Dreaded P0A80 Code - Car Running / Charging Good.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PriuSocal, Jan 25, 2026.
  1. ASRDogman
    ASRDogman Senior Member
    8,055
    4,083
    Mixing coolant is not good. You run the risk of it jelling up, and not flowing.
    But it's done.
    If you fill it slowly, and a little at a time, you won't have to worry about air pockets because the coolant
    will push it out.
    If the coolant temperature is within specs, while driving, it's likely working correctly.
    PriuSocal likes this.
  2. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    Yes, I agree. It was def mixed with orange coolant or water at some point. Here is a photo of how it looked like: image.jpeg
    About a Gallon came out and about a gallon and a bit more went in. I was glad there wasnt any foreign looking sediment or jelling as you say which can also indicate head gasket “fix” additives to the system. It is nice and pink now and temp hovering within spec, so glad it was done on time. As for he flow/current in the reservoirs, is there suppose to be one in the coolant or inverter reservoirs like on the Gen 2? I didnt see any flow on mine, just steady coolant. And, as mentioned live data showed the water pump at normal operating speeds.
  3. rjparker
    11,049
    6,924
    Yes there is a good flow entering from the top reservoir hose once the thermostat opens. Flow before the thermostat opens uses the thermostat bypass inlet. Even after the thermostat opens a majority of the flow returns via the big radiator hose.
    Regardless there is a decent flow through the reservoir after the thermostat opens.
    Due to the somewhat opaque plastic of the reservoir, I place a small led flashlight directly on the top of the reservoir to light up the inside, making the flow clearer.
    A portion of the gen3 coolant flows (edited from a slightly different gen4 diagram)
    #43 rjparker, Feb 6, 2026
  4. ASRDogman
    8,055
    4,083
    nasty!
    How fast if flows is hot it is and how much it need to cool.
    It circulates mostly to the radiator, so you won't see a lot of movement in the coolant tank.
    You might as well change the inverter coolant. It's the same coolant. Quicker and easier to change.
  5. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    Lol, its def not to be had on the rocks.
    Awesome, thanks for the clarification. As for the inverter coolant, it is in good cond so ill leave that alone for now as I need to get onto the rear brakes and front sway bar links 1st. It sucks as I have to disconnect the battery to do the rear brakes and need to get it smogged so that means my monitors will now take even longer to complete.
  6. ASRDogman
    8,055
    4,083
    Yea, the inverter's not important......
    Why would you disconnect the battery to do the brakes??? No reason too.
    Just do NOT open the drivers door while you're working on them. And keep the key fob more than
    20 feet away from the car.
    I've replaced the rear pads a few times and the hubs and didn't disconnect the battery.
    If you think a family member or friend might open it, put a note on the window and down across
    the door handle that says DO NOT OPEN.....
  7. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    I guess after most videos I have found, advice to remove the negative battery connection to avoid caliper engaging and damaging itself. The car care nut guy has a video on servicing rear brakes with electronic parking brakes but doesn't seem it apply to Prius models. All videos seen still require you to manually retract the caliper using a retract square.
  8. ASRDogman
    8,055
    4,083
    As long as you do NOT open the drivers door, you will not have a problem.
    If you open the door, the pump will activate and push the puck out if you don't have the pads in
    and on the rotor.
    It won't hurt to disconnect the 12v battery, but you don't have too.
    You will have to rotate the puck to get it all the way back in for the new pads to work.
    Make sure you align the pucks to the pins from the pad to fit in the slots or you'll have an angled pad
    and rapid uneven wear.
  9. ChapmanF
    18,993
    When the pump activates, it puts pressure into the storage accumulator. There is always supposed to be pressure there, and the pressure there never pushes on any puck, except when the brakes are applied. If it did, the brakes would be constantly dragging.
    However, a gen 3 also does a brake self-test, 90 seconds after shutting down. That self-test does apply pressure to the brakes, and will push any puck out if the pads and rotor aren't there to restrain it.
