1. veggiecar
    veggiecar Junior Member
    My 2012 Prius with 278,000 miles has a problem. The engine sounds awful and act like it is shaking off of its mounts. The check engine light is on. There is an unburnt fuel smell as the car runs. The engine oil dipstick seems free of coolant. The code from the computer is P0303. The scan tells me that the number 3 cylinder is misfiring. My reading of prior post suggests a possibility of a bad coil or a blown head gasket. Are coils something that should be replaced after a certain number of miles? I can replace them all for about 50 dollars. How do you tell if there is a blown head gasket? How do you suggest I proceed? Thanks so much for the help…
  2. BiomedO1
    4,064
    2,136
    SacTown, Ca
    Swap the ignition coil from #3 and see if the problem moves. That would verify an ignition coil issue.
    ie. say you swap #1 & #3 coils and the code changes to P0301; that would tell you that coil is bad - since #3 cylinder is now firing. You can do the same with the injector and spark plugs; though that would be a lot more work. ONLY move ONE thing at a time while testing; so you don't have to guess which part actually failed.
    #2 BiomedO1, Feb 16, 2026
  3. ASRDogman
    ASRDogman Senior Member
    7,790
    3,975
    Have you recently replaced the spark plugs? Did you get them off amazon or ebay???
    If so, they are very likely cheap chinese copies.
    Coils last a long time. Mine have 382,000 + miles. Swoping the #3 and 4 coils is a good way to
    see if the coil is bad. If the miss fire stays at #3, it's the plug.
    Bosch plugs from Autozone have worked well for me.
    If the coil is bad, do not get cheap ones! Unless you like removing the windshield wiper assembly a lot.
    They likely but a few hundred miles. $12.50 for Prius coils, is extremely cheap!
    Check the coolant tank, is it at the full mark? If it is, the head gasket is likely okay, at least for now.
    Usually, the gasket fails between cylinders 1 and 2. But sometimes it's 3 and 4, but it's rare.
    You likely will never see water in the oil in a Gen 3 Prius. By the time that happens, you'll need a motor.
  4. veggiecar
    Thanks for the help… I changed the coil between one and three. Correct me if I’m wrong, I understand the cylinders are counted from left to right in order. I have some software on my computer to read the codes. Unfortunately, I can not tell if the information is new in that the number of misfires did not change from my earlier exam. Also the engine would only run for a couple of seconds before it would shut off. It did give me another code of P0302. It says that both codes are active. I have not swapped spark plugs or injectors yet. As to my coolant level it seems like it might be a little lower than the last time I checked it. I drove the car about 5 miles with the issue. It never ran great but at forty-five the engine vibration was greatly reduced. Would the coolant go down much with 5 miles of driving? Is changing the head gasket a difficult job? I am up for trying. I successfully disassembled my HV battery to get rid of the triangle of doom, changed brake rotors and pads and replaced the brake master cylinder along with general maintenance.
  5. ASRDogman
    7,790
    3,975
    Did you clear the codes? I guess I had forgotten to tell you that.
    Why did you change 1 and 3? Why not 3 and 2 or 4?
    It's confusing....
    Perhaps you should remove the spark plugs and look at them. And look down the spark plug holes
    and see if any of the pistons look cleaner than the others. And you can inspect the plugs as well.
    You can also use an inexpensive bore scope. And if you put pressure on the coolant system, you
    could see coolant leaking past the head gasket, if it has failed.
    Are you certain the engine is actually starting? The hybrid battery will turn the engine over for 15-20
    seconds before disengaging. Do you have fuel in the tank?
    Perhaps check all the electrical connections, and check the fuel lines, you could have a leak. You did
    say you smells fuel.
    It does take some still to replace the head gasket. Have you ever changed a head gasket on any engine?
    It's the same.
  6. veggiecar
    ASRDogman…Thanks for the input. I watched a video on changing the head gasket and it is quite involved. At this moment the car is worth nothing so if I get another car I will keep this Prius and spend the time fixing it. Tomorrow I will go through all of your suggestions and report back. Thanks again.
  7. ASRDogman
    7,790
    3,975
    Good Luck! (y)
  8. rjparker
    10,442
    6,549
    Sounds like its not starting at all. A hybrid motor spins the engine so fast people often think the dngine is running.
    No
    BiomedO1 likes this.
  9. BiomedO1
    4,064
    2,136
    SacTown, Ca
    #1 is always the one closest to the harmonic balancer. Never use left or right references on the car, since most people don't know their left from their right. Depending on if they're sitting in the driver's seat or staring at the engine from the front of the car. Driver's side vs passenger side sometimes works too; unless your talking about a UK car vs US car. See what I mean????:(:whistle:
    CR94 likes this.
  10. veggiecar
    I swapped the #3 cylinder spark plug with #2 cylinder and the #3 coil with #4 coil. I watched the live stream from the car computer and as the car was running, the #4 cylinder was active. I’m not sure what it means but there is a “value” that goes up and down. The #4 fluctuated while all of the other cylinders remained at 0. There is a total misfires number that continued to go up. I am going to move the coil over to the #2 cylinder and see if the problem follows. This suggests that the coil might be the problem and it would be worth replacing. Input regarding this information is appreciated. A couple of questions: What is the “value” that is going up and down represent? What coils do you recommend and should they be replaced as a set or would replacing only one be acceptable? I was asked earlier what brand of spark plugs I have. They are autolite. I have included a comparison between the #2 plug and the #3 plug. Thanks so much for the help… IMG_3663.jpeg IMG_3662.jpeg
  11. Mendel Leisk
    41,855
    as you stand at front of car, facing engine bay, yes: cylinder one is at your left (aka "front") end of the engine.
