Good evening, all I have a 2013 Prius V (pretty sure it is just the Base) with ~ 101,587 miles. I drove to the store and everything was fine. When I got in and started my 2013 Prius V, the brake indicators (Brake, ABS, (!), SS) on the dash were on. I did not notice until after I started driving, so I pulled into the gas station next door. I checked the book. I confirmed that the brake fluid level is between the min and max lines. The emergency brake is disengaged. Reluctantly, I drove home. It was only a few miles and I took all back roads. A couple things I noticed. I would push on the brake one time and it would be pretty soft. After releasing and pushing again, the brake was again solid. After driving for a few seconds, it would replicate. The first press of the brake was always softer than the 2nd/3rd/etc. Every 3 seconds, I heard a very faint "brrrrr" coming from the floor around my left foot/knee. Any idea what could be wrong? I am fairly handy (changed radiators, brakes, shocks). Is this something you think would be a straight forward fix? Thanks!!
Read codes with a hybrid capable scanner. A common failure is the Brake Booster (master cylinder/abs/skid control ecu) which runs about $2400 installed at the dealer. There was an extended warranty but it expired at 10 years or 150k miles, whichever occurs first. There are plenty of threads on the subject. It results in reduced braking and no regen. It is a complex job and requires Techstream bleeding and calibrations after the installation. Trained Toyota techs are paid five hours for the repair. Independent hybrid shops get a discount on parts and may do it for much less. However their are no rebuilt or aftermarket parts and used parts are often bad or improperly labeled. Codes first.
If you don't have a suitable scan tool yet to find out the trouble codes, it is fastest to go ahead and get the codes this way: Blink (a/k/a Flash) Codes – How to. | PriusChat and post them here. That way, finding out what the trouble is doesn't have to wait while you shop for a scan tool, and you can take your time picking out a tool you can have for next time.
