Obtaining inverter coolant temperature via OBD
Discussion in 'Gen 5 Prius Technical Discussion' started by PrimeDan, Feb 3, 2026.
  1. PrimeDan
    PrimeDan Junior Member
    25
    16
    Philly Suburbs
    2024 Prius Prime
    SE
    Has anyone had success with reading the Gen 5's inverter coolant temperature via OBD?
    I've tried using both OBD Fusion and Car Scanner with a Bluetooth dongle to no avail. I've attached screenshots of all the temperature readings, but nothing related to the inverter is showing. As you can see, I've correctly selected the Prius Prime profile as well, so I'm not sure what else to try.
    I'm stumped!
  2. VelvetFoot
    VelvetFoot Senior Member
    1,407
    544
    New York State
    2026 Prius
    You sure?
    In Car Scanner Demo mode just now I got the below.
    Searching on "EV" seems to highlight them.
    edit: I bought the 'pro' version...7 bucks?
    edit2: Not using it for gauges because it seems to suck down the phone battery (just noticed I had GPS on even though permissions off-will try in car later with inverter coolant temp enabled.)
    edit3: Using iPhone
    #2 VelvetFoot, Feb 3, 2026
  3. VelvetFoot
    1,407
    544
    New York State
    2026 Prius
    upload_2026-2-3_14-58-30.png Inverter temp barely went above ambient.
    Then again, I don’t have cardboard in front of the grille. :)
    #3 VelvetFoot, Feb 3, 2026
    2023p likes this.
  4. VelvetFoot
    1,407
    544
    New York State
    2026 Prius
    And I still think that car scanner is a battery hog.
  5. PrimeDan
    25
    16
    Philly Suburbs
    2024 Prius Prime
    SE
    Hey there funny guy, yes I still have the cardboard in front of my radiator. (My other thread, for those interested: Cold weather radiator block made of cardboard)
    Back to the topic at hand, I think I figured it out based on your screenshots. I had selected "Prius Prime" where it looks like you have the (more extensive?) "Toyota RAV4 Prime PHEV (2019-present), Prius Prime (2023-present) / Lexus NX450h+ PHEV" profile selected. See below:
    VelvetFoot likes this.
  6. VelvetFoot
    1,407
    544
    New York State
    2026 Prius
    Let me know if you feel if the Car Scanner app consumes a lot of phone battery.
    The OBD Fusion does not, but I don't think anything special is available for Toyota hybrids.
    2023p and PrimeDan like this.
  7. VelvetFoot
    1,407
    544
    New York State
    2026 Prius
    I deactivated all sensors in the profile except inverter coolant.
    Maybe that will improve battery drain.
    2023p likes this.
  8. PrimeDan
    25
    16
    Philly Suburbs
    2024 Prius Prime
    SE
    I haven't noticed any appreciable impact on phone battery life when using Car Scanner. I have an app that detects that sort of thing and it's been silent on the topic.
  9. VelvetFoot
    1,407
    544
    New York State
    2026 Prius
    Interesting. My battery dropped 7% in a 35 minute drive. Disabling profile sensors didn’t seem to help. I phone.
    PrimeDan likes this.
  10. VelvetFoot
    1,407
    544
    New York State
    2026 Prius
    OBD Fusion used less than 1%.
    I’m gonna stick with that for everyday.
  11. PrimeDan
    25
    16
    Philly Suburbs
    2024 Prius Prime
    SE
    Yeah, it strikes me as a more full-featured app as compared to Car Scanner.
