LiBSU - Redesigning the "Battery Support Unit" to Support Lithium
Discussion in 'Gen 3 Prius Technical Discussion' started by mudder, Jun 7, 2024.
  1. A.J
    A.J Junior Member
    59
    Worldwide
    I really wish this can come to life sooner. Because i need a new battery pack for my Gen 3 and wish to use Lithium if there is a proper solution out there.
    Corvairius likes this.
  2. ASRDogman
    ASRDogman Senior Member
    7,704
    3,955
    You want the Sodium ion battery.
  3. rjparker
    10,346
    6,472
    I would also prefer Mudder's engineered lithium solution over any other new aftermarket pack when it is available.
    Otherwise I would go new oem (which is sometimes available at similar costs as aftermarket) or mix and match used for short term if necessary.
    Corvairius, Mr. F and CR94 like this.
  4. ASRDogman
    7,704
    3,955
    ha ha ha ha ha ha
    redesign the wheel... stay in the past... :rolleyes::rolleyes:o_Oo_O
  5. Rami Boul
    Rami Boul Junior Member
    Jordan
    can you please give information how to decipher these data?
  6. mudder
    mudder Active Member
    272
    372
    Chattanooga, TN
    Not yet... I'll release it eventually, but not anytime soon. For now you'll need to reverse engineer the data structure yourself. My color coding in that image is quite helpful as you begin your journey.
