locked out of Gen 2!
Discussion in 'Gen 2 Prius Main Forum' started by priusrust, Jan 30, 2026.
  1. priusrust
    priusrust Member
    216
    79
    MA
    Hello!
    Looking for advice. I have a 2004 Prius. I have it stored and sometimes 12 v battery drains and I have to jump start it.
    Don't know if that is the case with this issue, but perhaps so:
    • went to open the door with FOB- got nothing
    • replaced battery in FOB just to make sure that was not issue (still nothing)
    • I removed the hidden physical key in the FOB, and tried to manually unlock the door. When I turned ket to the left, slight "thunk" noises came from inside door (s) [sounded like noise came from back door too, [but not sure]
    • though the 'thunk' noises sounded like door was unlocking, it remained locked.
    I'm baffled. What expected to happen was physical key would unlock door, I'd climb in back and open rear hatch from inside, charge 12 volt, and be good.
    I have AAA, assume they would have a way to open door....but wanted to see if there was anything I was missing. Any help appreciated! [in the future I'll leave one of those trickle chargers on 12 volt].
    Thanks!
    52,286
    Spray some lubricant in the lock mechanism and try the key with pliers, both directions, not too hard!
    PrimeDan and priusrust like this.
  3. ChapmanF
    18,454
    It's weird because you'd like to think leftey-loosey, but turn the key to the right to unlock the door.
    priusrust likes this.
  4. priusrust
    priusrust Member
    216
    79
    MA
    Much thanks Bisco & Chapman!
    Little WD-40 in lock....and Chapman is right, clockwise opens door. Come to find out, the problem is not with drained 12 volt, but worn out casing on the FOB. The plastic is clearly worn, so despite a new FOB battery, the lock/unlock buttons don't work. Checked out Amazon, and found this. Seems to have good reviews....looks like simple operation of transferring FOB innards to new FOB shell. Thoughts welcome.
    bisco and Brian1954 like this.
  5. PriusCamper
    PriusCamper Senior Member
    12,985
    5,281
    Pacific Northwest, USA
    Of course when you turn the top of key in one direction, the bottom of the key goes in the other direction, so it can still be confusing if you don't say counter-clockwise rather than clockwise.
  6. priusrust
    priusrust Member
    216
    79
    MA
    don't follow.....when you turn key to right, top of key goes clockwise, and bottom goes clockwise. am I missing what you said?
  7. Tombukt2
    13,289
    2,397
    I thought you said your buttons didn't work so this is no help no buttons or board the green thing it states so in add. So your existing green board goes in this plastic Black cover so you'll have new cover but no working buttons but it'll look nice . Pay the 425 at dealer programmed ready to go . Or you can mess around with dingbats and save about $75 in a waste about two three days of your time depends on what you'll put up with . Good luck . They're some emulator like remotes folks have gotten to work . Are you SKS?
  8. priusrust
    priusrust Member
    216
    79
    MA
    ok, Im confused. Not sure if SKS. If I use the Amazon FOB shell referenced above, and transfer battery/ circuit board from my current FOB, are you saying the lock/unlock buttons wont work?
  9. pasadena_commut
    pasadena_commut Senior Member
    2,774
    831
    Southern California
    SKS: button on driver's door handle and the car will start without having to put the fob in a slot in the dashboard. SKS always has the 45Ah 12V battery and nonSKS might or might not have the smaller one, as many people have upgraded to the larger battery.
  10. dolj
    dolj Senior Member
    8,524
    4,325
    Wellington, New Zealand
    If you have SKS, you will have the little black buttons on the front door handles and (if stock) a silver Toyota logo on the back of your current fob.
    Tom is making assumptions based on what he thinks you mean by "so despite a new FOB battery, the lock/unlock buttons don't work." The physical lock/unlock buttons on the board are likely fine.
    One last point that no one has mentioned, in addition to transferring the circuit board over, you will need to transfer the RFID chip over as well. The RFID chip is what allows the car to start when you insert the fob in the slot.
  11. Tombukt2
    13,289
    2,397
    I thought you stated that you're unlocking locking buttons on your messed up remote don't work so buying this case won't fix . If you didn't say your buttons aren't working my bad.
  12. ChapmanF
    18,454
    I think that's what Camper was getting at—clockwise always means clockwise, and counterclockwise always means counterclockwise*, but right or left depend on whether you're talking about the top of the key or the bottom of the key.
    OTOH, I don't think I've ever in my life seen anyone say right or left meaning the bottom of the key, so I was pretty sure I knew what you meant.
    * It was tradition at Thanksgiving dinner while I grew up for anyone asking for something to be passed clockwise or counterclockwise to also specify: as viewed from above or from below the table.
    So we could also talk about whether to turn the key clockwise as viewed from outside or counterclockwise viewed from inside the door. We'd just have to hold hands and say grace first.
  13. priusrust
    priusrust Member
    216
    79
    MA
    my nomenclature is likely off. I'll try to be more clear.
    my old, very worn non-SKS FOB :- has new battery, and starts car once inserted in slot. But, does not lock/ unlock car door when buttons are pressed.
    I plan to buy the new Amazon FOB shell and transfer over c.board, battery and chip. With this new case, I'm hoping lock/unlock button function will then work. Does this sound right?
  14. Tombukt2
    13,289
    2,397
    Why would a black outer case make the lil white buttons on green board work again ? Explain that logic please?
  15. lexidium
    lexidium Active Member
    300
    141
    manchester
    If you change the case, don't forget to transfer the chip as well.
    I did this and had to dig out the old case from the refuse.
  16. priusrust
    priusrust Member
    216
    79
    MA
    ok great! your comment pinpointed our communication glitch. I have yet to open case, so am unaware of the white buttons on green board....but I know what to expect now. My attempt at logic: I'm hoping the little white buttons on green board actually do work! ...and that the problem lies with the disintegrating FOB plastic shell. The new case is like $15 ...so not much risk to try. My dad owned the car before me. Toyota snake charmed him multiple times into replacing the whole FOB ($300+) when the plastic case shell became worn out. I'm hoping the white buttons work, that they are just not being properly pressed due to worn FOB shell. That is my attempt to employ pure logic.
  17. pasadena_commut
    2,774
    831
    Southern California
    It's possible that the receiver on the car is busted, and that's why the buttons don't work. Check the relevant fuse?
    Don't know if this is relevant but easy enough to try:
  18. bisco
    52,286
    Congrats on getting in!
  19. Tombukt2
    13,289
    2,397
    He said he put a new battery in all wrong with his is ugly rubber buttons . But he stated the buttons did not work with new battery in old case ? So my logic is a new case cover over old board is moot. Should be able to hold board with battery push white squares and things happen ,?
  20. Tombukt2
    13,289
    2,397
    I thought you said you put a battery in this existing remote with the broken buttons or broken rubbers,???? If that's the case then.? I guess we'll just wait three or four more posts down until you get around to you do realize you have to cut that factory remote apart it do not click like the new in.
