Obtaining inverter coolant temperature via OBD
Discussion in 'Gen 5 Prius Technical Discussion' started by PrimeDan, Feb 3, 2026 at 1:10 AM.
  1. PrimeDan
    PrimeDan New Member
    17
    Philly Suburbs
    2024 Prius Prime
    SE
    Has anyone had success with reading the Gen 5's inverter coolant temperature via OBD?
    I've tried using both OBD Fusion and Car Scanner with a Bluetooth dongle to no avail. I've attached screenshots of all the temperature readings, but nothing related to the inverter is showing. As you can see, I've correctly selected the Prius Prime profile as well, so I'm not sure what else to try.
    I'm stumped!
  2. VelvetFoot
    VelvetFoot Active Member
    1,017
    370
    New York State
    2026 Prius
    You sure?
    In Car Scanner Demo mode just now I got the below.
    Searching on "EV" seems to highlight them.
    edit: I bought the 'pro' version...7 bucks?
    edit2: Not using it for gauges because it seems to suck down the phone battery (just noticed I had GPS on even though permissions off-will try in car later with inverter coolant temp enabled.)
    edit3: Using iPhone
    #2 VelvetFoot, Feb 3, 2026 at 8:40 AM
  3. VelvetFoot
    1,017
    370
    New York State
    2026 Prius
    Inverter temp barely went above ambient.
    Then again, I don’t have cardboard in front of the grille. :)
    #3 VelvetFoot, Feb 3, 2026 at 2:38 PM
  4. VelvetFoot
    1,017
    370
    New York State
    2026 Prius
    And I still think that car scanner is a battery hog.
