The grim reaper has finally arrived
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 2005prius, Jan 31, 2026.
  1. 2005prius
    2005prius Junior Member
    New York
    Three Touring
    My visions of 300k from the hv battery have been dashed by the untimely appearance of the red triangle of death.P0A80 code.
    I prefer not to replace it in 18 degree weather. How long do I have before I’m calling the hook for a trip back home?
    It’s running through the charging cycles normally
  2. Brian1954
    Brian1954 Senior Member
    2,426
    973
    South Central PA, USA
    What Bluetooth OBD2 dongle are you using with the Dr Prius app? Have you used it previously and seen realistic data with the app, or is this the first time that you used the dongle with the app?
    #2 Brian1954, Jan 31, 2026
  3. 2005prius
    New York
    Three Touring
    It’s some cheap eBay dongle.
    I have used it before, but never snapped what normal operation looked like. I don’t think I saw that much red.
    I’ve used the dongle on my 96 Ram and it gave me codes when I had problems.
    I use Car Scanner app to read the codes.
  4. PriusCamper
    PriusCamper Senior Member
    13,115
    5,317
    Pacific Northwest, USA
    The good news is that your data indicates that you have corrosion in the voltage sensor harness and inside the ECU which is creating signal noise/chaos so the car shut it down. This is a simple clean up job and link to new higher quality voltage sensor harness is in my signature of this post below. I suspect if you get this done right away you'll still have a good chance of making it to 300K miles on your OEM pack.
    hill, 2005prius and bisco like this.
  5. Brian1954
    2,426
    973
    When you see data in the Dr Prius app that is not realistic, like in your screenshot, it means that the problem is the dongle. Buy one of the dongles that is recommended on the Dr Prius website.
  6. PriusCamper
    13,115
    5,317
    My experience is if the dongle is bad it won't connect... But if the dongle gives impossible data from the hybrid battery pack it's corrosion causing signal noise to the point that the battery data is not accurate, but it still stays connected and works fine for non-hybrid battery related features.
  7. Tombukt2
    13,502
    2,429
    Elm 327 purple works perfectly cheap . As mentioned this is a quick cleanup job and you might make it to 400,000 MI because thedata here is fubar
    2005prius likes this.
  8. Brian1954
    2,426
    973
    Ask Jack what he thinks about the screenshot shown in post #1. I think that he will agree with me that the problem is the cheap bluetooth dongle that the OP is using.
  9. 2005prius
    New York
    Three Touring
    Just ordered the dongle recommended on Dr Prius.
    https://a.co/d/dpzIZlR
    it will be a cheap check, and I can use my cheapie in my 96 Dodge just to read codes.
    #9 2005prius, Jan 31, 2026
    Brian1954 likes this.
  10. 2005prius
    New York
    Three Touring
    if I’m going to have to gut my interior, I’m going to update the hardware. I also have to change rear struts, so this was bound to eventually happen.
  11. Tombukt2
    13,502
    2,429
    You don't have to gut anything I only remove rt side trim in qtr. But if you're going to do the rear shocks at the same time just because then you'll have to swing in the other side panel to get it the nut that lets shock lower . You should be able to clean everything up and replace the fubar harness if that's so in bout three hours . Unless you see some very troubling things inside.
  12. pasadena_commut
    pasadena_commut Senior Member
    2,892
    868
    Southern California
    Those numbers are obviously not real. How could the pack possibly sustain a negative voltage of more than 1000V, roughly 4X what it is normally but in the opposite direction?
    As Tom indicated, there is probably an issue with the wiring. Note that the first module has a plausible voltage and none of the subsequent ones do. That suggests a connection problem between the 1st and 2nd modules. Also possible that the dongle is screwy, but both things can be true at the same time.
    Edit: Just noticed the battery temps, those are bogus too. -500F is below absolute zero, I guarantee you that not matter what is wrong with your car, or any car for that matter, no part of it will ever be colder than absolute zero.
    #12 pasadena_commut, Feb 1, 2026
  13. 2005prius
    New York
    Three Touring
    Latest update: plugged in the dongle from the Dr. P site.
    I'm now getting realistic data.
    do I have to get the pay version to reset the code?
  14. Brian1954
    2,426
    973
    There is a problem with one of the two modules that makes up block #6. That is the reason why the voltage of block #6 is lower than the others.
  15. Tombukt2
    13,502
    2,429
    Has anyone looked under hood of ,HV battery yet?
  16. 2005prius
    New York
    Three Touring
    No, not yet. Going to start pulling it apart.
  17. Tombukt2
    13,502
    2,429
    Just info one edge of screws with it sitting on car lift car cover up yep it bent it. What ya see behind facing black cover over orange connections??
  18. 2005prius
    New York
    Three Touring
    Latest update:
    After popping the battery cover, I discovered plenty of corrosion. My new harness annd hardware arrived today, so I’m going to be installing that when the weather warms up next week.
  19. Brian1954
    2,426
    973
    Why do you think the wiring harness and hardware needs to be replaced?
    Based on the Dr Prius screenshot in post #13, you have a bad module in battery block #6 that needs to be replaced. Read post #14.
    Replacing the wiring harness will not fix the problem with the bad battery module.
    #19 Brian1954, Feb 6, 2026
  20. Tombukt2
    13,502
    2,429
    Looks like the battery's been messed with already possibly