    Last link in my signature is the full engine section of the repair manual, should have that info. (On a phone turn it landscape to see signatures.)
    How long have you had the car?
    Addendum: just browsed the aforementioned "full engine section" myself, and could not find a diagram corroborating this cylinder ordering. But it's lore...
    #11 Mendel Leisk, Feb 17, 2026
  12. veggiecar
    I bought the car new in 2012. I love the car and hope to keep it going for a long time to come. My son is going to a local college and uses it to get to school and other local activities.
  13. Mendel Leisk
    41,855
    EGR (Exhaust Gas Recirculation) system, including intake manifold, ever cleaned? If not, it'll likely be fully clogged, and has caused head gasket failure.
  14. BiomedO1
    4,064
    2,136
    SacTown, Ca
    Sounds like you have a problem with the coil currently in #4 position. At close to 300K miles; IMHO - I'd go ahead and replace all 4 coils. Toss out the know bad one, keep the other 3 for future troubleshooting. Are those Autolite spark plugs iridium? Iridium plugs will go 100K+ miles w/o issues.
    re: spark plugs. The brown one is fine, the darker blacker one is burning some oil or running a little rich in that cylinder. Should probably run some injection cleaner with your next tank of gas; that might clean-out a slightly leaky injector issue. If the slightly blacker plug is from #3, that would explain the darker color - unburned, rich fuel mixture from intermittent misfires.
    Hope this helps....
    #14 BiomedO1, Feb 17, 2026
  15. rjparker
    10,442
    6,549
    A value of zero on a cylinder misfire counter means no misfires, while a higher number represents misfires per 200 revolutions.
  16. veggiecar
    Thanks to all. I did clean the EGR and all of the pipes, the intake manifold and replaced the PCV. I installed an oil catch can and cleaned the MAP sensor. I soaked the EGR with oxiclean for a short time and then hit it with a pressure washer (did not hold the EGR with my hand). I was covered with specks of soot but the EGR was clean. That was about 30K miles ago. I moved the coil to #2 cylinder, cleared the codes and the new code was P0302. I will replace all of the coils and spark plugs. I will get iridium spark plugs. Please recommend good coils to purchase. I will give an update. Thanks again
  17. BiomedO1
    4,064
    2,136
    SacTown, Ca
    I would just get any random quality set of coils; since they're easy to get to and your going to have 3 relatively good coils to do a quick swap out to test - if you have future issues. Don't dismiss the local auto parts stores; some of them will give you a "lifetime warranty". IMHO - Worth the slightly elevated cost, if your going to drive the wheels off of that car. Ditto with spark plugs; just keep the receipts in the glove box and toss the spare coils in the spare tire wheel well; so you don't lose them in your garage mess.
    I had an intermittent coil on my GMC @ 210K miles. It didn't completely die for another 6 months and anytime I pulled over to try to troubleshoot it - it would start working again. My code reader stated P0300, so no help there. I even pulled onto the shoulder of the highway a few times to try to troubleshoot it; only for the problem to disappear again. It eventually failed long enough for me to troubleshoot it, so I replaced it - just the one. Fast-forward 9 months later, the same thing started happening again; so I shot-gunned all the coils and haven't had an issue since. That was 60K miles ago. I only held onto the newest coil, figuring that the rest of them wasn't too far behind intermittently failing too. The set was way cheaper than the individual coil. The single coil, I purchased at a local chain auto parts store, w/lifetime warranty.
    Good Luck......
    #17 BiomedO1, Feb 17, 2026
  18. ASRDogman
    7,790
    3,975
    The first rule of diagnoses is to make it simple. By moving plugs and coils, you made it unsimple.
    If you have a misfire on ONE cylinder, you move THAT coil with the one next to it. Clear the codes.
    Run the engine. If the misfire moves, the coil is the issue. If it doesn't move, it's the spark plug.
    Those plugs do not look like iridium plugs. Either get the ND plugs from the Toyota Dealer, or try
    autozone for the Bosch plugs. https://www.autozone.com/p/bosch-spark-plug-96339/1043174?searchText=spark+plugs&productPartGroupId=azpg4514&productBrandId=BBHK&productUniqueId=5935644815472
    Same for the coils. You don't really want to go cheap with these parts. How often do you replace them???
    Since you like to do a lot of work, just buy GOOD spark plugs, install them, and drive.
    You may not need coils at all. But if you still get misfires, then buy the coils.
  19. rjparker
    10,442
    6,549
    Don't go cheap on plugs or coils; they may fail quickly and you would have been better off just replacing the one failed coil with oem.
    #19 rjparker, Feb 17, 2026
    Brian1954 likes this.
  20. veggiecar
    I put in new coils and plugs and the car is running great. Thanks to all for the help. Michael
    Brian1954 and BiomedO1 like this.
