Metallic Rattling Noise When ICE Under Load
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by shaltbecome, Jan 23, 2026.
  1. shaltbecome
    shaltbecome New Member
    Louisiana, United States
    Hi all, I recently purchased an 08 Prius with 115k miles. When the ICE is running under load (charging battery or first minute or so during a cold start) there's a metallic rattling noise coming from underneath the car. Does anyone know what would cause this?
    Here's a video of the sound (at 0:56 the noise goes away):
  2. saneesh8
    saneesh8 Member
    215
    53
    Allen, TX
    I think it is normal. Not so loud. Can you record it from the front of the car? Oil level is good? Also only at cold start?
  3. shaltbecome
    Oil level was fine when I bought it. I've changed the oil and it sounds the same. It happens during cold start but I think it may happen anytime the engine is under load such as the hybrid battery charging but I'd have to check to be sure. I recorded another video. This noise isn't really audible until I go under the car at 0:20
  4. Rennie
    Rennie Junior Member
    39
    Australia
    The dzzzzz sound seems normal
    I do detect a little of similar tapping hollow sound that mine makes, though not as bad.
  5. bisco
    52,417
    is it possible they rolled back the odometer?
  6. shaltbecome
    No, according to carfax it had 89k miles in early 2025 so if anything it jumped in miles.
  7. saneesh8
    saneesh8 Member
    215
    53
    Allen, TX
    Any way to put a stethoscope close to the water pump ? Not sure, but can be the sound of the impeller on load?
  8. shaltbecome
    Looked under the car today since I had P0420 and a strong exhaust smell. I found two exhaust leaks - one at the exhaust donut and another where the back of the catalytic converter connects. I also found a few rocks on a bracket near the catalytic converter (didn't take a photo but I think it was unrelated). I watched a few videos of gen 2 cold starts and I think I hear the same sound as my car it just seems to be quieter so maybe the exhaust leak is making it louder?
  9. saneesh8
    saneesh8 Member
    215
    53
    Allen, TX
    I guess fix all of those first and it should take care it.Exhaust leak can make it louder for sure.
