Oil marks on dipstick
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by C Clay, Jan 8, 2026.
  1. CR94
    CR94 Senior Member
    2,733
    1,193
    Northwestern S.C.
    It isn't necessary to use such an elaborate system to do that. My ~$25 12-v pump gets the job done, and as far as I can tell, gets out at least as much as opening the plug. Not having to raise the car and conspicously crawl under it is a big improvement where car maintanance is banned. It also saves a lot of time and mess.
  2. ASRDogman
    ASRDogman Senior Member
    7,737
    3,962
    And how do you change the oil filter???
  3. C Clay
    C Clay Member
    353
    68
    Lexington, KY
    Hey, while we’re having fun with this thread… I have wondered if there is any hack or modification one can do to move the oil filter up to where the dipstick is? Wouldn’t that be sweet!
    Did I see a video of a Subaru engine where that is where the oil filter is for certain engines?
  4. ASRDogman
    7,737
    3,962
    Fun?
    Many engines have the oil filter up top. Which is where it should be.
    Now YOU have a project. Design a replacement for the oil filter housing next to the crank pulley,
    and design a new oil filter housing combining the oil dipstick and oil filter.
    mass produce it and sell it for under $30.
    (y)(y):whistle:
    C Clay likes this.
  5. rjparker
    10,385
    6,503
    The way to do it with off the shelf parts is to first convert your gen3 to a standard spin on filter using 2018 gen4 oil filter housing parts
    and then use a universal remote mount kit for the 3/4"-16 filter thread
    Brian1954 likes this.
