Dreaded P0A80 Code - Car Running / Charging Good.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PriuSocal, Jan 25, 2026.
  1. ASRDogman
    ASRDogman Senior Member
    7,708
    3,955
    Mixing coolant is not good. You run the risk of it jelling up, and not flowing.
    But it's done.
    If you fill it slowly, and a little at a time, you won't have to worry about air pockets because the coolant
    will push it out.
    If the coolant temperature is within specs, while driving, it's likely working correctly.
    PriuSocal likes this.
  2. PriuSocal
    PriuSocal Member
    270
    SoCal
    Yes, I agree. It was def mixed with orange coolant or water at some point. Here is a photo of how it looked like: image.jpeg
    About a Gallon came out and about a gallon and a bit more went in. I was glad there wasnt any foreign looking sediment or jelling as you say which can also indicate head gasket “fix” additives to the system. It is nice and pink now and temp hovering within spec, so glad it was done on time. As for he flow/current in the reservoirs, is there suppose to be one in the coolant or inverter reservoirs like on the Gen 2? I didnt see any flow on mine, just steady coolant. And, as mentioned live data showed the water pump at normal operating speeds.
  3. rjparker
    10,351
    6,475
    Yes there is a good flow entering from the top reservoir hose once the thermostat opens. Flow before the thermostat opens uses the thermostat bypass inlet. Even after the thermostat opens a majority of the flow returns via the big radiator hose.
    Regardless there is a decent flow through the reservoir after the thermostat opens.
    Due to the somewhat opaque plastic of the reservoir, I place a small led flashlight directly on the top of the reservoir to light up the inside, making the flow clearer.
    A portion of the gen3 coolant flows (edited from a slightly different gen4 diagram)
    #43 rjparker, Feb 6, 2026 at 2:19 PM
  4. ASRDogman
    7,708
    3,955
    nasty!
    How fast if flows is hot it is and how much it need to cool.
    It circulates mostly to the radiator, so you won't see a lot of movement in the coolant tank.
    You might as well change the inverter coolant. It's the same coolant. Quicker and easier to change.
  5. PriuSocal
    PriuSocal Member
    270
    SoCal
    Lol, its def not to be had on the rocks.
    Awesome, thanks for the clarification. As for the inverter coolant, it is in good cond so ill leave that alone for now as I need to get onto the rear brakes and front sway bar links 1st. It sucks as I have to disconnect the battery to do the rear brakes and need to get it smogged so that means my monitors will now take even longer to complete.
  6. ASRDogman
    7,708
    3,955
    Yea, the inverter's not important......
    Why would you disconnect the battery to do the brakes??? No reason too.
    Just do NOT open the drivers door while you're working on them. And keep the key fob more than
    20 feet away from the car.
    I've replaced the rear pads a few times and the hubs and didn't disconnect the battery.
    If you think a family member or friend might open it, put a note on the window and down across
    the door handle that says DO NOT OPEN.....
  7. PriuSocal
    PriuSocal Member
    270
    SoCal
    I guess after most videos I have found, advice to remove the negative battery connection to avoid caliper engaging and damaging itself. The car care nut guy has a video on servicing rear brakes with electronic parking brakes but doesn't seem it apply to Prius models. All videos seen still require you to manually retract the caliper using a retract square.
  8. ASRDogman
    7,708
    3,955
    As long as you do NOT open the drivers door, you will not have a problem.
    If you open the door, the pump will activate and push the puck out if you don't have the pads in
    and on the rotor.
    It won't hurt to disconnect the 12v battery, but you don't have too.
    You will have to rotate the puck to get it all the way back in for the new pads to work.
    Make sure you align the pucks to the pins from the pad to fit in the slots or you'll have an angled pad
    and rapid uneven wear.
  9. ChapmanF
    18,400
    When the pump activates, it puts pressure into the storage accumulator. There is always supposed to be pressure there, and the pressure there never pushes on any puck, except when the brakes are applied. If it did, the brakes would be constantly dragging.
    However, a gen 3 also does a brake self-test, 90 seconds after shutting down. That self-test does apply pressure to the brakes, and will push any puck out if the pads and rotor aren't there to restrain it.
    PriuSocal and Brian1954 like this.
  10. PriuSocal
    PriuSocal Member
    270
    SoCal
    Well just did the rear brakes w/out disconnecting the battery, Thanks for the tip. The brakes were near gone and glad I noticed on time, I may have to resurface the rotors though as when the wheel spins, I hear a slight rub……rub…..rub….rub at low speeds. I did make sure to turn the caliper all the way back and match the pad stud with the caliper groove. Brake fluid level is also good.
  11. ASRDogman
    7,708
    3,955
    That's good. Check the backing plate/dust shield. It is easily bent....
