazing that I did my original hid to led conversion 8 years ago on a 2007 Prius. It had 80k miles then & is now at 140k. I went thru a few different LEDs that worked, but none worked well. I finally converted to a more or less factory halogen set up. The halogens have worked perfectly & the new housings are clear, shiny & new. I am happy.
    But you guys have persevered & succeeded. Kudos to you. LED technology has advanced so much in 8 years & it is fantastic that something is now on the market that doesn't just work, it now works well.
    Excellent job everyone!
    Lloyd
  7. outtabounds
    52
    Metairie, LA
    Yes. I removed the headlight assembly and wired these inside the assembly only 2 wires. Was easier than it seems. Drop the front bumper don't need to fully remove but just enough to get to 3 10mm bolts to remove headlight, then remove the dustcap and wire the 2 wires connected to the bulb directly. I used some of those plastic snap on connectors. Has worked find so far.
  8. Classic Car Guy
    469
    127
    Northwest, USA
    Okay so just to understand on this follow-up on this conversion from your original HiD. The only one you replaced is this LED below and the old HiD housing remains disconnecting the ballast and wiring it the existing 12 volts switched in the steering control .. Is that correct?
    Thanks,
  9. justinaprius
    justinaprius New Member
    It looks like they also sell a $56 D2H version with a blade type plug, but other than that, I cannot tell them apart. The $38 D2H in your screenshot has needle styled connectors. I've never done this before, so just inferring that the needle style plugs are more compatible with the wiring that is on the hard plastic dust cover? Can you share what kind of snap on connectors you used to bridge them together?
  10. Lloyd-ss
    Lloyd-ss Member
    92
    89
    Ivy, VA
    Four Touring
    Read post #3 in this thread. It explains about the connectorization of the 12 volt supply going into the headlight assembly. I looks like the 12 volts terminals coming in from the car are 3/16 male push-on blades. Therefore the wires on the new LED lamps would need to be 3/16 female push-on blades. Changing the type of terminal/pin (round to blade, etc) is pretty easy if you can cut and strip the wire and crimp on a new terminal.
  11. Classic Car Guy
    469
    127
    Northwest, USA
    Okay.. so I already bought the one on the picture but I have a 10 amp Dean connector for RC planes both male and female which I can convert the car easily and hope that would work?
    Thanks....
    Lloyd-ss likes this.
  12. Lloyd-ss
    Lloyd-ss Member
    92
    89
    Ivy, VA
    Four Touring
    Wow, those should definitely work, but I don't know if a humble Prius is worthy of that high level of quality! Just joking, of course, but they look nice!
    As a side note, I have been looking for a "standard" style of low voltage high amperage connectors to use for various projects. But the multitude of choices just confuse me. Has the RC industry settled on a few standard lines of connectors that everybody is using? I have not dabbled in RC enough to know if there is something that plugs into battery packs and motors and controllers, etc., of most manufacturers. Or is it still a crap shoot? Thanks
  13. Classic Car Guy
    469
    127
    Northwest, USA
    The only reason why I'm using the dean style connector. I already have those from my airplane pack supplies. Use this instead which is the XT60 connectors 14 gauge wires. These are better because they are sealed when connected. But you have to solder all 8 wires to your car and quick disconnect. This set is more than enough for what you need to make everything easy for quick connect and disconnect.
    XT60 Link:
    or get it at amazon:
    WOODGUILIN 5 Pairs XT60 Connector Plug XT60 Male and Female Connector Xt60 Connector Adapter Equipped with 10cm 14AWG Cable for Li Battery Connection/Quadcopter/Remote Vehicle/and Model Boat.(xt 60)
  14. Lloyd-ss
    Lloyd-ss Member
    92
    89
    Ivy, VA
    Four Touring
    Perfect! Just what I was looking for! Soldering and shrink sleeve is not an issue at all.
    Thx
  15. Classic Car Guy
    469
    127
    Northwest, USA
    Thank you for posting the LED. I been spinning my head of this for awhile. I don't wanna spend 600 bucks for HiD that will possibly blow up again next 5 years.
    #155 Classic Car Guy, Jan 19, 2026
  16. outtabounds
    52
    Metairie, LA
    They mount exactly like the original. There are two wires that go thru the circluar screw off dustcap. I cut the wires on the inside of the headlight and hard wired them Not the wires in the engine bay. I used Ideal push down wire connectors from lowes but you can connect the wires however. If I can remember I hooked ground to black wire but dont think it matters. I can maybe get a pic of the dust cover. You want the lights with the push pins not the connector. Can prob just push the pins in without cutting wires but i cut the wires and hard wired it.
  17. outtabounds
    52
    Metairie, LA
  18. outtabounds
    52
    Metairie, LA
    Ive seen elaborate cutting and rewiring the car harness wiring on youtube but found none of that is neccessary. This worked for me and I didnt need to mess with car wiring outside of the light assembly.
  19. Classic Car Guy
    469
    127
    Northwest, USA
    Ooops so the LED is polarized if thats correct? I'll just figure out the connectors when I work on it. I still have to finish recharging the hybrid batteries. I have to replace 1 or 2 cell modules.
  20. Lloyd-ss
    Lloyd-ss Member
    92
    89
    Ivy, VA
    Four Touring
    They actually came with instructions! That is unusual but nice.
    I see you also have a few bad battery modules.
    https://priuschat.com/posts/3421121/
    Here is a link to the long process I went thru replacing modules and then the entire batt pack. I learned a lot. But it is still going strong after 2 years.
