58 mpg On First Tank
Discussion in 'Gen 5 Prius Fuel Economy & Prime EV Range' started by VelvetFoot, Nov 15, 2025.
  1. ColoradoBoo
    ColoradoBoo Senior Member
    1,256
    858
    Monument, Colorado USA
    No, I've heard too many stories of folks "topping off" their tanks which can risk getting gasoline inside the charcoal canister...and it's not cheap getting that replaced.
    I estimate the amount of gas she needs (like 7 gallons) and will turn the auto-fill level from "fast" to "slow" at around 5 gallons to finish it up. Once it clicks, that's it.
  2. HamiltonPrius
    HamiltonPrius Member
    192
    95
    Parts unknown in Virginia
    2026 Prius
    Just a one time thing to see how much gas there is from auto shutoff to overflowing.
    Do you know? If so you can save me the trouble.
    #42 HamiltonPrius, Jan 11, 2026
  3. VelvetFoot
    VelvetFoot Active Member
    1,029
    379
    New York State
    2026 Prius
    No, lol.
  4. Probity
    Probity Junior Member
    Covington LA
    2026 Prius
    @VelvetFoot - a thought just occurred to me - you seem to be getting what I consider to be stellar (at or above EPA estimates) fuel efficiency all things considered (winter in New York). I also remember seeing posts from you mentioning removing the plastic wheel covers and installing wheel center caps sourced from Amazon.
    So - the mpg's you've observed to date - are all those with the plastic aero-wheel covers off? And I "assume" some mix of city/hwy driving?
    I ask because, my daughter in southern California is in the camp of those that don't like the looks of the plastic wheel covers (her comment is "makes it look like a Tesla"), and she prefers the look of the alloy wheels 'hidden' under the wheel covers. I earlier told her that after I drive her LE from Louisiana to Socal I could remove her wheel covers if she wanted but that she might experience a slight drop in overall mpg's. [I shamelessly stole your idea and ordered the exact same wheel center caps off Amazon that you did and also verified they fit, so ready for exposing the alloys].
    So I'd love to be able to tell her it's at least possible from your experience to get at/close to EPA mpg's even with the wheel covers off - but want to make sure that's what you're actually doing.
  5. VelvetFoot
    1,029
    379
    New York State
    2026 Prius
    @Probity , I never removed the wheel covers, except to put on the center caps.
    That must've been somebody else.
    I like the look of the wheel covers.
    One COULD be of the opinion that it makes the rotors appear less tiny, which is also a thing, apparently.. :)
    Tangentially, I recently got the oil changed by the dealer and they may have put in 0W16 instead of 0W8.
    I think I'm getting less mpgs.
    Hard to prove though. :)
    #45 VelvetFoot, Feb 4, 2026 at 8:21 PM
    2023p likes this.
  6. 2023p
    2023p Active Member
    161
    102
    Here
    2023 Prius
    I think similarly about the oil weight, who knows if it alls add up. During my first 10k I think I was averaging about 62.8 mpg , will find out - possibly - next oil change, going to make sure it's 0W8.
    Edit: went back and looked and for the first 4k miles it's was 63.9, sheesh.
    #46 2023p, Feb 5, 2026 at 2:54 AM
    VelvetFoot likes this.
  7. VelvetFoot
    1,029
    379
    New York State
    2026 Prius
    Again, awesome!
    You can do your best, but how do you really know what they put in there?
    MINI(BMW) had a video you could access of the tech's work.
    Then again, they weren't too cheap, and I never used it.
    In this case, I reminded the service writer that spec was 0W8.
    When I got the receipt, it said 0W16 on it.
    They told me the tech wrote down the wrong info.
    I accepted that...trying to keep the Fahrvergnügen feeling going, lol.
    They have a cappuccino machine, after all.
    Next time, at 10k miles, I'll be more vociferous. :)
    PS: Again, excellent recommendation on the seat covers-they holding up great!
  8. Probity
    Covington LA
    2026 Prius
    Thanks for the clarification, I'll reiterate the potential downside and let her decide if form or function is more important.
    I'll find out in a week or so if her local dealer uses 0w-8 or 0w-16, 1st task after my trip is getting a smog test (for the title transfer), 2nd task is oil/filter change, 3rd task is enduring the joys of California DMV antics.
  9. VelvetFoot
    1,029
    379
    New York State
    2026 Prius
    Hey, it's something to do. :)
