2026 Prius Plug in won't start
Discussion in 'Gen 5 Prius Main Forum' started by sistersinhim, Feb 11, 2026 at 11:43 AM.
  1. sistersinhim
    sistersinhim Junior Member
    30
    Central Virginia
    2020 Prius Prime
    Technology AWD-e
    Another question: my friend is trying to reset the maintenence light on her 2014 after she changed the oil. I've tried what the book says, but it doesn't work. I've also tried online, and 2 different things didn't work either.
  2. Gokhan
    Gokhan Senior Member
    6,453
    2,577
    Paramount CA
    Not sure which battery maintainer you bought, but if it is the Noco Genius, the battery will recharge automatically, on and off every few days, as long as it is connected.
    LRO likes this.
  3. Gokhan
    6,453
    2,577
    Paramount CA
    Ask it on the Gen 3 forum.
  4. sistersinhim
    30
    Central Virginia
    2020 Prius Prime
    Technology AWD-e
    We got the maintenance needed cut off.
    Gokhan likes this.
  5. sistersinhim
    30
    Central Virginia
    2020 Prius Prime
    Technology AWD-e
    Back to my question about the odometer and temperature reading not changing since the dead battery. Is there something I need to do?
  6. Gokhan
    6,453
    2,577
    Paramount CA
    No
  7. sistersinhim
    30
    Central Virginia
    2020 Prius Prime
    Technology AWD-e
    But it says to not use the trikle charge inside the car. I was hoping to put it next to the battery in the car and plug the charger into a backup battery. That sounds like it won't be safe. Do I have to remove the battery from the car?
  8. sistersinhim
    30
    Central Virginia
    2020 Prius Prime
    Technology AWD-e
    Do I have to take it back to the dealer to reset them or will it happen eventually?
  9. Gokhan
    6,453
    2,577
    Paramount CA
    Again, if it is the Noco Genius, it could be left powered on and connected to the car indefinitely. No idea what you bought.
  10. Gokhan
    6,453
    2,577
    Paramount CA
    Those things never need a reset and shouldn’t be affected by a 12-V battery disconnect. If there is really a malfunction, no idea what the problem is.
    sistersinhim likes this.
  11. Gokhan
    6,453
    2,577
    Paramount CA
    Don’t keep the hatch open, though, as the light bulb will burn out. Those miniature tungsten bulbs have a life of only a few hundred hours. Use the 12 V service connector under the hood instead.
    #31 Gokhan, Feb 14, 2026 at 5:04 PM
    LRO and BiomedO1 like this.
  12. VelvetFoot
    VelvetFoot Active Member
    1,077
    402
    New York State
    2026 Prius
    tungsten? lol. This is a Gen5!
    I have a NOCO1 in the trunk, attached to the battery, just in case, or did I say that already?
    My plan is to hook it up to a thin, flat extension cord. I do believe the weatherstripping will be okay when the hatch is closed.
    The battery has a vent tube to the outside.
    Gokhan likes this.
  13. Gokhan
    6,453
    2,577
    Paramount CA
    Giant leap in technology with the trunk light having been updated from tungsten to LED from Gen 4 to Gen 5! ;)
    VelvetFoot likes this.
  14. BiomedO1
    3,966
    2,091
    SacTown, Ca
    Yes; you should hook-up the RV battery maintainer under the hood. There is a jump-point there. Hopefully you purchased a maintainer that's capable of outputting at least 2+ amps. Leaving the hood up won't draw extra current and will remind you to unplug the car before taking-off. A three mile drive isn't long enough for the 12V battery to recharge itself. I also wouldn't plug-in the car everyday either. You need to work all of the car's systems, in order to keep them healthy - you know what they say, use it or lose it. You'll also need to run your gasoline engine for at least 30 minutes about every 3-4 weeks. That should be easy in the winter months to generate heat for the cabin. You just need to do the same in the summer months too. Again, to keep everything lubed-up and running.
    As for the 2014 Prius; I believe the manual failed to mention that your odometer needs to be in factory default mode, before beginning the instructions to reset the maintenance minder. I believe your odometer need to be set for total miles - NOT tripA or tripB. It's been a while since I've done one of those; but I believe you need to turn-on the car and press a button 3 times; holding it down on the third. Your display should start counting-down and you must keep that button down. If you release that button before the end of the count-down, it won't let you in to reset the maintenance minder.
    I also believe there's a couple of Youtube videos on this issue too..
    Good Luck....
    LRO and VelvetFoot like this.
  15. LRO
    LRO Junior Member
    United States
    2024 Prius Prime
    XSE Premium
    Just wanted to show in attached image that in a 5th Gen Prius there's also a perfect slot available to route a charging cable under the hood between the rubber seal at the leading edge of the hood and the "tear duct" of the headlamp. I recall in my early attempts at leaving the hood up it seemed a warning kept appearing on the MID display that may not have gone away to my liking.
  16. sistersinhim
    30
    Central Virginia
    2020 Prius Prime
    Technology AWD-e
    Thanks everyone for your help! I will use the post under the hood. That's where we jumped it.
    BiomedO1 likes this.
