Brake Indicator Lights are On
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Hexanite, Feb 3, 2026.
  1. Hexanite
    Hexanite Junior Member
    Raleigh
    Good evening, all
    I have a 2013 Prius V (pretty sure it is just the Base) with ~ 101,587 miles. I drove to the store and everything was fine. When I got in and started my 2013 Prius V, the brake indicators (Brake, ABS, (!), SS) on the dash were on. I did not notice until after I started driving, so I pulled into the gas station next door. I checked the book. I confirmed that the brake fluid level is between the min and max lines. The emergency brake is disengaged.
    Reluctantly, I drove home. It was only a few miles and I took all back roads.
    A couple things I noticed.
    I would push on the brake one time and it would be pretty soft. After releasing and pushing again, the brake was again solid. After driving for a few seconds, it would replicate. The first press of the brake was always softer than the 2nd/3rd/etc.
    Every 3 seconds, I heard a very faint "brrrrr" coming from the floor around my left foot/knee.
    Any idea what could be wrong? I am fairly handy (changed radiators, brakes, shocks). Is this something you think would be a straight forward fix?
    Thanks!!
  2. rjparker
    10,442
    6,548
    Read codes with a hybrid capable scanner.
    A common failure is the Brake Booster (master cylinder/abs/skid control ecu) which runs about $2400 installed at the dealer.
    There was an extended warranty but it expired at 10 years or 150k miles, whichever occurs first.
    There are plenty of threads on the subject. It results in reduced braking and no regen.
    It is a complex job and requires Techstream bleeding and calibrations after the installation. Trained Toyota techs are paid five hours for the repair.
    Independent hybrid shops get a discount on parts and may do it for much less. However their are no rebuilt or aftermarket parts and used parts are often bad or improperly labeled.
    Codes first.
    #2 rjparker, Feb 3, 2026
  3. ChapmanF
    18,487
    If you don't have a suitable scan tool yet to find out the trouble codes, it is fastest to go ahead and get the codes this way:
    Blink (a/k/a Flash) Codes – How to. | PriusChat
    and post them here. That way, finding out what the trouble is doesn't have to wait while you shop for a scan tool, and you can take your time picking out a tool you can have for next time.
  4. Hexanite
    Raleigh
    Thank you both so much for your help.
    I do not recall (though I may have thought it was a scam/junk mail) ever receiving a letter from Toyota about this issue (as indicated in the pdf linked above).
    I am certain that I have mentioned a "puffing" noise and occasional "spongy-ness" when I depress the brake during services before the 10-year limit at my visits to the dealership (I only go to the Toyota Dealer for service). I was told that was "normal." So, I trust them. AND, Since it was never documented in my history (only available back to 2020?) they cannot do anything about it. I was under the impression that taking my car to the dealer for all services (I bought the car there, new) would help avoid missing things like this.
    I am in NC and called multiple Toyota Dealerships and Independent Shops that work on Hybrids.
    Quotes range from the "come in now and I'll give you a deal price" of $4,467.10 out the door to the "eh...that is going to run you around" $4800 price.
    Now I am stuck. It is a 2013 with 101,600 miles. Is it worth putting nearly $4500 into this car? I thought hybrid batteries last an average of 15 years. So, I could be out a hybrid battery soon.
    I feel like it is time to move on from this car and put the $4500 (and potentially $8K for a new hybrid battery) into a new car.
    Any advice on a path forward?
    Thanks!
  5. BiomedO1
    4,062
    2,136
    SacTown, Ca
    Lots of Prius enthusiast love the Prius V, so if it's in decent shape with all dealership records - I'm sure you could get $3K for it AS-IS on Facebook marketplace of Craig's list. It still runs, just not safe to drive.
    Good Luck.....
  6. ChapmanF
    18,487
    "This issue" sounds singular, but the lights you have come on for around 200 reasons, which is a little too plural to try matching up to any Toyota letter yet. I would want to start by knowing what the trouble codes are.
    Brian1954 likes this.
  7. rjparker
    10,442
    6,548
    Your concern is the brake booster or sensors, not the hybrid battery. While Toyota replaced the Brake Booster and separate Pump, most owners are back running with just the Booster.
    The warranty program covered the brake booster and pump with the right codes in the above pdf. Yours probably never had codes. It is common for the brake booster to slowly degrade and remain safe for years UNTIL it codes.
    Everyone wants to do diy thinking it saves money. First you need a diagnosis. I would let a hybrid shop diagnose. THEN come back for cost saving advice if needed.
    Often calling for prices is the wrong thing to do. Shops hate people price shopping by phone. Visit a hybrid shop in person and ask for help.
    #7 rjparker, Feb 4, 2026
  8. Hexanite
    Raleigh
    Good morning, all!
    Thank you all again for the great advice.
    Well, my dashboard is clear. I got in my car after work yesterday and everything is "fine." Braking normally, dash lights are normal.
    I took it to O'Reilly this morning. They said their code reader works on Toyota Hybrids.
    His report gave a code: C1391 "Abnormal Leak of ACC Press"
    Google indicates that this is a typical code for the brake booster/actuator assembly.
    I think I am going to invest the $4500 into getting it repaired. The O'Reilly guy echoed what Biomed01 said. Since Prius V has been discontinued, it still holds a lot of value and people still want it, especially with "only" 101K on it. It is in pretty good shape. There is a broken vent flap from my clip on phone holder and a small dent above the driver rear wheel (happened in a parking lot about 2 months after I bought it :-(, no one left a note). Other than that, it is in good shape.
    Now, my concern is that I put $4500 into it today and 6 months to 1 year from now, I need a new Hybrid Battery :-(.
    Do you think hybrid battery life is more an aspect of time or mileage? I drive every day, but it is just to work (3 miles away) and stores (3 miles away). So, I drive daily, just not far.
    Thanks, all!
  9. BiomedO1
    4,062
    2,136
    SacTown, Ca
    If the car is more or less a daily driver, I wouldn't expect a traction battery issue - since your working the pack. Parking the car and letting it sit for week, months, or years will kill both batteries and is the worst thing you can do to these cars - that's why I question looking for a low mileage Prius. A purely mechanical car suffers less in storage.
    Has the brake fluid system ever been flushed out or changed? You may want to try that first; if a piece of debris jammed up the valve; preventing it from fully closing - your system could be fine.
    If you ever get a soft pedal, don't panic and start rapidly pumping the brake pedal. That's the redundant backup engineered into that system.
    Good Luck.......
    #9 BiomedO1, Feb 5, 2026
  10. rjparker
    10,442
    6,548
    First having a dealer change both parts is easy and comes with a guarantee. For many that is worth an upcharge of 100% on parts and 50% on labor.
    For me $4500 is too much but to do better, you have to buy the right parts at discount (online Toyota dealers), wait a week and locate a hybrid shop that will let you supply parts (even though they get similar discounts).
    The first is what most people have installed along with a gasket.
    Even if you buy both and pay a shop five hours at $200 an hour you are looking at ~$1400 for parts and $1000 in labor. $2400 and everybody is making good money.
    PS. Last week we had a guy upgrade his gen2 brake booster with a new Toyota part for $800 installed. $500 for the brake booster (he received an additional nationwide holiday discount) and $300 labor at an independent shop. A gen2 is one part and is slightly easier.
    #10 rjparker, Feb 5, 2026
    BiomedO1 likes this.
