58 mpg On First Tank
Discussion in 'Gen 5 Prius Fuel Economy & Prime EV Range' started by VelvetFoot, Nov 15, 2025.
  1. ColoradoBoo
    ColoradoBoo Senior Member
    1,316
    932
    Monument, Colorado USA
    No, I've heard too many stories of folks "topping off" their tanks which can risk getting gasoline inside the charcoal canister...and it's not cheap getting that replaced.
    I estimate the amount of gas she needs (like 7 gallons) and will turn the auto-fill level from "fast" to "slow" at around 5 gallons to finish it up. Once it clicks, that's it.
  2. HamiltonPrius
    HamiltonPrius Active Member
    214
    102
    Parts unknown in Virginia
    2026 Prius
    Just a one time thing to see how much gas there is from auto shutoff to overflowing.
    Do you know? If so you can save me the trouble.
    #42 HamiltonPrius, Jan 11, 2026
  3. VelvetFoot
    VelvetFoot Senior Member
    1,375
    529
    New York State
    2026 Prius
    No, lol.
  4. Probity
    Probity Junior Member
    46
    36
    Covington LA
    2026 Prius
    @VelvetFoot - a thought just occurred to me - you seem to be getting what I consider to be stellar (at or above EPA estimates) fuel efficiency all things considered (winter in New York). I also remember seeing posts from you mentioning removing the plastic wheel covers and installing wheel center caps sourced from Amazon.
    So - the mpg's you've observed to date - are all those with the plastic aero-wheel covers off? And I "assume" some mix of city/hwy driving?
    I ask because, my daughter in southern California is in the camp of those that don't like the looks of the plastic wheel covers (her comment is "makes it look like a Tesla"), and she prefers the look of the alloy wheels 'hidden' under the wheel covers. I earlier told her that after I drive her LE from Louisiana to Socal I could remove her wheel covers if she wanted but that she might experience a slight drop in overall mpg's. [I shamelessly stole your idea and ordered the exact same wheel center caps off Amazon that you did and also verified they fit, so ready for exposing the alloys].
    So I'd love to be able to tell her it's at least possible from your experience to get at/close to EPA mpg's even with the wheel covers off - but want to make sure that's what you're actually doing.
  5. VelvetFoot
    1,375
    529
    New York State
    2026 Prius
    @Probity , I never removed the wheel covers, except to put on the center caps.
    That must've been somebody else.
    I like the look of the wheel covers.
    One COULD be of the opinion that it makes the rotors appear less tiny, which is also a thing, apparently.. :)
    Tangentially, I recently got the oil changed by the dealer and they may have put in 0W16 instead of 0W8.
    I think I'm getting less mpgs.
    Hard to prove though. :)
    #45 VelvetFoot, Feb 4, 2026
    2023p likes this.
  6. 2023p
    2023p Active Member
    165
    107
    Here
    2023 Prius
    I think similarly about the oil weight, who knows if it alls add up. During my first 10k I think I was averaging about 62.8 mpg , will find out - possibly - next oil change, going to make sure it's 0W8.
    Edit: went back and looked and for the first 4k miles it's was 63.9, sheesh.
    #46 2023p, Feb 5, 2026
    VelvetFoot likes this.
  7. VelvetFoot
    1,375
    529
    New York State
    2026 Prius
    Again, awesome!
    You can do your best, but how do you really know what they put in there?
    MINI(BMW) had a video you could access of the tech's work.
    Then again, they weren't too cheap, and I never used it.
    In this case, I reminded the service writer that spec was 0W8.
    When I got the receipt, it said 0W16 on it.
    They told me the tech wrote down the wrong info.
    I accepted that...trying to keep the Fahrvergnügen feeling going, lol.
    They have a cappuccino machine, after all.
    Next time, at 10k miles, I'll be more vociferous. :)
    PS: Again, excellent recommendation on the seat covers-they holding up great!
    2023p likes this.
  8. Probity
    46
    36
    Covington LA
    2026 Prius
    Thanks for the clarification, I'll reiterate the potential downside and let her decide if form or function is more important.
    I'll find out in a week or so if her local dealer uses 0w-8 or 0w-16, 1st task after my trip is getting a smog test (for the title transfer), 2nd task is oil/filter change, 3rd task is enduring the joys of California DMV antics.
    2023p and VelvetFoot like this.
  9. VelvetFoot
    1,375
    529
    New York State
    2026 Prius
    Hey, it's something to do. :)
    2023p likes this.
  10. VelvetFoot
    1,375
    529
    New York State
    2026 Prius
    Filled up second full tank on the Michelin X-Ice's.
    Last time 55.1 mpg, actual.
    This time 56.7.
    It's getting warmer.
    Gokhan likes this.
  11. Probity
    46
    36
    Covington LA
    2026 Prius
    That’s a good number. What tire pressure are you running?
    I finished my Louisiana-California trip a couple weeks ago. Overall was happy with the cumulative mpg (hand-calc 51.6 mpg over 2125 miles before hand-over to daughter). ‘Course I had a lot more temperate weather than you’ve seen.
    Negatives affecting my mpg:
    • In addition to my weight, about 200 lbs of ‘extra’ payload (luggage, tools/other stuff for my daughter, spare tire solution, steel cat converter shield, Torklift EcoHitch receiver).
    • Some (not major) headwinds/cross-winds most of the trip.
