LiBSU - Redesigning the "Battery Support Unit" to Support Lithium
Discussion in 'Gen 3 Prius Technical Discussion' started by mudder, Jun 7, 2024.
  1. A.J
    A.J Junior Member
    60
    Worldwide
    I really wish this can come to life sooner. Because i need a new battery pack for my Gen 3 and wish to use Lithium if there is a proper solution out there.
    Corvairius likes this.
  2. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    You want the Sodium ion battery.
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,140
    6,985
    Texas Hill Country
    I would also prefer Mudder's engineered lithium solution over any other new aftermarket pack when it is available.
    Otherwise I would go new oem (which is sometimes available at similar costs as aftermarket) or mix and match used for short term if necessary.
    Corvairius, Mr. F and CR94 like this.
  4. ASRDogman
    8,070
    4,092
    ha ha ha ha ha ha
    redesign the wheel... stay in the past... :rolleyes::rolleyes:o_Oo_O
  5. Rami Boul
    Rami Boul Junior Member
    Jordan
    can you please give information how to decipher these data?
  6. mudder
    mudder Active Member
    305
    414
    Chattanooga, TN
    Not yet... I'll release it eventually, but not anytime soon. For now you'll need to reverse engineer the data structure yourself. My color coding in that image is quite helpful as you begin your journey.
  7. mudder
    305
    414
    Chattanooga, TN
    Here's what 12 square inches of cross sectional airflow looks like from the pack bottom:
    LiBSU's pack has 40% more cross sectional airflow than OEM.
    In fact, the OEM air plenum's cross section is only 8 square inches, so that'll be the limiting airflow factor.
    Stencil_Box and NHP10L like this.
  8. mikesozin
    mikesozin Junior Member
    Chattanooga, TN
    I'm just curious, why'd you decide to cram all the components into the OEM metal ECU case, especially since there's so much room on both sides (the red space in the pic)? Plus, you could totally fit all the blocks instead of just one blade (the green space in the pic), and I bet the lithium pack would be way shorter than the stock NiMh. Anyway, I'm super excited to buy your product and I really think you're on the right track!
    mudder likes this.
  9. mudder
    305
    414
    Chattanooga, TN
    Great questions, Mike!
    Several reasons:
    -I wanted to retain the wire harnesses, connectors, and mechanical enclosure in their OEM locations.
    -Simplifies installation and reduces cost.
    -I didn't need additional space.
    -Fun challenge.
    I think you're suggesting placing the BMS computer inside one of the blade widths?
    I didn't explore this idea, primarily because it would require lengthening the OEM wire harness.
    Yes, the 'LiBlade' lithium modules I designed form a pack that is shorter than the OEM blade length, while also delivering more energy than OEM. Specifically, replicating the OEM voltage range leaves QTY7 OEM blade widths empty (~14 cm).
    However, we might as well fill that empty space to increase pack voltage, which will increase power output if we spoof the voltage lower... QTY9 LiBlades yields 72S, but I don't yet know how well the inverter hardware will tolerate that voltage. Certainly the car tolerates 60S and 64S in my testing so far.
    I'm having a good time... can't wait to share more.
    mikesozin and hurricos like this.
  10. mikesozin
    Chattanooga, TN
    I checked, all the wires can easily reach the first blade's space. Maybe later you'll add more features like grid charging, etc., and this space could be useful. Plus, it'll get extra airflow from the main fan.
    By the way, I saw around 270v on the battery sometimes during braking.
    mudder likes this.
  11. mudder
    305
    414
    Chattanooga, TN
    I like the concept of a complete pack that doesn't require a separate computer and cable (in the BSU's OEM enclosure). This streamlines some of the annoyances involved with the existing BSU enclosure.
    Probably (edit: no, definitely) worth re-investigating on my end.
    Thanks for the tip/concept.
    With a "BMS blade" in slot 1, I could change from:
    -"external modular expansion via ribbon cables", to;
    -"internal modular cards that insert into said BMS blade".
    This is probably due to high NiMH pack ESR. For example, a pack with 500 mOhm ESR would increase 30 volts during 60 amp regen. In general, the Gen3 Prius tries to keep the pack below 240 volts.
