Setting water pump belt tension question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by pasadena_commut, Feb 21, 2026 at 7:35 PM.
  1. pasadena_commut
    pasadena_commut Senior Member
    2,762
    827
    Southern California
    Out of curiosity, if one were to loosen the tension bolt for that belt by exactly N turns (whatever it takes to remove the belt), swap on the new belt, and then turn that bolt the other way exactly the same amount, would the belt be at the correct tension? Naively it seems like it would, at least as long as nobody ever readjusted the tension after the previous belt was put on.
  2. PriusCamper
    PriusCamper Senior Member
    12,964
    5,275
    Pacific Northwest, USA
    That's how they do it on spacewalks outside the spacestation... They have two different people at ground control to help count your rotations too. Of course when not in the vacumm of space you get dirt and grime and belt wear which can slightly change the number of rotations you need. Also a brand new belt will stretch a little and so a tiny bit tighter would be better than a tiny bit looser.
  3. BiomedO1
    3,994
    2,102
    SacTown, Ca
    The short answer is NO. The old belt is worn and stretched and your assuming the new belt is within millimeters of length of your old belt. Tension the replacement belt per OEM manual/procedures. Don't over-tighten them or your going to have bearing and bushing issues.
    Brian1954 likes this.