    PriuSocal and Brian1954 like this.
  10. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    Well just did the rear brakes w/out disconnecting the battery, Thanks for the tip. The brakes were near gone and glad I noticed on time, I may have to resurface the rotors though as when the wheel spins, I hear a slight rub……rub…..rub….rub at low speeds. I did make sure to turn the caliper all the way back and match the pad stud with the caliper groove. Brake fluid level is also good.
  11. ASRDogman
    8,055
    4,083
    That's good. Check the backing plate/dust shield. It is easily bent....
  12. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    Well bumming news…I have been driving the car around the neighborhood and it runs/charges great and no codes are present BUT something has me scratching my head. I was about to take it to get smogged and checked I/M readiness and it said all monitors were completed and ready for smog. I then ran a check for codes again with my blue driver dongle and it gave me 1 PERMANENT code for P0A80 (mind you again no current codes). I then ran my Autel AP200 and it showed no codes either. However, I was told the car would fail with that PERMANENT code in the system and so now i'm stumped as to what to do because the car appears to be running fine, HV battery works fine and no other CEL codes present.
    I had an issue once where my old Gen 2 was down for about a month when I replaced the transmission and upon starting it up, it had the P0A80 code present. I deleted the codes and it never came back on but I cannot delete the PERMANENT code with my scanners.
    Any recommendations for this issue? I have seen videos that speak on it needing to complete the 15 drives /200 miles drive cycle with no issues in order tor the car to clear it on its own but I am having second thoughts as the tags are expired (hence why i need it smogged to register it) and don't want to get pulled over on longer drives.
  13. rjparker
    11,049
    6,924
    You can try this:
  14. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    Brian1954 likes this.
  15. ChapmanF
    18,993
    While the confirmation pattern mentions Techstream, by looking at the steps in the procedure, you can see that what you need is any capable scan tool able to view and clear codes for the hybrid system, and to display the traction battery state of charge so you can know when it is below 30%.
    If you don't already have any such scan tool, there are threads here that can help you select one. You could also seek help from someone who has one.
    ScottHz, PriuSocal and Brian1954 like this.
  16. rjparker
    11,049
    6,924
    You do have to follow the procedure exactly even if a step seems unnecessary.
    Part of the procedure is a forced discharge of the hv battery to 30% which is low. Effectively a stress test. It is worth a try since it does not require a long multi day period of good battery performance to clear the battery permanent code, but some bad modules may show again.
    Under the 10 year 150k mile warranty, Toyota would replace the battery free with that code.
    While most of us warn against the poor value of "rebuilt" batteries due to very short lifespans, that may be a low budget answer if the confirmation pattern technique fails with the current battery.
    Even with a rebuilt or preferably a new oem nimh, someone would still need to run the confirmation pattern unless a receipt is good enough for the emissions testing.
    ScottHz and PriuSocal like this.
  17. indel
    indel Member
    283
    89
    Northwest Indiana
    I am a bit confused. What does P0A80 have to do with the emissions check? Is it because the emission testing rejects simply based on the fact that CEL is ON?
  18. rjparker
    11,049
    6,924
    California requires no codes.
  19. ChapmanF
    18,993
    A Prius can't meet its emissions targets if the traction battery is to far gone.
  20. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    I believe the Autel AP200 can check the HV state of charge if I recall correctly. I have have 4 scan tools from the cheaper BlueDriver, Autel AP200, Zurich ZR11 and a ICON T10 which is my go to with major tests but they have had issues with Toyota regarding licensing hence I have to juggle between the lesser ones for diag and testing. Proof that not all scanners even though more expensive, can do the job.
    I think techstream is def a good option specifically for Toyotas and Priuses in particular. I saw a guy on Offerup selling a laptop with techstream installed for $300. Your thoughts?
    #60 PriuSocal, Feb 10, 2026
    ScottHz likes this.