    #111 mudder, Feb 18, 2026
  12. mikesozin
    Chattanooga, TN
    I tested this NMC battery pack from a Hyundai Sonata for a week. It runs great. It's a little higher than the stock battery, but super cheap on the marketplace. Plus it easy to convert to Prius battery. 20260217_102925.jpg
  13. mudder
    305
    414
    Chattanooga, TN
    Very neat fitment. What to the cell voltage taps look like on that Sonata pack? Is there a wire harness, or would LiBSU need ring terminals to attach to each cell?
    mikesozin likes this.
  14. mikesozin
    Chattanooga, TN
    So, each module has a BMS control connection. The nominal voltage is 30v. You'll need 7 modules to match the original 28 Toyota cells. I think it's possible to make adapters for the original Hyundai package.
    Stencil_Box and Corvairius like this.
  15. mudder
    305
    414
    Chattanooga, TN
    Sounds like there's QTY8 cells per connector. If so, you're in luck because each LiBSU BMS PCB measures QTY8 lithium cells. Right now I'm planning on using QTY8 modules, for a total of QTY64 lithium cells. That'll yield a higher voltage than OEM, so LiBSU will report a lower pack voltage to the main hybrid computer, thus yielding more power than OEM. QTY7 modules is closer to OEM pack voltage, and will work, too... just not as much fun because you don't get more power that way.
    Note that I also have designs for QTY12 cells/PCB, QTY6 cells/PCB, and QTY18 cells/PCB...
    ...but will only initially offer BMS PCBs that measure QTY8 cells. The architecture allows you to mix and match BMS PCBs (e.g. you could use four QTY12 cell BMS PCBs and one QTY8 cell BMS PCB). LiBSU can theoretically auto-detect your hardware configuration, but I doubt I ever write the firmware to do that.
    #115 mudder, Mar 1, 2026
    Stencil_Box, mikesozin and Corvairius like this.
  16. mudder
    305
    414
    Chattanooga, TN
    Blade Mechanical prototypes worked out well. Need to make some minor changes before posting more.
    Here's what a safe 8 channel per-cell lithium BMS looks like:
    Speed holes allow increased airflow.
    Tetris pieces are doing the heavy lifting here.
  17. hurricos
    hurricos Junior Member
    74
    24
    Burlington, Vermont
    Are you concerned at all about the tetris silkscreen being damaged during installation? :giggle:
  18. mudder
    305
    414
    Chattanooga, TN
    I worry that one day I might orient the pieces horizontally, thus causing that all-too-familiar line clear. Wish me luck this never happens, because it would end the project immediately... these pieces take too much time to design for them to just willy-nilly disappear. I haven't fully decompiled the source code yet to determine how much leeway I have before the algorithm can auto-detect row completion.
  19. hurricos
    74
    24
    Burlington, Vermont
    On a more serious note:
    The 2006-2016 Highlander Hybrid (and equivalently, 2005-2008 Lexus RX400h) uses QTY30 8-cell modules (quite literally like the Prismatic 6-cell module, but longer) to comprise a 240-cell NiMH pack. There are a few assembly variants, all divided into three sub-packs to be bolted under the seats -- 2006-2009 is 12-6-12 (i.e. the first submodule is 250mm wide 377mm long, 118mm tall, with ~20mm of plenum space above and below), and after the 2nd gen Highlander facelift in 2010, the 2010-2016 is 10-10-10. Edit: Looks like the RX450h (2015-2022) also uses the 10-10-10 design -- see Jack's videos here:
    The inverter on these units can handle a very high HVDC on the battery side -- I've seen my 2006 go up to ~380V. It does appear the LX68 modules don't quite fit in these cars - not enough space for QTY72 cells. The production numbers aren't terrible -- "[Toyota targeted] 62,000 RX 400h and Toyota Highlander hybrid cars [from 2006 onwards]"; alternatively, see Toyota's full (up to 2016) sales figures for the Lexus hybrids here: Lexus Hybrid Owners, Thanks a Million | Toyota Motor Corporation Official Global Website
    #119 hurricos, Mar 9, 2026
  20. hurricos
    74
    24
    Burlington, Vermont
    Upon review, looks like the larger Lexus hybrids continued to use the 240-cell NiMH pack alongside the lower-end Gen4 Priuses -- Ctrl-F "288" in the lower table here: Toyota Hybrid - Transmissions line-up
    The 10-10-10 *might* fit QTY6 LX68 modules laid on their sides - certainly plenty of space for power cable bends -- but all of these applications demand a voltage-spoofing circuit designed for much higher voltages, and different connectors than the Gen3 BSU's. Reviewing ...
