Oil marks on dipstick
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by C Clay, Jan 8, 2026.
  1. CR94
    CR94 Senior Member
    2,733
    1,193
    Northwestern S.C.
    It isn't necessary to use such an elaborate system to do that. My ~$25 12-v pump gets the job done, and as far as I can tell, gets out at least as much as opening the plug. Not having to raise the car and conspicously crawl under it is a big improvement where car maintanance is banned. It also saves a lot of time and mess.
  2. ASRDogman
    ASRDogman Senior Member
    7,741
    3,962
    And how do you change the oil filter???
  3. C Clay
    C Clay Member
    353
    68
    Lexington, KY
    Hey, while we’re having fun with this thread… I have wondered if there is any hack or modification one can do to move the oil filter up to where the dipstick is? Wouldn’t that be sweet!
    Did I see a video of a Subaru engine where that is where the oil filter is for certain engines?
  4. ASRDogman
    7,741
    3,962
    Fun?
    Many engines have the oil filter up top. Which is where it should be.
    Now YOU have a project. Design a replacement for the oil filter housing next to the crank pulley,
    and design a new oil filter housing combining the oil dipstick and oil filter.
    mass produce it and sell it for under $30.
    (y)(y):whistle:
    C Clay likes this.
  5. rjparker
    10,388
    6,506
    The way to do it with off the shelf parts is to first convert your gen3 to a standard spin on filter using 2018 gen4 oil filter housing parts
    and then use a universal remote mount kit for the 3/4"-16 filter thread
    Brian1954 likes this.
  6. Mendel Leisk
    41,792
    I did the oil filter conversion to spin-on, but can't get my head about why you'd want to shift the filter location: at least if you're under there, doing a conventional oil change, it's right there, and not going to drip on anything. If you're thinking to vacuum the oil out through dipstick it'd make more sense, but...
  7. rjparker
    10,388
    6,506
    Because you can do the whole change from above as discussed in posts 39 and 41. No mess; no danger.
  8. Mendel Leisk
    41,792
    Regarding danger, I make a point to always push a robust tree trunk section under first, a little aft of the engine bay, under a solid beam. Roughly the same height/diameter, uncompressible, and significantly thicker than me.
  9. ColoradoBoo
    ColoradoBoo Senior Member
    1,259
    864
    Monument, Colorado USA
    It, definitely, sounds like the head gasket needs replacing but you could know for sure with a pretty inexpensive test kit.
    I saw a video on it a while back....
  10. Mendel Leisk
    41,792
    From the video: "the basic principal here, is you pull coolant from your radiator, and if it stays blue, you don't have a head gasket leak". That's only applicable IF the leak is carbon monoxide (from the exhaust) into coolant, which is NOT the typical 3rd gen Prius leak type, it's usually coolant leaking into cylnders.
