Seeking "pop-in" light sub-panel for 2010 Prius lift gate
Discussion in 'Gen 3 Prius Accessories and Modifications' started by gatorback, Feb 1, 2026.
  1. gatorback
    gatorback Junior Member
    57
    The lift gate seems to have a sub panel that could be popped out. It would be ideal if one could pop in a LED light fixture (designed for this lift gate or fits by happenstance) that is switched on off / automatically, so as to provide light when needed and turn off automatically so as to not deplete the battery..
    Does such a unicorn exist? I would think I am not the first to look for such a fixture.
    Photograph of said sub panel in the lift gate
    52,351
    maybe a stick on battery operated led?
    gatorback likes this.
  3. gatorback
    57
    I followed your suggestion last month. I neglected to mention in the the original post that I would like to wire power in to the light.
  4. bisco
    52,351
    those are available as well, but none that will fit in that panel area
  5. Mr. F
    Mr. F Active Member
    389
    263
    Washington
    shangief, Xterra72, gatorback and 2 others like this.
  6. amarino
    amarino Active Member
    142
    105
    99
  7. gatorback
    57
  8. gatorback
    57
    Would be nice if the switch would turn off automatically after a 15 minutes or when the trunk is closed. Unicorn?
  9. AzWxGuy
    AzWxGuy Weather Guy
    1,065
    547
    Tucson, AZ
    2021 Prius
    For reference, I believe those two pop-out panels are for access to the license plate illumination LEDs.
  10. Xterra72
    Xterra72 Senior Member
    1,437
    1,681
    Great find! Did not know that they still sold this. I've had mine for at least 10 years and it still works with no issues!