    • Almost all interstate highway driving (I-12, I-10), except for short traffic backups in El Paso, Tucson, Phoenix, AZ-CA border.
    • Majority of trip “uphill” (320 miles pre-trip driving around Covington LA @ ~12 ft above SL, ~1200 miles to Continental Divide on I-10 in NM (~4585 ft), downhill ~600 miles to Indio CA (below SL)(last place I gassed up).
    MPG positives:
    • Around 37-38 psi in the stock P195/60R17 tires.
    • Drove around 5 mph under the 80 mph speed limit in west TX (drove the posted speed most other times). Like all vehicles I’ve ever owned, speeds above 70 mph give noticeable mpg reductions.
    • Temperate weather (except for white-knuckle driving in rain storm outside Indio CA, that was nasty).
    Pre-trip, I had 57.9 mpg over the 320 miles I spent putting around Covington, I loved that.
  12. VelvetFoot
    1,375
    529
    New York State
    2026 Prius
    Well.....I started at 42.... Haven't looked lately. 46? lol. I think the sidewall says, 50 max.
    I think that's damn good for the speeds you're going. A lot of flatness, but mountains too.
    When I was 19, I pedaled my bike from Brooklyn, NY, where I lived to Vancouver, BC, along the Trans Canada.
    Prevailing westerlies are real. lol.
    Today was the first time I drove with a window open since I got the car in November. Just the driver's door, and not all the way. Initial impressions are good. I usually don't use A/C around here, but I can see it getting fatiguing on a long trip.
    What's great about this car is the high mileage even when puttering around town.
    I hope your daughter likes it. It is a cool car! :)
  13. VelvetFoot
    1,375
    529
    New York State
    2026 Prius
    Filled up again today. 60.8 mpg actual, still on the X-Ices.
    I'd like to switch over to the Ecopias soon.
    2023p likes this.
  14. VelvetFoot
    1,375
    529
    New York State
    2026 Prius
    Back on the Ecopias.
    Still not summer, lol. It snowed here today.
    63.1 actual
    phasechange and 2023p like this.
  15. 2023p
    2023p Active Member
    165
    107
    Here
    2023 Prius
    Ok, so I had spark plugs replaced (stock OEM new ones) at 90k, also had the oil changed and made sure to put in the 0w8 JASO official oil and OEM filter, went from what initially was 62.8 ish avg mpg that became towards the end of the 90k mile about 59.2 and dropping pretty significantly at that point
    Either way after about 2k miles with the 08w oil and the new sparks average 63 mpg about 60/40 city/hwy Southern West Coast
    This is with the tires swapped into the super meaty Maxlife2 after about 80k on the stock Toyota, yes they lasted that long, crazy) (which I think did drop the mpg a bit nitially
  16. VelvetFoot
    1,375
    529
    New York State
    2026 Prius
    Were they Ecopias that lasted that long?
    The Goodyears brought the mpgs down a little, but then self corrected? Interesting.
    You liking the tires??
    Awesome mileage.
    My mpg-o-meter says ~67 now with maybe 80 miles to go on the tank. I haven't been going on the highway much though.
    I spent some quality time today with my driver's side lower seat cover, lol. It had moved out of place a bit. It's finally warm enough here, in spells at least, to do stuff in the garage.
    My 10,000 mile check is coming up soon. How did you verify the dealer put in the right oil?
    A totally random observation I made today now that it's windows open weather here: The windows are very controllable. Much more so than the MINI I had last.
    2023p likes this.
  17. 2023p
    2023p Active Member
    165
    107
    Here
    2023 Prius
    Bought the JASO Toyota glv 0w8 at the dealer, brought that to indie shop to have done, with the filter. They were the Toyo's, bonkers they lasted so long, every where I read it's 30k - 50k ish, I don't understand what was going on with mine, still had healthy plenty tread left when swapped.
    It seems like the maxlife 2's did come down noticably. Thing is not sure if they corrected or the spark and oil swap did a supreme impact. Leaning toward the sparks and oil. Plus breaking in the max's, but honestly no idea outside or anecdotal.
    Glas you're enjoying!!! I do like the maxlife 2 tires, noticably quieter, at least I think so. Absolutely more tread on them for sure. Hoping they can surpass the Toyo's milage wise hah, incredible initial set of the Toyo's. Enough to go back to them if I start reading people buying a retail pair and them lasting as long as mine did etc. wonder how the max's will be at 40k + if the will be louder and ride rougher. The Toyo's were a treat.
    Next and last thing for a while will be the coolant engine side (not Invertor) exchange. For now, I be decided not to do the Invertor unless a part breaks/seal becomes not sealed. And also transmission fluid, won't be doing that. Wish me luck hah.
    Incredible car, value, aesthetics imo.
  18. 2023p
    2023p Active Member
    165
    107
    Here
    2023 Prius
    But yeah the max's seem to have noticably effected the mpg at first. May have just been accumulative, sparks wear etc not quite positive. But if I had to say, the max tires brought the mpg down from where it was
  19. VelvetFoot
    1,375
    529
    New York State
    2026 Prius
    Filled up just now with 40 miles left, indicated.
    65.3
    A new personal best.
    dicknose and 2023p like this.
  20. VelvetFoot
    1,375
    529
    New York State
    2026 Prius
    Filled up with 50 miles left, indicated.
    68.0
    A new personal best, lol.
    I go to dealer tomorrow for the 10,000 mile thing.
    2023p likes this.
