Valvoline Restore & Protect 0w20
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by AzusaPrius, Sep 25, 2024.
  1. johnHRP
    johnHRP Active Member
    645
    189
    KA, DE
    Excel
    @AzusaPrius Any pictures?
  2. AzusaPrius
    AzusaPrius Senior Member
    2,214
    928
    You know I thought about it and its funny, the one time I do not take any, you ask for pictures.
    Nothing new, same filter and fresh oil.
    I only had an itch to take a picture of the magnetic drain plug but I did not have my phone on me and it is 100F outside so I did the slowest oil change ever but made sure to get every drop and was inside the cool house as all the oil drained.
    Ask me in 5,000 miles.....
    johnHRP likes this.
  3. orenji
    orenji Senior Member
    5,887
    3,488
    All big brands will do a good job of protecting and keeping the engine clean. But anyone doing 10k mile oil changes and using 0W-20 is not helping the health of any engine. I personally do 3,000 mile oil changes and use Mobil 1 euro 0W-40. No oil issues and still high MPG.
    Grit likes this.
  4. Jim Swart
    Jim Swart Member
    57
    Portland, OR
    If all big brands did such a good job of keeping an engine clean why was there a need to market an oil like Valvoline Restore and Protect? I think 5,000 mile oil change intervals are much more reasonable than 10,000 mile ones. Doing them at 3,000 is probably even better.
  5. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    A sucker is born every day, especially those who neglected to change oil on time and hoping this oil will undo their procrastination
    ASRDogman and johnHRP like this.
  6. johnHRP
    645
    189
    KA, DE
    Excel
    Any synthetic (group III or IV) engine oils can handle 5000 miles/6 months OCI for most case scenarios. Only some of us can do 10k miles OCI without oil consumptions beyond 200k miles. I also do 5-7k miles interval, depends on my driving conditions. In winter, short trips, I did 5k miles or less, and summer 7k miles. . I changed the oil in November and April .
  7. Tombukt2
    13,155
    2,370
    Is all fine and dandy but in machine shop you learn that metal on metal creates friction and wear metalurgical wear and removal . I don't know if any lubricant that can replace worn away metal so far . They have made some things happen in this area but uhh not really ready for prime time etc . I really haven't been able to create our own personal oil related failure in 47 years of driving not so normally . Welp
  8. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,479
    2,456
    Taylors, SC
  9. johnHRP
    645
    189
    KA, DE
    Excel
    Lake is one of the Oil Geek I am fan of. He does not push any marketing, just educative with science and number. All quantified.
    No one can replaced wear metal parts with anything. The main concept on RP Valvoline is removing varnish and gunk. Additives like ZDDP and MoDTC are bonded to the metals, actually eat the metal a bit and create a hard glassy solid surface, this layer reduce the overal wear because it is replacable and as hard as steel. https://link.springer.com/article/10.1007/s11249-025-01968-3
  10. Tombukt2
    13,155
    2,370
    Yeah right so when you go back and you put in proper rings and have proper sealing etc welp . Generally I had this control in my older Toyz. 22R 3S BEAMS JZ etc no lo tension nonsense poor sealing and all that . This crap was engineered in to try and extract nth degree of mpg . Well in my eyes you've got to know when to say when before the stupidity begins . And apparently.....
    johnHRP likes this.
  11. ASRDogman
    ASRDogman Senior Member
    7,675
    3,945
    It's a scam
    Grit likes this.
  12. AzusaPrius
    2,214
    928
    Ah yes...everything is a scam.
    Jim Swart likes this.
  13. wheelsup
    wheelsup Junior Member
    97
    Raleigh, NC
    Finished my first 5,000 run with R&P. 140k -> 145k. Normally 1/2 to 3/4 oil burned in that time frame, noticed basically no oil loss and engine runs very smooth. Oil that came out was black almost sludge like vs the previous M1 that came out golden brown at the end of the 5,000 miles.
    Oldwolf and Jim Swart like this.
  14. ASRDogman
    7,675
    3,945
    Very low mileage, so very little build up.
    I've done 8 or 9, maybe more oil changes and haven't notice any change.
    Still burning about 1.5-2qts in 5000 miles.
    But it doesn't hurt for you to keep using it. How you drive counts also to how much you burn.
    Grit likes this.
  15. BiomedO1
    3,895
    2,042
    SacTown, Ca
    I would've changed the filter at around 1K-2.5K, since that stuff is knocking a bunch of junk loose. The oil filter bypass valve would've opened, if the filter got clogged - but that would allow all that junk back into the engine. That would/could potentially clog up the VVT system, that's oil pressure driven.
    Just something to keep in mind for the future. YMMV
    FWIW; black engine oil changes are normal on a diesel engine, even with only a few hundred miles on the oil. Chunky and sludge like is NOT normal and has the potential to clog oil passages.
    #35 BiomedO1, Sep 19, 2025
  16. Jim Swart
    Jim Swart Member
    57
    Portland, OR
    Very true.
    ASRDogman likes this.
  17. johnHRP
    645
    189
    KA, DE
    Excel
    Burning rate increase at higher speed significantly. The problem with burning oil to some of the toasted engines are permanent scaring on the cylinder wall, not just a simple stuck rings.
    For those who just in the early stage of oil consumption, cleaning tbe piston rings and islands help with VRP. It is not scam IMO. But some of us just way too late to use it.
    i personally do not use it just because I could not find it in europe yet. But ACEA C5/C6 oil that suitable for diesel and gasoline are always rated up to 20k miles and works well in keeping our Prius engine clean, even for 2010-2014
  18. AzusaPrius
    2,214
    928
    Another round of R&P down another 5,000k miles to go.
  19. Georgina Rudkus
    3,479
    2,456
    Taylors, SC
    I have no need.
    I have a 14 year old Prius v with only 36,000 miles.
    I change oil and filter with 1,000 to 1,500 miles religiously every 6 months.
